<?xml-stylesheet type="text/xsl" href="https://devzone.nordicsemi.com/cfs-file/__key/system/syndication/rss.xsl" media="screen"?><rss version="2.0" xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:slash="http://purl.org/rss/1.0/modules/slash/" xmlns:wfw="http://wellformedweb.org/CommentAPI/" xmlns:atom="http://www.w3.org/2005/Atom"><channel><title>Can not receive event BLE_GAP_EVT_CONN_SEC_UPDATE after I called sd_ble_gap_sec_params_reply within event BLE_GAP_EVT_SEC_PARAMS_REQUEST.</title><link>https://devzone.nordicsemi.com/f/nordic-q-a/65567/can-not-receive-event-ble_gap_evt_conn_sec_update-after-i-called-sd_ble_gap_sec_params_reply-within-event-ble_gap_evt_sec_params_request</link><description>Current I used nRF52840 Dongle to develop a Bluetooth PC Tool base on nrf_ble_driver_obj_sd_api_v5 which shared on https://github.com/NordicSemiconductor/pc-ble-driver/blob/master/examples/heart_rate_collector/main.c
 Now I can&amp;#39;t receive event BLE_GAP_EVT_CONN_SEC_UPDATE</description><dc:language>en-US</dc:language><generator>Telligent Community 13</generator><lastBuildDate>Mon, 07 Sep 2020 06:48:15 GMT</lastBuildDate><atom:link rel="self" type="application/rss+xml" href="https://devzone.nordicsemi.com/f/nordic-q-a/65567/can-not-receive-event-ble_gap_evt_conn_sec_update-after-i-called-sd_ble_gap_sec_params_reply-within-event-ble_gap_evt_sec_params_request" /><item><title>RE: Can not receive event BLE_GAP_EVT_CONN_SEC_UPDATE after I called sd_ble_gap_sec_params_reply within event BLE_GAP_EVT_SEC_PARAMS_REQUEST.</title><link>https://devzone.nordicsemi.com/thread/268183?ContentTypeID=1</link><pubDate>Mon, 07 Sep 2020 06:48:15 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:ed675493-1206-46b7-89aa-2aed517cec3c</guid><dc:creator>Macl</dc:creator><description>&lt;p&gt;I have ajusted the order as you suggested. It works. I connect and pair successfully!&lt;/p&gt;
&lt;p&gt;Thank you!&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: Can not receive event BLE_GAP_EVT_CONN_SEC_UPDATE after I called sd_ble_gap_sec_params_reply within event BLE_GAP_EVT_SEC_PARAMS_REQUEST.</title><link>https://devzone.nordicsemi.com/thread/268176?ContentTypeID=1</link><pubDate>Mon, 07 Sep 2020 06:26:17 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:edbd8f55-7546-4ccc-ba7f-194ed4351a72</guid><dc:creator>Vidar Berg</dc:creator><description>&lt;p&gt;I see, so you are trying to iniate pairing from your device. I think maybe the reason it disconnects is that you&amp;#39;re calling on_pair() from the BLE_GAP_EVT_PHY_UPDATE event. Do you get the same disconnect reason (0x2A - BLE_HCI_DIFFERENT_TRANSACTION_COLLISION)&amp;nbsp; if you uncomment on_pair() from BLE_GAP_EVT_CONNECTED and remove the update_phy() request?&lt;/p&gt;
&lt;p&gt;Message sequence chart for reference:&lt;/p&gt;
&lt;p&gt;&lt;span&gt;&lt;a title="Pairing: Just Works" href="https://infocenter.nordicsemi.com/topic/com.nordic.infocenter.s132.api.v7.0.1/group___b_l_e___g_a_p___c_e_n_t_r_a_l___p_a_i_r_i_n_g___j_w___m_s_c.html?cp=4_7_3_1_2_1_5_5_2_3"&gt;Pairing: Just Works&lt;/a&gt;&lt;/span&gt;&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: Can not receive event BLE_GAP_EVT_CONN_SEC_UPDATE after I called sd_ble_gap_sec_params_reply within event BLE_GAP_EVT_SEC_PARAMS_REQUEST.</title><link>https://devzone.nordicsemi.com/thread/268170?ContentTypeID=1</link><pubDate>Mon, 07 Sep 2020 03:47:14 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:a94e6d5c-bc4b-47b4-8ce6-803ba6c99138</guid><dc:creator>Macl</dc:creator><description>&lt;p&gt;basically , the sequence is connect -- update_phy to 2M --- on_pair ---&amp;nbsp; event BLE_GAP_EVT_SEC_PARAMS_REQUEST --- Fail(disconnect) or Success(receive event BLE_GAP_EVT_CONN_SEC_UPDATE).&lt;/p&gt;
&lt;p&gt;Mine is disconnect&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: Can not receive event BLE_GAP_EVT_CONN_SEC_UPDATE after I called sd_ble_gap_sec_params_reply within event BLE_GAP_EVT_SEC_PARAMS_REQUEST.</title><link>https://devzone.nordicsemi.com/thread/268169?ContentTypeID=1</link><pubDate>Mon, 07 Sep 2020 03:40:49 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:bc2356b6-304f-472c-80ac-432266944ad0</guid><dc:creator>Macl</dc:creator><description>&lt;p&gt;I&amp;#39;m sorry. I didn&amp;#39;t say it clearly, I add connect, pair to it.&lt;/p&gt;
&lt;p&gt;&lt;pre class="ui-code" data-mode="c_cpp"&gt;err_code = sd_ble_gap_connect(m_adapter, &amp;amp;(p_ble_gap_evt-&amp;gt;params.adv_report.peer_addr),
                                      &amp;amp;m_scan_param, &amp;amp;m_connection_param
#if NRF_SD_BLE_API &amp;gt;= 5
            m_config_id // m_config_id //BLE_CONN_CFG_TAG_DEFAULT
                                          //can&amp;#39;t receive notice when it is set to be BLE_CONN_CFG_TAG_DEFAULT(0)
case BLE_GAP_EVT_CONNECTED:
        on_connected(&amp;amp;(p_ble_evt-&amp;gt;evt.gap_evt));
        /*on_pair(&amp;amp;(p_ble_evt-&amp;gt;evt.gap_evt));*/
        update_phy(&amp;amp;(p_ble_evt-&amp;gt;evt.gap_evt));
case BLE_GAP_EVT_PHY_UPDATE:
        on_phy_update(&amp;amp;(p_ble_evt-&amp;gt;evt.gap_evt));
static void on_pair(const ble_gap_evt_t *const p_ble_gap_evt)
    printf(&amp;quot;\non_pairing\n&amp;quot;);
    fflush(stdout);
    /*err_code = bsp_indication_set(BSP_INDICATE_CONNECTED);
    APP_ERROR_CHECK(err_code);*/
    uint16_t m_conn_handle = p_ble_gap_evt-&amp;gt;conn_handle;
    ble_gap_sec_params_t params;
    params.bond     = 0; // 1 to bond, 0 to pair?
    params.mitm     = 0;
    params.lesc     = 0;
    params.keypress = 0;
    params.io_caps =
        BLE_GAP_IO_CAPS_NONE; // BLE_GAP_IO_CAPS_NONE; //
                              // BLE_GAP_IO_CAPS_KEYBOARD_DISPLAY;BLE_GAP_IO_CAPS_KEYBOARD_ONLY
    params.oob             = 0;
    params.min_key_size    = 7;
    params.max_key_size    = 16;
    params.kdist_own.enc   = 1;
    params.kdist_own.id    = 1;
    params.kdist_own.link  = 0;
    params.kdist_own.sign  = 0;
    params.kdist_peer.enc  = 1;
    params.kdist_peer.id   = 1;
    params.kdist_peer.link = 0;
    params.kdist_peer.sign = 0;
    uint32_t nResult = -1;
    nResult          = sd_ble_gap_authenticate(m_adapter, m_conn_handle, &amp;amp;params);
    printf(&amp;quot;pair status is %d\n&amp;quot;, nResult);
}&lt;/pre&gt;&lt;/p&gt;
&lt;p&gt;I can receive event&amp;nbsp;BLE_GAP_EVT_SEC_PARAMS_REQUEST after on_pair(). But it will disconnect as I had said it before.&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: Can not receive event BLE_GAP_EVT_CONN_SEC_UPDATE after I called sd_ble_gap_sec_params_reply within event BLE_GAP_EVT_SEC_PARAMS_REQUEST.</title><link>https://devzone.nordicsemi.com/thread/268030?ContentTypeID=1</link><pubDate>Fri, 04 Sep 2020 11:18:31 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:9d82c2fe-1e00-4f1c-b5a5-d82242537230</guid><dc:creator>Vidar Berg</dc:creator><description>&lt;p&gt;Hi,&lt;/p&gt;
&lt;p&gt;Support for pairing and bonding is not implemented in the sample code. Unless this is required I would recommend you try responding with &amp;#39;BLE_GAP_SEC_STATUS_PAIRING_NOT_SUPP&amp;#39; to reject the request:&lt;/p&gt;
&lt;p style="padding-left:30px;"&gt;error_code1&amp;nbsp;=&amp;nbsp;sd_ble_gap_sec_params_reply(adapter,&amp;nbsp;p_ble_evt-&amp;gt;evt.common_evt.conn_handle,&lt;br /&gt;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp; BLE_GAP_SEC_STATUS_PAIRING_NOT_SUPP,&lt;br /&gt;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp; NULL,&amp;nbsp;NULL);&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: Can not receive event BLE_GAP_EVT_CONN_SEC_UPDATE after I called sd_ble_gap_sec_params_reply within event BLE_GAP_EVT_SEC_PARAMS_REQUEST.</title><link>https://devzone.nordicsemi.com/thread/267958?ContentTypeID=1</link><pubDate>Fri, 04 Sep 2020 07:11:35 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:aa91c08f-f6c7-472e-b929-2c9617516ded</guid><dc:creator>Macl</dc:creator><description>&lt;p&gt;It can receive event BLE_GAP_EVT_CONN_SEC_UPDATE if I change m_config_id from 1 to 0. But it can&amp;#39;t receive notification from BLE remote since then.&lt;/p&gt;
        );&lt;/pre&gt;&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item></channel></rss>
