<?xml-stylesheet type="text/xsl" href="https://devzone.nordicsemi.com/cfs-file/__key/system/syndication/rss.xsl" media="screen"?><rss version="2.0" xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:slash="http://purl.org/rss/1.0/modules/slash/" xmlns:wfw="http://wellformedweb.org/CommentAPI/" xmlns:atom="http://www.w3.org/2005/Atom"><channel><title>zb_set_rx_on_when_idle(ZB_FALSE); returns a zb_nrf52840_abort error</title><link>https://devzone.nordicsemi.com/f/nordic-q-a/48774/zb_set_rx_on_when_idle-zb_false-returns-a-zb_nrf52840_abort-error</link><description>I am runing the light switch example in zigbee sdk v3.1. I am connecting to a smarthings hub. I have set the a single change on the code:
 The device will be connected and commisioned by the hub but the code will not get to the status == RET_OK /Joined</description><dc:language>en-US</dc:language><generator>Telligent Community 13</generator><lastBuildDate>Thu, 20 Jun 2019 13:24:16 GMT</lastBuildDate><atom:link rel="self" type="application/rss+xml" href="https://devzone.nordicsemi.com/f/nordic-q-a/48774/zb_set_rx_on_when_idle-zb_false-returns-a-zb_nrf52840_abort-error" /><item><title>RE: zb_set_rx_on_when_idle(ZB_FALSE); returns a zb_nrf52840_abort error</title><link>https://devzone.nordicsemi.com/thread/193899?ContentTypeID=1</link><pubDate>Thu, 20 Jun 2019 13:24:16 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:58cadfc5-99b1-4bd5-8323-d7c4e8d42ba5</guid><dc:creator>Marjeris Romero</dc:creator><description>&lt;p&gt;Hi,&lt;/p&gt;
&lt;p&gt;If you are unable to connect to a Zigbee network please check the following first:&lt;/p&gt;
&lt;p&gt;1. Check that your coordinator (Smarthings Hub) is on the same channel as your device (for example, use the &lt;a href="https://infocenter.nordicsemi.com/index.jsp?topic=%2Fsdk_tz_v3.1.0%2Fnrf802154_sniffer.html&amp;amp;cp=5_3_4_3_0"&gt;nRF Sniffer for 802.15.4&lt;/a&gt; to check which channel is used by the coordinator).&lt;/p&gt;
&lt;p&gt;2. Check that the Zigbee network is opened (Association permit in beacon packet is set to True, check with sniffer).&lt;/p&gt;
&lt;p&gt;3. Check if the coordinator replies to TC key rotation pakets (Request Key/Verify Key), also check again with sniffer.&lt;/p&gt;
&lt;p&gt;Best Regards,&lt;/p&gt;
&lt;p&gt;Marjeris&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item></channel></rss>
