hardfault about the saadc channel init
I meet a hard fault handler issue when initialize the saadc channel. The code is as followed.
#define SAADC_SAMPLES_IN_BUFFER 2
int16_t touchs[2];
nrf_saadc_channel_config_t channel[2]; //saadc channel
nrf_drv_saadc_config_t saadc_config = NRFX_SAADC_DEFAULT_CONFIG;  //saadc
static nrf_saadc_value_t buffer[2][SAADC_SAMPLES_IN_BUFFER];  //buffer for saadc
        nrf_drv_saadc_buffer_convert(p_event->data.done.p_buffer, SAADC_SAMPLES_IN_BUFFER);
        for (int i = 0; i < SAADC_SAMPLES_IN_BUFFER; i++)
            touchs[i] = p_event->data.done.p_buffer[i];
void saadc_init()
    nrf_drv_saadc_init(&saadc_config, saadc_callback); //initial the saadc with the callback function
    saadc_config.resolution = NRF_SAADC_RESOLUTION_12BIT; //res = 12?
    channel[0].pin_p = yp;  //channel 0 yp
    nrf_drv_saadc_channel_init(0, &channel[0]);
    channel[1].pin_p = xp;   //channel 1 xp
    nrf_drv_saadc_channel_init(1, &channel[1]);
    nrf_drv_saadc_buffer_convert(buffer[0], SAADC_SAMPLES_IN_BUFFER); //read sample from saadc to buffer?
    nrf_drv_saadc_buffer_convert(buffer[1], SAADC_SAMPLES_IN_BUFFER);
When I set the breakpoint at line 22, the debugging process can work well, but when I move the breakpoint to line 24, the debugging process will jump to hard fault handler. Do you think my configuration of the saadc channel is wrong?
Thanks in advance for your help,
Leo
  • Thanks for your reply. I extract the saadc part from my project. The terminal output and the register setting are the same as the pictures before. It should print three sample values in the terminal. Please have a try.
    Thanks a lot.
    #include <stdio.h>
    #include <stdlib.h>
    #include <sys/time.h>
    #include <stdbool.h>
    #include <stdint.h>
    #include <ble_gap.h>
    #include "nrf.h"
    #include "nrf_delay.h"
    #include "app_timer.h"
    #include "app_error.h"
    #include "nrf_log.h"
    #include "boards.h"
    #include "pca10056.h"
    #include "nrf_gpio.h"
    #include "nrf_drv_timer.h"
    #include "nrfx_gpiote.h"
    #include "nrf_drv_gpiote.h"
    #include "nrf_drv_ppi.h"
    #include "nrf_drv_rtc.h"
    #include "nrf_drv_clock.h"
    #include "nrf_drv_lpcomp.h"
    #include "nrf_drv_saadc.h"
    #include "nrf_drv_twi.h"
    #include "nrf_libuarte_async.h"
    #include "app_pwm.h"
    #define SAADC_SAMPLES_IN_BUFFER 3
    nrf_saadc_channel_config_t channel[3]; //saadc channel
    nrf_drv_saadc_config_t saadc_config;  //saadc
    int adcData[3];
    /*saadc data read*/
            ret_code_t err_code;
            err_code = nrf_drv_saadc_buffer_convert(p_event->data.done.p_buffer, SAADC_SAMPLES_IN_BUFFER);
                adcData[i] = p_event->data.done.p_buffer[i];
    void saadc_init()
        saadc_config.resolution = 2; //res = 12?
        channel[0].reference = NRF_SAADC_REFERENCE_VDD4; //reference vvd
        channel[0].gain = NRF_SAADC_GAIN1_4; //gain 1/4
        channel[0].acq_time = NRF_SAADC_ACQTIME_3US; //tacq=3
        channel[0].pin_p = 31; //D31? positive pin?
        channel[1].reference = NRF_SAADC_REFERENCE_INTERNAL; //refvvd false
        channel[1].gain = NRF_SAADC_GAIN1_6;
        channel[1].acq_time = NRF_SAADC_ACQTIME_3US;
        channel[1].pin_p = 28;
        channel[2].reference = NRF_SAADC_REFERENCE_VDD4;
        channel[2].gain = NRF_SAADC_GAIN1_6;
        channel[2].acq_time = NRF_SAADC_ACQTIME_3US;
        channel[2].pin_p = 30;
        nrf_drv_saadc_channel_init(2, &channel[2]);
    void updateADC()
            for(int i=0; i<3; i++)
                nrf_drv_saadc_sample();
                printf("%d \n", i);
        printf("hello\n");
        saadc_init();
        updateADC();
        printf("%d, %d, %d \n", adcData[0], adcData[1], adcData[2]);
  • I'll try to set it up on my end.
    Have you disabled ASSERTs for that project? What SDK are you using for these two projects?
    All instances of the nrf_drv_saadc_channel_init in the nRF5 SDK 12.3 and upwards contain the following check:
    ASSERT((p_config->pin_p <= NRF_SAADC_INPUT_VDD) &&(p_config->pin_p > NRF_SAADC_INPUT_DISABLED));
    Where NRF_SAADC_INPUT_VDD = 0x9 and NRF_SAADC_INPUT_DISABLED = 0x0.
