To be in scannable connectable mode
I am using nRF52832 with Temperature sensor using sdk 16 version . I have done buttonless OTAin ble_app_uart example by adding the dfu in it . I can able to update the firmware over the air using buttonless dfu , receiving the temperature data via ble_nus_send .Now I want to advertise my temperature data instead of receiving in the application .
1. Is it possible in my case (DFU+ BLE_APP_UART (should behave as a beacon)?
2)possible means what are the changes I need to do in ble_app_uart
Thanks and regards
Manikandan V
  • i am looking for the data to be advertised(temperatue data) i have hardcoded the temp data ,i need my value to be advertised like beacon
    static uint8_t mytemp[1]={90};
    manuf_specific_data.data.p_data = &mytemp;
    manuf_specific_data.data.size = 1;
    thanks and regards
    manikandan v
    I have taken your code snippet from your post Nov 21 and updated the code so that it updates a dummy temperature byte in manufacturer specific data every 5 seconds.This code works if you drop this main.c in the ble_app_uart folder in SDK 17. I hope that helps.
    #include <stdint.h>
    #include <string.h>
    #include "nordic_common.h"
    #include "nrf.h"
    #include "ble_hci.h"
    #include "ble_advdata.h"
    #include "ble_advertising.h"
    #include "ble_conn_params.h"
    #include "nrf_sdh.h"
    #include "nrf_sdh_soc.h"
    #include "nrf_sdh_ble.h"
    #include "nrf_ble_gatt.h"
    #include "nrf_ble_qwr.h"
    #include "app_timer.h"
    #include "ble_nus.h"
    #include "app_uart.h"
    #include "bsp_btn_ble.h"
    #include "nrf_pwr_mgmt.h"
    #if defined (UART_PRESENT)
    #include "nrf_uart.h"
    #if defined (UARTE_PRESENT)
    #include "nrf_uarte.h"
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    #define APP_BLE_CONN_CFG_TAG            1                                           /**< A tag identifying the SoftDevice BLE configuration. */
    #define DEVICE_NAME                     "Nordic_UART"                               /**< Name of device. Will be included in the advertising data. */
    #define NUS_SERVICE_UUID_TYPE           BLE_UUID_TYPE_VENDOR_BEGIN                  /**< UUID type for the Nordic UART Service (vendor specific). */
    #define APP_BLE_OBSERVER_PRIO           3                                           /**< Application's BLE observer priority. You shouldn't need to modify this value. */
    #define APP_ADV_INTERVAL                64                                          /**< The advertising interval (in units of 0.625 ms. This value corresponds to 40 ms). */
    #define APP_ADV_DURATION                18000                                       /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
    #define MIN_CONN_INTERVAL               MSEC_TO_UNITS(20, UNIT_1_25_MS)             /**< Minimum acceptable connection interval (20 ms), Connection interval uses 1.25 ms units. */
    #define MAX_CONN_INTERVAL               MSEC_TO_UNITS(75, UNIT_1_25_MS)             /**< Maximum acceptable connection interval (75 ms), Connection interval uses 1.25 ms units. */
    #define SLAVE_LATENCY                   0                                           /**< Slave latency. */
    #define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(4000, UNIT_10_MS)             /**< Connection supervisory timeout (4 seconds), Supervision Timeout uses 10 ms units. */
    #define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(5000)                       /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
    #define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(30000)                      /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
    #define MAX_CONN_PARAMS_UPDATE_COUNT    3                                           /**< Number of attempts before giving up the connection parameter negotiation. */
    #define DEAD_BEEF                       0xDEADBEEF                                  /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
    #define UART_TX_BUF_SIZE                256                                         /**< UART TX buffer size. */
    #define UART_RX_BUF_SIZE                256                                         /**< UART RX buffer size. */
    BLE_NUS_DEF(m_nus, NRF_SDH_BLE_TOTAL_LINK_COUNT);                                   /**< BLE NUS service instance. */
    NRF_BLE_GATT_DEF(m_gatt);                                                           /**< GATT module instance. */
    NRF_BLE_QWR_DEF(m_qwr);                                                             /**< Context for the Queued Write module.*/
    BLE_ADVERTISING_DEF(m_advertising);                                                 /**< Advertising module instance. */
    static uint16_t   m_conn_handle          = BLE_CONN_HANDLE_INVALID;                 /**< Handle of the current connection. */
    static uint16_t   m_ble_nus_max_data_len = BLE_GATT_ATT_MTU_DEFAULT - 3;            /**< Maximum length of data (in bytes) that can be transmitted to the peer by the Nordic UART service module. */
    static ble_uuid_t m_adv_uuids[]          =                                          /**< Universally unique service identifier. */
    // Added for advertising (fake) temperature data regularly -----
    #define COMPANY_IDENTIFIER              0x0059 // Nordic company ID.
    #define TEMP_UPDATE_INTERVAL            APP_TIMER_TICKS(5000) // 5 seconds temperature update interval
    static uint8_t m_temperature=0;
    static ble_advdata_manuf_data_t m_manuf_advdata;
    static ble_advdata_t m_advdata;
    static ble_advdata_t m_srdata;
    APP_TIMER_DEF(m_temperature_timer);
    /**@brief Function for assert macro callback.
     * @warning This handler is an example only and does not fit a final product. You need to analyse
     * @param[in] line_num    Line number of the failing ASSERT call.
     * @param[in] p_file_name File name of the failing ASSERT call.
    /**@brief Timeout handler for the temperature timer.
    static void temperature_timer_handler(void * p_context)
        m_temperature++; // Increment dummy temperature data
        NRF_LOG_INFO("Update advertising data with new temperature: %u", m_temperature);
        ret_code_t err_code = ble_advertising_advdata_update(&m_advertising, &m_advdata, &m_srdata);
    /**@brief Function for initializing the timer module.
    static void timers_init(void)
        // Temperature timer
        err_code = app_timer_create(&m_temperature_timer,
                                    APP_TIMER_MODE_REPEATED,
                                    temperature_timer_handler);
        err_code = app_timer_start(m_temperature_timer, APP_TIMER_TICKS(5000), NULL);
     *          the device. It also sets the permissions and appearance.
        uint32_t                err_code;
                                              strlen(DEVICE_NAME));
        APP_ERROR_HANDLER(nrf_error);
    /**@brief Function for handling the data from the Nordic UART Service.
     * @details This function will process the data received from the Nordic UART BLE Service and send
     *          it to the UART module.
     * @param[in] p_evt       Nordic UART Service event.
    /**@snippet [Handling the data received over BLE] */
            uint32_t err_code;
            for (uint32_t i = 0; i < p_evt->params.rx_data.length; i++)
                do
                    err_code = app_uart_put(p_evt->params.rx_data.p_data[i]);
                    if ((err_code != NRF_SUCCESS) && (err_code != NRF_ERROR_BUSY))
                        NRF_LOG_ERROR("Failed receiving NUS message. Error 0x%x. ", err_code);
                } while (err_code == NRF_ERROR_BUSY);
            if (p_evt->params.rx_data.p_data[p_evt->params.rx_data.length - 1] == '\r')
                while (app_uart_put('\n') == NRF_ERROR_BUSY);
        uint32_t           err_code;
        ble_nus_init_t     nus_init;
        // Initialize NUS.
    /**@brief Function for handling an event from the Connection Parameters Module.
     * @details This function will be called for all events in the Connection Parameters Module
     *          which are passed to the application.
     * @note All this function does is to disconnect. This could have been done by simply setting
     *       the disconnect_on_fail config parameter, but instead we use the event handler
     *       mechanism to demonstrate its use.
        uint32_t err_code;
    /**@brief Function for handling errors from the Connection Parameters module.
        // Prepare wakeup buttons.
        uint32_t err_code;
        switch (ble_adv_evt)
            case BLE_ADV_EVT_FAST:
            case BLE_ADV_EVT_IDLE:
                sleep_mode_enter();
        uint32_t err_code;
     int8_t rssi;
            case BLE_GAP_EVT_CONNECTED:
                NRF_LOG_INFO("Connected");
                uint32_t err_code;
    m_conn_handle  = p_ble_evt->evt.gap_evt.conn_handle;
    err_code = sd_ble_gap_rssi_start(m_conn_handle, 10, 0);
     case BLE_GAP_EVT_RSSI_CHANGED:
           rssi = p_ble_evt->evt.gap_evt.params.rssi_changed.rssi;
    NRF_LOG_INFO("rssi:%d",rssi);
                NRF_LOG_INFO("Disconnected");
                ble_gap_phys_t const phys =
                    .rx_phys = BLE_GAP_PHY_AUTO,
                    .tx_phys = BLE_GAP_PHY_AUTO,
            } break;
                // Pairing not supported
            case BLE_GATTC_EVT_TIMEOUT:
            case BLE_GATTS_EVT_TIMEOUT:
                // No implementation needed.
    /**@brief Function for the SoftDevice initialization.
     * @details This function initializes the SoftDevice and the BLE event interrupt.
        ret_code_t err_code;
        uint32_t ram_start = 0;
        // Enable BLE stack.
    /**@brief Function for handling events from the GATT library. */
    void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt)
        if ((m_conn_handle == p_evt->conn_handle) && (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED))
            m_ble_nus_max_data_len = p_evt->params.att_mtu_effective - OPCODE_LENGTH - HANDLE_LENGTH;
            NRF_LOG_INFO("Data len is set to 0x%X(%d)", m_ble_nus_max_data_len, m_ble_nus_max_data_len);
        NRF_LOG_DEBUG("ATT MTU exchange completed. central 0x%x peripheral 0x%x",
                      p_gatt->att_mtu_desired_central,
                      p_gatt->att_mtu_desired_periph);
    /**@brief Function for initializing the GATT library. */
    void gatt_init(void)
        err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
        err_code = nrf_ble_gatt_att_mtu_periph_set(&m_gatt, NRF_SDH_BLE_GATT_MAX_MTU_SIZE);
     * @param[in]   event   Event generated by button press.
        uint32_t err_code;
        switch (event)
            case BSP_EVENT_SLEEP:
                sleep_mode_enter();
            case BSP_EVENT_DISCONNECT:
                err_code = sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
            case BSP_EVENT_WHITELIST_OFF:
     *          a string. The string will be be sent over BLE when the last character received was a
     *          'new line' '\n' (hex 0x0A) or if the string has reached the maximum data length.
    /**@snippet [Handling the data received over UART] */
        static uint8_t index = 0;
        uint32_t       err_code;
        switch (p_event->evt_type)
            case APP_UART_DATA_READY:
                index++;
                if ((data_array[index - 1] == '\n') ||
                    (data_array[index - 1] == '\r') ||
                    (index >= m_ble_nus_max_data_len))
                    if (index > 1)
                        do
                        } while (err_code == NRF_ERROR_RESOURCES);
                    index = 0;
            case APP_UART_FIFO_ERROR:
    /**@brief  Function for initializing the UART module.
    /**@snippet [UART Initialization] */
    static void uart_init(void)
            .rx_pin_no    = RX_PIN_NUMBER,
            .tx_pin_no    = TX_PIN_NUMBER,
            .use_parity   = false,
            .baud_rate    = NRF_UART_BAUDRATE_115200
    #else
            .baud_rate    = NRF_UARTE_BAUDRATE_115200
                           UART_RX_BUF_SIZE,
                           UART_TX_BUF_SIZE,
                           uart_event_handle,
                           APP_IRQ_PRIORITY_LOWEST,
                           err_code);
    /**@brief Function for handling advertising errors.
    static void ble_advertising_error_handler(uint32_t nrf_error)
        uint8_t                adv_flags;
        ble_advertising_init_t init;
        m_manuf_advdata.company_identifier = COMPANY_IDENTIFIER;
        m_manuf_advdata.data.p_data = &m_temperature;
        m_manuf_advdata.data.size   = 1;
        // Advertising data
        adv_flags                           = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
        init.advdata.name_type              = BLE_ADVDATA_FULL_NAME;
        init.advdata.include_appearance     = true;
        init.advdata.flags                  = adv_flags;
        init.advdata.p_manuf_specific_data  = &m_manuf_advdata;
        // Scan response data
        init.srdata.uuids_complete.p_uuids  = m_adv_uuids;
        // Copy Adv data and SR data to static buffers to be used when data is to be updated
        memcpy(&m_advdata, &init.advdata, sizeof(m_advdata));
        memcpy(&m_srdata, &init.srdata, sizeof(m_srdata));
        // Configure advertising parameters and advertising module
        init.config.ble_adv_directed_high_duty_enabled = false;
        init.config.ble_adv_directed_enabled           = false;
        init.config.ble_adv_directed_interval          = 0;
        init.config.ble_adv_directed_timeout           = 0;
        init.error_handler = ble_advertising_error_handler;
        bsp_event_t startup_event;
        uint32_t err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
    static void log_init(void)
            nrf_pwr_mgmt_run();
    /**@brief Application main function.
        bool erase_bonds;
        // Initialize.
        uart_init();
        log_init();
        timers_init();
        power_management_init();
        ble_stack_init();
        gap_params_init();
        gatt_init();
        services_init();
        advertising_init();
        conn_params_init();
        // Start execution.
        advertising_start();
        // Enter main loop.
        for (;;)
            idle_state_handle();
  • thanks i have tired the above code its working fine now i want to do the same thing with rtc instead of using apptimer but my data is not updating regularly. can you check my code
    #define CAL_RTC NRF_RTC2
    #define CAL_RTC_IRQn RTC2_IRQn
    #define CAL_RTC_IRQHandler RTC2_IRQHandler
    #define CAL_RTC_IRQ_Priority 3
    void nrf_cal_init(void)
    // Select the 32 kHz crystal and start the 32 kHz clock
    NRF_CLOCK->LFCLKSRC = CLOCK_LFCLKSRC_SRC_Xtal << CLOCK_LFCLKSRC_SRC_Pos;
    NRF_CLOCK->TASKS_LFCLKSTART = 1;
    while(NRF_CLOCK->EVENTS_LFCLKSTARTED == 0);
    // Configure the RTC for 1 minute wakeup (default)
    CAL_RTC->PRESCALER = 0;
    CAL_RTC->EVTENSET = RTC_EVTENSET_COMPARE0_Msk;
    CAL_RTC->INTENSET = RTC_INTENSET_COMPARE0_Msk;
    CAL_RTC->CC[0] = m_rtc_increment *32768;
    CAL_RTC->TASKS_START = 1;
    NVIC_SetPriority(CAL_RTC_IRQn, CAL_RTC_IRQ_Priority);
    NVIC_EnableIRQ(CAL_RTC_IRQn);
    void nrf_cal_set_callback(void (*callback)(void), uint32_t interval)
    // Set the calendar callback, and set the callback interval in seconds
    cal_event_callback = callback;
    m_rtc_increment = interval;
    m_time += CAL_RTC->COUNTER / 32768;
    CAL_RTC->TASKS_CLEAR = 1;
    CAL_RTC->CC[0] = interval * 32768;
    void CAL_RTC_IRQHandler(void)
    if(CAL_RTC->EVENTS_COMPARE[0])
    CAL_RTC->EVENTS_COMPARE[0] = 0;
    m_time += m_rtc_increment;
    if(cal_event_callback) cal_event_callback();
    int main()
    while(NRF_CLOCK->EVENTS_HFCLKSTARTED == 0);
    nrf_cal_init();
    nrf_cal_set_callback(temperature_timer_handler, 4);
    thanks and regards
    manikandan v
    Why do you want to use the RTC directly instead of via the app_timer? The app_timer is essentially just a user friendly low power timer library that is uses the RTC underneath and lets you create an arbitrary number of timers based on a single RTC instance.
    Regarding your code I so not see any obvious mistakes directly related to the RTC when looking at it, but I may be overlooking something and the code is incomplete, so cannot see everything you have done. Can you share a complete piece of code that I can build and run?
  • i have uploaded the whole file kingly check and get back to me. I want to do the whole thing with rtc  instead of app_timer
    5773.my_file.rar
    thanks and regards
    manikandan v
