<?xml-stylesheet type="text/xsl" href="https://devzone.nordicsemi.com/cfs-file/__key/system/syndication/rss.xsl" media="screen"?><rss version="2.0" xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:slash="http://purl.org/rss/1.0/modules/slash/" xmlns:wfw="http://wellformedweb.org/CommentAPI/" xmlns:atom="http://www.w3.org/2005/Atom"><channel><title>What is the dfference between using &amp;quot;nrf_ble_scan_filter_set + SCAN_ADDR_FILTER&amp;quot; and using a whitelist policy ?</title><link>https://devzone.nordicsemi.com/f/nordic-q-a/47839/what-is-the-dfference-between-using-nrf_ble_scan_filter_set-scan_addr_filter-and-using-a-whitelist-policy</link><description>Hello,
 I want that two devices can connect with each other and only each other . To do this i wanted to use whitelist on peripheral side but i found that i could use filtering on address and it seems to work fine. But what is the difference with the</description><dc:language>en-US</dc:language><generator>Telligent Community 13</generator><lastBuildDate>Fri, 31 May 2019 09:52:19 GMT</lastBuildDate><atom:link rel="self" type="application/rss+xml" href="https://devzone.nordicsemi.com/f/nordic-q-a/47839/what-is-the-dfference-between-using-nrf_ble_scan_filter_set-scan_addr_filter-and-using-a-whitelist-policy" /><item><title>RE: What is the dfference between using "nrf_ble_scan_filter_set + SCAN_ADDR_FILTER" and using a whitelist policy ?</title><link>https://devzone.nordicsemi.com/thread/190227?ContentTypeID=1</link><pubDate>Fri, 31 May 2019 09:52:19 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:41feadc2-4221-46be-81a0-547920c4c121</guid><dc:creator>Simon</dc:creator><description>&lt;p&gt;What do you mean by independent whitelist? Are you setting the whitelist manually? If you are, then you need an independent whitelist.&lt;/p&gt;
&lt;p&gt;E.g. if collector wants device2 in its whitelist it will need the irk and address of device2.&lt;/p&gt;
&lt;p&gt;Similarly, if device2 wants device1 in its whitelist it will need the irk and address of device1.&lt;/p&gt;
&lt;p&gt;&lt;/p&gt;
&lt;p&gt;What example are you using? In the SDK, a device will be added to the whitelist after bonding, and you don&amp;#39;t have to think about the address or irk since the Peer Manager has taken care of this and stored it into flash.&lt;/p&gt;
&lt;p&gt;&lt;/p&gt;
&lt;p&gt;Best regards,&lt;/p&gt;
&lt;p&gt;Simon&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: What is the dfference between using "nrf_ble_scan_filter_set + SCAN_ADDR_FILTER" and using a whitelist policy ?</title><link>https://devzone.nordicsemi.com/thread/189691?ContentTypeID=1</link><pubDate>Tue, 28 May 2019 15:17:03 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:6f73ffe8-3c16-4d54-9330-ebe303343112</guid><dc:creator>Aurele</dc:creator><description>&lt;p&gt;Hi Simon,&lt;/p&gt;
&lt;p&gt;Thank you very much for your link, indeed, it has been very helpful. So i guess whitelist are the solution for what&amp;nbsp; i want to implement. One more question&lt;/p&gt;
&lt;p&gt;&amp;nbsp;Here is what i want :&lt;/p&gt;
&lt;p&gt;&lt;/p&gt;
&lt;p&gt;&lt;img alt=" " src="https://devzone.nordicsemi.com/resized-image/__size/320x240/__key/communityserver-discussions-components-files/4/Dessin-sans-titre.jpg" /&gt;&lt;/p&gt;
&lt;p&gt;Link 1 between Device 1 and 2 cannot change.&lt;/p&gt;
&lt;p&gt;But, on device 2 side, can i use independant whitelist for (1) and for (2) ? or do i need to use the same whitelist for the two links.&lt;/p&gt;
&lt;p&gt;Regards,&lt;/p&gt;
&lt;p&gt;&lt;/p&gt;
&lt;p&gt;Aur&amp;eacute;lien&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: What is the dfference between using "nrf_ble_scan_filter_set + SCAN_ADDR_FILTER" and using a whitelist policy ?</title><link>https://devzone.nordicsemi.com/thread/189639?ContentTypeID=1</link><pubDate>Tue, 28 May 2019 12:38:57 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:05c00c3f-ab54-4583-b8e3-3317cb3e9420</guid><dc:creator>Simon</dc:creator><description>&lt;p&gt;I have elaborated earlier on the difference between scan filtering and whitelisting. Check out &lt;a href="https://devzone.nordicsemi.com/f/nordic-q-a/45034/scan-with-whitelist-vs-scan-filtering"&gt;this answer&lt;/a&gt;.&lt;/p&gt;
&lt;p&gt;Simon&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item></channel></rss>
