<?xml-stylesheet type="text/xsl" href="https://devzone.nordicsemi.com/cfs-file/__key/system/syndication/rss.xsl" media="screen"?><rss version="2.0" xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:slash="http://purl.org/rss/1.0/modules/slash/" xmlns:wfw="http://wellformedweb.org/CommentAPI/" xmlns:atom="http://www.w3.org/2005/Atom"><channel><title>nRF52840 &amp;quot;ERROR: failed to initialize sniffer&amp;quot; / PROP_VALUE_SET [tid=1]: MAC_FILTER_MODE</title><link>https://devzone.nordicsemi.com/f/nordic-q-a/75696/nrf52840-error-failed-to-initialize-sniffer-prop_value_set-tid-1-mac_filter_mode</link><description>Hi, I have flashed the nRF52840 dongle on macos (11.4) and ubuntu (20.04.20) using nRF Connect for Desktop (3.61) following the guide ( https://infocenter.nordicsemi.com/index.jsp?topic=%2Fug_sniffer_ble%2FUG%2Fsniffer_ble%2Fintro.html ). Using pyspinel</description><dc:language>en-US</dc:language><generator>Telligent Community 13</generator><lastBuildDate>Fri, 28 May 2021 14:42:19 GMT</lastBuildDate><atom:link rel="self" type="application/rss+xml" href="https://devzone.nordicsemi.com/f/nordic-q-a/75696/nrf52840-error-failed-to-initialize-sniffer-prop_value_set-tid-1-mac_filter_mode" /><item><title>RE: nRF52840 "ERROR: failed to initialize sniffer" / PROP_VALUE_SET [tid=1]: MAC_FILTER_MODE</title><link>https://devzone.nordicsemi.com/thread/312427?ContentTypeID=1</link><pubDate>Fri, 28 May 2021 14:42:19 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:c3bf4cae-2bbe-4b28-ada8-e1f8830aaa5b</guid><dc:creator>Charlie</dc:creator><description>&lt;p&gt;Hi nmonkee,&lt;/p&gt;
&lt;p&gt;I repeat this process, everything seems fine. Here is my setup:&lt;/p&gt;
&lt;h2&gt;1. Build latest NCP for nRF52840 dongle(v1.2.0).&lt;/h2&gt;
&lt;p&gt;Setup build envrionment following&amp;nbsp;&lt;a href="https://github.com/openthread/ot-nrf528xx/blob/main/src/nrf52840/README.md"&gt;ot-nrf528xx/README.md at main · openthread/ot-nrf528xx (github.com)&lt;/a&gt;&amp;nbsp;and build with following commands:&lt;/p&gt;
&lt;p&gt;&lt;pre class="ui-code" data-mode="text"&gt;/script/build nrf52840 USB_trans -DOT_BOOTLOADER=USB
arm-none-eabi-objcopy -O ihex build/bin/ot-ncp-ftd ot-ncp-ftd.hex&lt;/pre&gt;&lt;/p&gt;
&lt;p&gt;I get the hex file:&amp;nbsp;&lt;a href="https://devzone.nordicsemi.com/cfs-file/__key/communityserver-discussions-components-files/4/1004.ot_2D00_ncp_2D00_ftd.hex"&gt;devzone.nordicsemi.com/.../1004.ot_2D00_ncp_2D00_ftd.hex&lt;/a&gt;&lt;/p&gt;
&lt;h2&gt;2. Programming&amp;nbsp;&lt;a href="https://infocenter.nordicsemi.com/index.jsp?topic=%2Fug_nc_programmer%2FUG%2Fnrf_connect_programmer%2Fncp_programming_dongle.html"&gt;nRF52840 Dongle&lt;/a&gt;&amp;nbsp;through USB bootloader.&lt;/h2&gt;
&lt;h2&gt;3. Run the sniffer.py&lt;/h2&gt;
&lt;p&gt;I am not sure if you tested with the same NCP firmware. Please test my hex file and also check your nRF52840 version. The document mentioned that it only tested PCA10059 1.0.0.&lt;/p&gt;
&lt;p&gt;Best regards,&lt;/p&gt;
&lt;p&gt;Charlie&lt;/p&gt;
&lt;p&gt;&lt;/p&gt;
&lt;p&gt;&amp;nbsp;&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item></channel></rss>
