nRF52840 - sd_ble_gattc_exchange_mtu_request() returned NRF_ERROR_INVALID_PARAM.
Hi All.
I have modified the ble_app_multilink_central project, and replaced the button service LBS with the NUS service. When I switch on my peripheral device (based on the ble_app_uart project), then I get the following errors;
<info> app: Multilink example started.
<info> app: Start scanning for device name SWTG1.
<info> app: Name is a match
<error> nrf_ble_gatt: sd_ble_gattc_exchange_mtu_request() returned NRF_ERROR_INVALID_PARAM.
<info> app: Connection 0x0 established, starting DB discovery.
<error> nrf_ble_gatt: sd_ble_gatts_exchange_mtu_reply() returned NRF_ERROR_INVALID_PARAM.
<info> app: NUS service discovered on conn_handle 0x0
<info> app: Connected to device with Nordic UART Service.
<error> app: ERROR 17 [NRF_ERROR_BUSY] at C:\Nordic_Semi\nRF5_SDK_15.0.0_a53641a\examples\ble_central\ble_app_multilink_central - Dock\main.c:205
PC at: 0x0002D60B
<error> app: End of error report
I have adjusted the ble connection parameters of both to match, and updated the NRF_SDH_BLE_GATT_MAX_MTU_SIZE  in the sdk_config (had to update the RAM start location after that update).
I have attached the main.c and config file. Is there anything obvious I have missed?
Thanks
 * Copyright (c) 2014 - 2018, Nordic Semiconductor ASA
 * All rights reserved.
 * @brief BLE LED Button Service central and client application main file.
 * This example can be a central for up to 8 peripherals.
 * The peripheral is called ble_app_blinky and can be found in the ble_peripheral
 * folder.
#include <stdint.h>
#include <stdio.h>
#include <string.h>
#include "nordic_common.h"
#include "nrf_sdh.h"
#include "nrf_sdh_ble.h"
#include "app_timer.h"
#include "bsp_btn_ble.h"
#include "ble.h"
#include "ble_hci.h"
#include "ble_advdata.h"
#include "ble_advertising.h"
#include "ble_conn_params.h"
#include "ble_db_discovery.h"
//#include "ble_lbs_c.h"
#include "ble_nus_c.h"
#include "ble_conn_state.h"
#include "nrf_ble_gatt.h"
#include "nrf_pwr_mgmt.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#define APP_BLE_CONN_CFG_TAG      1                                     /**< A tag that refers to the BLE stack configuration we set with @ref sd_ble_cfg_set. Default tag is @ref APP_BLE_CONN_CFG_TAG. */
#define APP_BLE_OBSERVER_PRIO     3                                     /**< Application's BLE observer priority. You shouldn't need to modify this value. */
#define UART_TX_BUF_SIZE          256                                     /**< UART TX buffer size. */
#define UART_RX_BUF_SIZE          256                                     /**< UART RX buffer size. */
#define CENTRAL_SCANNING_LED      BSP_BOARD_LED_0
#define CENTRAL_CONNECTED_LED     BSP_BOARD_LED_1
#define LEDBUTTON_LED             BSP_BOARD_LED_2                       /**< LED to indicate a change of state of the the Button characteristic on the peer. */
#define LEDBUTTON_BUTTON          BSP_BUTTON_0                          /**< Button that will write to the LED characteristic of the peer. */
#define BUTTON_DETECTION_DELAY    APP_TIMER_TICKS(50)                   /**< Delay from a GPIOTE event until a button is reported as pushed (in number of timer ticks). */
#define SCAN_INTERVAL             0x00A0                                /**< Determines scan interval in units of 0.625 millisecond. */
#define SCAN_WINDOW               0x0050                                /**< Determines scan window in units of 0.625 millisecond. */
#define SCAN_DURATION             0x0000                                /**< Duration of the scanning in units of 10 milliseconds. If set to 0x0000, scanning will continue until it is explicitly disabled. */
#define MIN_CONNECTION_INTERVAL   MSEC_TO_UNITS(20, UNIT_1_25_MS)      /**< Determines minimum connection interval in milliseconds. */
#define MAX_CONNECTION_INTERVAL   MSEC_TO_UNITS(100, UNIT_1_25_MS)       /**< Determines maximum connection interval in milliseconds. */
#define SLAVE_LATENCY             0                                     /**< Determines slave latency in terms of connection events. */
#define SUPERVISION_TIMEOUT       MSEC_TO_UNITS(4000, UNIT_10_MS)       /**< Determines supervision time-out in units of 10 milliseconds. */
uint16_t dataLength = 0;
uint16_t reportLength = 0;
uint8_t txPower = 0;
uint8_t rssi = 0;
uint8_t test2[];
uint32_t count = 0;
NRF_BLE_GATT_DEF(m_gatt);                                               /**< GATT module instance. */
BLE_NUS_C_ARRAY_DEF(m_nus_c, NRF_SDH_BLE_CENTRAL_LINK_COUNT);                                             /**< BLE NUS service client instance. */
//BLE_LBS_C_ARRAY_DEF(m_lbs_c, NRF_SDH_BLE_CENTRAL_LINK_COUNT);           /**< LED Button client instances. */
BLE_DB_DISCOVERY_ARRAY_DEF(m_db_disc, NRF_SDH_BLE_CENTRAL_LINK_COUNT);  /**< Database discovery module instances. */
static char const m_target_periph_name[] = "SWTG1";             /**< Name of the device we try to connect to. This name is searched for in the scan report data*/
static uint8_t m_scan_buffer_data[BLE_GAP_SCAN_BUFFER_MIN]; /**< buffer where advertising reports will be stored by the SoftDevice. */
static uint16_t m_ble_nus_max_data_len = BLE_GATT_ATT_MTU_DEFAULT - OPCODE_LENGTH - HANDLE_LENGTH; /**< Maximum length of data (in bytes) that can be transmitted to the peer by the Nordic UART service module. */
/**@brief Pointer to the buffer where advertising reports will be stored by the SoftDevice. */
static ble_data_t m_scan_buffer =
    m_scan_buffer_data,
/**@brief Scan parameters requested for scanning and connection. */
static ble_gap_scan_params_t const m_scan_params =
    .active   = 0,  //was 0
    .interval = SCAN_INTERVAL,
    .window   = SCAN_WINDOW,
    .timeout           = SCAN_DURATION,
    .scan_phys         = BLE_GAP_PHY_1MBPS,
    .filter_policy     = BLE_GAP_SCAN_FP_ACCEPT_ALL,
/**@brief Connection parameters requested for connection. */
static ble_gap_conn_params_t const m_connection_param =
    (uint16_t)MIN_CONNECTION_INTERVAL,
    (uint16_t)MAX_CONNECTION_INTERVAL,
    (uint16_t)SLAVE_LATENCY,
    (uint16_t)SUPERVISION_TIMEOUT
/**@brief Function to handle asserts in the SoftDevice.
 * @param[in] line_num     Line number of the failing ASSERT call.
 * @param[in] p_file_name  File name of the failing ASSERT call.
    app_error_handler(0xDEADBEEF, line_num, p_file_name);
/**@brief Function for the LEDs initialization.
 * @details Initializes all LEDs used by the application.
static void leds_init(void)
/**@brief Function to start scanning. */
static void scan_start(void)
    ret_code_t ret;
    (void) sd_ble_gap_scan_stop();
    NRF_LOG_INFO("Start scanning for device name %s.", (uint32_t)m_target_periph_name);
    ret = sd_ble_gap_scan_start(&m_scan_params, &m_scan_buffer);
    APP_ERROR_CHECK(ret);
    // Turn on the LED to signal scanning.
    bsp_board_led_on(CENTRAL_SCANNING_LED);
/**@brief Callback handling NUS Client events.
 * @details This function is called to notify the application of NUS client events.
 * @param[in]   p_ble_nus_c   NUS Client Handle. This identifies the NUS client
 * @param[in]   p_ble_nus_evt Pointer to the NUS Client event.
/**@snippet [Handling events from the ble_nus_c module] */
static void ble_nus_c_evt_handler(ble_nus_c_t * p_ble_nus_c, ble_nus_c_evt_t const * p_ble_nus_evt)
    ret_code_t err_code;
    switch (p_ble_nus_evt->evt_type)
        case BLE_NUS_C_EVT_DISCOVERY_COMPLETE:
            NRF_LOG_INFO("NUS service discovered on conn_handle 0x%x", p_ble_nus_evt->conn_handle);
            err_code = ble_nus_c_handles_assign(p_ble_nus_c, p_ble_nus_evt->conn_handle, &p_ble_nus_evt->handles);
            err_code = ble_nus_c_tx_notif_enable(p_ble_nus_c);
            NRF_LOG_INFO("Connected to device with Nordic UART Service.");
        case BLE_NUS_C_EVT_NUS_TX_EVT:
            //ble_nus_chars_received_uart_print(p_ble_nus_evt->p_data, p_ble_nus_evt->data_len);
            NRF_LOG_DEBUG("Receiving data.");
            NRF_LOG_HEXDUMP_DEBUG(p_ble_nus_evt->p_data, p_ble_nus_evt->data_len);
            //NRF_LOG_INFO("Data received : %X", p_ble_nus_evt->p_data);
//        case BLE_NUS_C_EVT_DISCONNECTED:
//            NRF_LOG_INFO("Disconnected.");
//            scan_start();
//            break;
/**@brief Function for handling the advertising report BLE event.
 * @param[in] p_adv_report  Advertising report from the SoftDevice.
static void on_adv_report(ble_gap_evt_adv_report_t const * p_adv_report)
//NRF_LOG_INFO("report rx'd");
    dataLength = p_adv_report->data.len;
    reportLength = sizeof(*p_adv_report);
    txPower = p_adv_report->tx_power;
    rssi = p_adv_report->rssi;
    //memcpy(test2, p_adv_report, sizeof(*p_adv_report));
    memcpy(test2, p_adv_report->data.p_data, p_adv_report->data.len);
    if (ble_advdata_name_find(p_adv_report->data.p_data,
                              p_adv_report->data.len,
                              m_target_periph_name))
        //Test code
        NRF_LOG_INFO("Name is a match");
        // Name is a match, initiate connection.
        err_code = sd_ble_gap_connect(&p_adv_report->peer_addr,
                                      &m_scan_params,
                                      &m_connection_param,
                                      APP_BLE_CONN_CFG_TAG);
        if (err_code != NRF_SUCCESS)
            NRF_LOG_ERROR("Connection Request Failed, reason %d", err_code);
        //NRF_LOG_INFO("Advertisment wasn't match to %s ", p_adv_report->data.p_data);// m_target_periph_name);
        err_code = sd_ble_gap_scan_start(NULL, &m_scan_buffer);
    // For readability.
    ble_gap_evt_t const * p_gap_evt = &p_ble_evt->evt.gap_evt;
        // Upon connection, check which peripheral has connected, initiate DB
        // discovery, update LEDs status and resume scanning if necessary.
        case BLE_GAP_EVT_CONNECTED:
            NRF_LOG_INFO("Connection 0x%x established, starting DB discovery.",
                         p_gap_evt->conn_handle);
            APP_ERROR_CHECK_BOOL(p_gap_evt->conn_handle < NRF_SDH_BLE_CENTRAL_LINK_COUNT);
           // err_code = ble_lbs_c_handles_assign(&m_lbs_c[p_gap_evt->conn_handle],
                                          //      p_gap_evt->conn_handle,
                                         //       NULL);
            err_code = ble_nus_c_handles_assign(&m_nus_c[p_gap_evt->conn_handle],
                                                NULL);
            err_code = ble_db_discovery_start(&m_db_disc[p_gap_evt->conn_handle],
            if (err_code != NRF_ERROR_BUSY)
            // Update LEDs status, and check if we should be looking for more
            // peripherals to connect to.
            bsp_board_led_on(CENTRAL_CONNECTED_LED);
            if (ble_conn_state_central_conn_count() == NRF_SDH_BLE_CENTRAL_LINK_COUNT)
                bsp_board_led_off(CENTRAL_SCANNING_LED);
                // Resume scanning.
                scan_start();
        } break; // BLE_GAP_EVT_CONNECTED
        // Upon disconnection, reset the connection handle of the peer which disconnected, update
        // the LEDs status and start scanning again.
            NRF_LOG_INFO("NUS central link 0x%x disconnected (reason: 0x%x)",
                         p_gap_evt->params.disconnected.reason);
            if (ble_conn_state_central_conn_count() == 0)
                err_code = app_button_disable();
                // Turn off connection indication LED
                bsp_board_led_off(CENTRAL_CONNECTED_LED);
            // Start scanning
            scan_start();
            // Turn on LED for indicating scanning
        } break;
        case BLE_GAP_EVT_ADV_REPORT:
            on_adv_report(&p_gap_evt->params.adv_report);
        case BLE_GAP_EVT_TIMEOUT:
            // We have not specified a timeout for scanning, so only connection attemps can timeout.
            if (p_gap_evt->params.timeout.src == BLE_GAP_TIMEOUT_SRC_CONN)
                NRF_LOG_DEBUG("Connection request timed out.");
        } break;
        case BLE_GAP_EVT_CONN_PARAM_UPDATE_REQUEST:
            NRF_LOG_DEBUG("BLE_GAP_EVT_CONN_PARAM_UPDATE_REQUEST.");
            // Accept parameters requested by peer.
            err_code = sd_ble_gap_conn_param_update(p_gap_evt->conn_handle,
                                        &p_gap_evt->params.conn_param_update_request.conn_params);
        } break;
            ble_gap_phys_t const phys =
                .rx_phys = BLE_GAP_PHY_AUTO,
                .tx_phys = BLE_GAP_PHY_AUTO,
        } break;
        case BLE_GATTC_EVT_TIMEOUT:
        } break;
        case BLE_GATTS_EVT_TIMEOUT:
        } break;
            // No implementation needed.
/**@brief Function for initializing the NUS Client. */
static void nus_c_init(void)
    ble_nus_c_init_t nus_c_init_obj;
    nus_c_init_obj.evt_handler = ble_nus_c_evt_handler;
    for (uint32_t i = 0; i < NRF_SDH_BLE_CENTRAL_LINK_COUNT; i++)
        err_code = ble_nus_c_init(&m_nus_c[i], &nus_c_init_obj);
 * @details Initializes the SoftDevice and the BLE event interrupts.
    uint32_t ram_start = 0;
    // Enable BLE stack.
/**@brief Function for handling events from the button handler module.
 * @param[in] pin_no        The pin that the event applies to.
 * @param[in] button_action The button action (press/release).
static void button_event_handler(uint8_t pin_no, uint8_t button_action)
    switch (pin_no)
        case LEDBUTTON_BUTTON:
            NRF_LOG_INFO("Button state %d", button_action);
            APP_ERROR_HANDLER(pin_no);
/**@brief Function for initializing the button handler module.
static void buttons_init(void)
   // The array must be static because a pointer to it will be saved in the button handler module.
    static app_button_cfg_t buttons[] =
        {LEDBUTTON_BUTTON, false, BUTTON_PULL, button_event_handler}
    err_code = app_button_init(buttons, ARRAY_SIZE(buttons), BUTTON_DETECTION_DELAY);
/**@brief Function for handling database discovery events.
 * @details This function is callback function to handle events from the database discovery module.
 *          Depending on the UUIDs that are discovered, this function should forward the events
 *          to their respective services.
 * @param[in] p_event  Pointer to the database discovery event.
static void db_disc_handler(ble_db_discovery_evt_t * p_evt)
    NRF_LOG_DEBUG("call to ble_nus_on_db_disc_evt for instance %d and link 0x%x!",
                  p_evt->conn_handle,
    ble_nus_c_on_db_disc_evt(&m_nus_c[p_evt->conn_handle], p_evt);
/** @brief Database discovery initialization.
static void db_discovery_init(void)
    ret_code_t err_code = ble_db_discovery_init(db_disc_handler);
 * @details Handle any pending log operation(s), then sleep until the next event occurs.
        nrf_pwr_mgmt_run();
/** @brief Function for initializing the log module.
static void log_init(void)
/** @brief Function for initializing the timer.
static void timer_init(void)
/**@brief Function for initializing the GATT module.
static void gatt_init(void)
    ret_code_t err_code = nrf_ble_gatt_init(&m_gatt, NULL);
    // Initialize.
    log_init();
    timer_init();
    leds_init();
    buttons_init();
    power_management_init();
    ble_stack_init();
    gatt_init();
    db_discovery_init();
 //   lbs_c_init();
    nus_c_init();
    ble_conn_state_init();
    // Start execution.
    NRF_LOG_INFO("Multilink example started.");
    scan_start();
    for (;;)
        idle_state_handle();
sdk_config.h
