nRF52840 DK v3.0.3 Debug out (P19) → custom board via Tag-Connect TC2030-CTX-NL: voltage mismatch (3.0 V vs 3.3 V) and no nRESET
I want to program and debug a custom board using my nRF52840 DK (PCA10056 v3.0.3) as the programmer, through the Debug out connector P19. Before I order the cable, I would like to confirm a few things.
Setup
  • Programmer: nRF52840 DK v3.0.3, powered from USB. SB47 and SB19 are open (default).
  • Target: custom board with a Raytac MDBT50Q-1MV2 module (nRF52840), powered from its own primary lithium battery (Saft LS14250, 3.6 V) through a 3.3 V LDO (TPS7A0233). VDD and VDDH are both tied to this 3.3 V rail, so the target runs at 3.3 V.
  • Target debug connector: Tag-Connect TC2030-IDC-NL footprint (6 pads), wired as: pin 1 = 3.3 V, pin 2 = SWDIO, pin 3 = nRESET (not connected), pin 4 = SWDCLK, pin 5 = GND, pin 6 = SWO (not connected). P0.18 is also not connected on the board.
  • Planned cable: Tag-Connect TC2030-CTX-NL (6-pin Tag-Connect end, 10-pin Cortex Debug connector). According to the Tag-Connect TC2030-CTX datasheet, the 10-pin end is: 1 VCC, 2 SWDIO, 3 GND, 4 SWCLK, 5 GND, 6 SWO, 9 GNDDetect, 10 nRESET.
  • The module is blank (no bootloader, APPROTECT not enabled).
Questions
  1. The DK User Guide (section 4.10) says the external board voltage must match the DK voltage, and that the DK voltage is 3 V when powered through USB. My target runs at 3.3 V. Is this 0.3 V difference acceptable for SWD programming and debugging with the on-board J-Link OB? If not, what is the recommended way to match the voltages (for example powering the target from the DK, or setting the DK VDD)?
  2. In v3.0.3, the guide says the interface MCU programs the external target when P19 pin 3 (SWD0_SELECT) is connected to GND. With the TC2030-CTX-NL cable, pin 3 of the 10-pin connector is GND according to Tag-Connect. Is this a correct and supported way to select the external target? Is the voltage on P19 pin 1 (SWD0_VTG) used as a reference for the SWD signal levels, or only for detecting the target?
  3. My target has nRESET not connected. Is it enough to connect VTG, SWDIO, SWDCLK and GND to program, debug, and recover the chip (for example with nrfjprog --recover or nRF Connect Programmer)? Are there any limitations when pin reset is not available on P19 pin 10?
  4. With SB47 open, and the target powered by its own battery while P19 pin 1 is connected to the target 3.3 V rail: is there any risk of current flowing back into the DK or any damage? Should I disconnect pin 1 (VTG) from the target rail in this case?
Thank you for your help.
Mario
