Is it expected that the DK's debug-out reset driver follows an externally driven low on SWD0_RESET and keeps the line low after the external source releases it? Which part drives SWD0_RESET on the nRF54LM20 DK, and is it open-drain?
If you look at the schematics above, the SWD0_RESET line on P13 is driven by U8, a TXB0104 bidirectional push-pull level shifter (not open-drain), with VCCA tied to VDD:DBGR (the interface MCU's rail) and VCCB tied to VDD:SWD0 (sourced from the target's SWD0_VTG on pin 1 of P13). To answer your question, Yes. If a debug operation times out, the J-Link OB firmware gets stuck mid-sequence and never issues a release command. Because of this, it leaves the reset signal actively asserted. he TXB0104 is a push-pull driver. It actively drives both high and low states, which is why it forces the target's reset line down to ~0.43 V instead of letting it float back up.
Why would RESET_HARD (CTRL-AP) after a program leave the reset line asserted, when RESET_PIN clears it?
The J-Link OB firmware drives on the RESET net, so once RESET_PIN commands the line high, U8 actively drives SWD0_RESET_EXT high and the target's P0.18 returns to 1.8 V.
Is there a DK (interface MCU / J-Link OB) firmware update or a solder-bridge configuration that changes this behaviour, short of leaving pin 10 out of the ribbon?
There is currently no firmware update. The only workaround is assuggested in the datasheet: Leave pin 10 out of the ribbon (as you noted) since U8 is push-pull on all four channels simultaneously, this is the only hardware-level isolation.
Regards
Pallavi
