Unable to work with nrf9160 using segger emstudio ide
Hi
i have installed segger emstudio and almost all dependencies but still can't able to build a project. my main target is to work with nrf9160 dk but without an hardware. Please guide me to set it up.
  • Hi again!
    From what I can see there are something wrong with your installation as you aren't seeing the corrects paths and options. I also find it a bit weird that gnuarmemb is your specified installation directory.
    Could you try to remove the installed NCS version again, then go to "Settings" in the Toolchain Manager app and change your installation directory to something like this "C:\nordic\ncs" before trying to install again?
    Also, when a build in SES fails you are able to see the build log by double clicking at the field in the image below:
    If any more errors happen, pleas provide that log to me.
    Carl Richard
  • Creating solution adc.emProject
    C:/gnuarmemb/v1.4.0/toolchain/opt/bin/cmake.exe -GNinja -DBOARD=nrf9160dk_nrf9160ns -DBOARD_DIR=C:\gnuarmemb\v1.3.2\zephyr\boards\arm\nrf9160dk_nrf9160 -BC:\Users\Win8\fw-nrfconnect-nrf\fw-nrfconnect-nrf\samples\nrf9160\adc\build_nrf9160dk_nrf9160ns -SC:\Users\Win8\fw-nrfconnect-nrf\fw-nrfconnect-nrf\samples\nrf9160\adc -DNCS_TOOLCHAIN_VERSION=1.4.0 -DEXTRA_KCONFIG_TARGETS=menuconfig_ses -DEXTRA_KCONFIG_TARGET_COMMAND_FOR_menuconfig_ses=C:\gnuarmemb\EmbeddedStudio_ARM_Nordic_v510d_win_x64\arm_segger_embedded_studio_v510d_win_x64_nordic/html/configure_nordic_project_menuconfig.py
    -- Application: C:/Users/Win8/fw-nrfconnect-nrf/fw-nrfconnect-nrf/samples/nrf9160/adc
    -- Zephyr version: 2.3.0-rc1 (C:/gnuarmemb/v1.3.2/zephyr)
    -- Found Python3: C:/gnuarmemb/v1.4.0/toolchain/opt/bin/python.exe (found suitable exact version "3.8.2") found components: Interpreter
    -- Board: nrf9160dk_nrf9160ns
    -- Found west: C:/gnuarmemb/v1.4.0/toolchain/opt/bin/Scripts/west.exe (found suitable version "0.7.2", minimum required is "0.7.1")
    -- Found dtc: C:/gnuarmemb/v1.4.0/toolchain/opt/bin/dtc.exe (found suitable version "1.4.7", minimum required is "1.4.6")
    -- Found toolchain: gnuarmemb (C:/gnuarmemb/v1.4.0/toolchain/opt)
    -- Found BOARD.dts: C:/gnuarmemb/v1.3.2/zephyr/boards/arm/nrf9160dk_nrf9160/nrf9160dk_nrf9160ns.dts
    -- Generated zephyr.dts: C:/Users/Win8/fw-nrfconnect-nrf/fw-nrfconnect-nrf/samples/nrf9160/adc/build_nrf9160dk_nrf9160ns/zephyr/zephyr.dts
    -- Generated devicetree_unfixed.h: C:/Users/Win8/fw-nrfconnect-nrf/fw-nrfconnect-nrf/samples/nrf9160/adc/build_nrf9160dk_nrf9160ns/zephyr/include/generated/devicetree_unfixed.h
    Parsing C:/gnuarmemb/v1.3.2/zephyr/Kconfig
    Loaded configuration 'C:/gnuarmemb/v1.3.2/zephyr/boards/arm/nrf9160dk_nrf9160/nrf9160dk_nrf9160ns_defconfig'
    Merged configuration 'C:/Users/Win8/fw-nrfconnect-nrf/fw-nrfconnect-nrf/samples/nrf9160/adc/prj.conf'
    -- Using NCS Toolchain 1.4.0 for building. (C:/gnuarmemb/v1.4.0/toolchain/cmake)
    error: NET_RAW_MODE (defined at subsys/net/ip/Kconfig:52) is assigned in a configuration file, but
    is not directly user-configurable (has no prompt). It gets its value indirectly from other symbols.
    See docs.zephyrproject.org/.../CONFIG_NET_RAW_MODE.html and/or look up
    NET_RAW_MODE in the menuconfig/guiconfig interface. The Application Development Primer, Setting
    Configuration Values, and Kconfig - Tips and Best Practices sections of the manual might be helpful
    too.
    CMake Error at C:/gnuarmemb/v1.3.2/zephyr/cmake/kconfig.cmake:217 (message):
    command failed with return code: 1
    C:/gnuarmemb/v1.3.2/zephyr/cmake/app/boilerplate.cmake:506 (include)
    CMakeLists.txt:9 (include)
    error: cmake failed
    create_nordic_project.py failed (1)
    this the error message i am getting during building a clone project.
  • Hi again!
    It seems like you are building for a board in version 1.3.2 of NCS. Could you try to specify the following board directory instead when opening your project:
    C:\gnuarmemb\v1.4.0\zephyr\boards\arm\nrf9160dk_nrf9160
    Carl Richard
