Dear Team,
I have been running two nRF54LM20-DK as Initiator and Reflector for Bluetooth Channel Sounding.
I adjusted the ranging algorithm RAS_Initiator to print Local and Remote IQ values, frequency, channel, rtt_counts and rtt_half_accumuluated_ns.
After which, I use UART with Python to read the data and print it to csv files. Later on, I use a Python based estimator to estimate the distances in a similar way of real time ranging. Moreover, I use an RF Antenna Chamber for placement of the boards, with almost precision with distance measurements.
What I have always observed is that there is a constant offset error which jumps more or less around 60 - 80 cm for each procedure that is estimated for PBR. Meanwhile RTT has an average error of around 3 times the ground truth distance.
Furthermore, I used a wired connection between both of the boards, which eliminated error offset error for PBR and somewhat reduced the RTT error to around 1.5 times of the ground truth distance.
So my conclusion is that most likely the offset error comes from the antenna group delay. However, RTT seems to have an additional hardware based delay (I cannot name it better) which needs additional calibration regardless if its a wired or wireless connection.
My question is:
Is it normal to have this offset between both of these boards in wireless connection?
Is there any explanation on the additional hardware delay for RTT?
I believe the clock drift and other calibration for ranging should be already done by mode-0 of Bluetooth Channel Sounding.
My configuration is:
Procedure: PHY 2M
CS Sync: PHY 2M
Procedures: 100 - 1000
Mode: 3
Mode 0 steps: 3
Subevents per procedure: 1
Channels used: 72 x 1 per procedure
Distances: 10cm to 170cm in RF Antenna Chamber
Thank you,
Rehan.
