For our application, we need to form a Zigbee distributed network and not a Zigbee centralized network. That means that routers need to be able to form a new network or join an existing one and that we will not have a Trust Center nor a coordinator in our network. Is this compatible with nRF Connect SDK v1.5.1? If yes, is there any example or documentation available on that subject? When I looked at the SDK it does not seem to be compatible yet. For example, I can see the following lines in zigbee_app_utils.c:
case ZB_BDB_SIGNAL_FORMATION: /* At this point the Zigbee stack has finished network formation * procedure. The device may have created a new Zigbee network, * which is indicated by signal's status code. * * Next step: * - If the device implements Zigbee coordinator * and the formation is not successful, try to form a new * Zigbee network by performing network formation after * 1 second (see BDB specification section 8.4). * - If the network formation was successful, open the newly * created network for other devices to join by starting * network steering for a node on a network, * (see BDB specification section 8.2). * - If the device implements Zigbee router or end device, * this signal is not expected. */
If this is not available yet, is it planned?
Thank you in advance,
Clement
