Can't correctly restore data stored with FDS
I am using FDS to store three int32_t numbers.
Here is my code for storing :
static void store(void)
    int32_t value_A = get_value_A();
    int32_t value_B = get_value_B();
    int32_t value_C = get_value_C();
    int32_t values[3] = { value_A, value_B, value_C };
    NRF_LOG_INFO("Size %d", sizeof(values)/sizeof(int32_t));
    fds_record_t record;
    record.file_id           = FILE_ID;
    record.key               = RECORD_KEY;
    record.data.p_data       = values;
    record.data.length_words = 3;
    ret_code_t err_code;
    err_code = fds_record_write(&record_desc, &record);
    NRF_LOG_INFO("Stored value A %d", value_A);
    NRF_LOG_INFO("Stored value B %d", value_B);
    NRF_LOG_INFO("Stored value C %d", value_C);
    read_values();
Here is my code for reading :
static bool read_values(void)
    memset(&ftok, 0x00, sizeof(fds_find_token_t));
    fds_flash_record_t flash_record;
    fds_record_desc_t record_desc;
    while (fds_record_find(FILE_ID, RECORD_KEY, &record_desc, &ftok) == NRF_SUCCESS)
        if (fds_record_open(&record_desc, &flash_record) != NRF_SUCCESS)
            return false;
        const int32_t* values = flash_record.p_data;
        int32_t value_A = values[0];
        NRF_LOG_INFO("Read value_A %d", value_A);
        int32_t value_B = values[1];
        NRF_LOG_INFO("Read value_C %d", value_B);
        int32_t value_C = values[2];
        NRF_LOG_INFO("Read value_C %d", value_C);
        if (fds_record_close(&record_desc) != NRF_SUCCESS)
            /* Handle error. */
            return false;
        return true;
Here are the logs (stored values are the correct ones) :
<info> app: Size 3
<info> app: Stored value A -11810
<info> app: Stored value B -5737
<info> app: Stored value C 200
<info> app: Read value A 536882505
<info> app: Read value B 72429
<info> app: Read value C 100360
What am I missing ? This *looks* like a uint <-> int conversion issue, but I never store nor read as uint ...
Thanks! Best regards
