I am working with Zephyr version 2.4 on nRF52840-Dongle for adding ability to scan CODED PHY devices. My host is Raspberry Pi3 with kernel version 5.4.51 v7+,
HCI_USB sample is used with following configuration:
CONFIG_STDOUT_CONSOLE=y
CONFIG_GPIO=y
CONFIG_SERIAL=y
CONFIG_BT=y
CONFIG_BT_H4=y
CONFIG_BT_CTLR=y
CONFIG_BT_HCI=y
CONFIG_USB=y
CONFIG_USB_DEVICE_STACK=y
CONFIG_USB_DEVICE_BLUETOOTH=y
CONFIG_USB_DEVICE_BLUETOOTH_VS_H4=y
CONFIG_MAIN_STACK_SIZE=1024
CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=1024
CONFIG_BT_CTLR_RX_BUFFERS=18
CONFIG_BT_CTLR_TX_BUFFERS=19
CONFIG_BT_CTLR_TX_BUFFER_SIZE=251
CONFIG_BT_CTLR_DATA_LENGTH_MAX=251
CONFIG_BT_HCI_CMD_COUNT=20
CONFIG_BT_RX_BUF_COUNT=20
CONFIG_BT_RX_BUF_LEN=258
CONFIG_BT_DISCARDABLE_BUF_SIZE=257
CONFIG_BT_MAX_CONN=24
CONFIG_BT_CTLR_PHY_CODED=y
CONFIG_BT_PHY_UPDATE=y
CONFIG_BT_AUTO_PHY_UPDATE=y
CONFIG_BT_LLL_VENDOR_NORDIC=y
CONFIG_BT_LL_SW_SPLIT=y
I trying to scan and connect a Coded PHY device, which is nRF52-PCA10056 board running the Long Range Demo (Nordic's Solution). I can not reach the board when board is advertising via CODED PHY but I can reach it when it advertising via 1M PHY.
Since automatic PHY update is activated, I tried to change it via hcitool, following command: hcitool cmd 08 31 03 04 04 and I got the following answer at btmon:
< HCI Command: LE Set Default PHY (0x08|0x0031) plen 3 #28 [hci0] 540.203681
All PHYs preference: 0x03
No TX PHY preference
No RX PHY preference
TX PHYs preference: 0x04
LE Coded
RX PHYs preference: 0x04
LE Coded
HCI Event: Command Complete (0x0e) plen 4 #29 [hci0] 540.205957
LE Set Default PHY (0x08|0x0031) ncmd 1
Status: Success (0x00)
But still, no Coded PHY device cannot scannable via my Zephyr USB HCI Bluetooth controller.
Any help will appreciated. Thanks in advance.
