<?xml-stylesheet type="text/xsl" href="https://devzone.nordicsemi.com/cfs-file/__key/system/syndication/rss.xsl" media="screen"?><rss version="2.0" xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:slash="http://purl.org/rss/1.0/modules/slash/" xmlns:wfw="http://wellformedweb.org/CommentAPI/" xmlns:atom="http://www.w3.org/2005/Atom"><channel><title>NRF52833 SAADC incorrectly measures NRF_SAADC_INPUT_VDD channel when supply voltage is set below 3.0v</title><link>https://devzone.nordicsemi.com/f/nordic-q-a/83924/nrf52833-saadc-incorrectly-measures-nrf_saadc_input_vdd-channel-when-supply-voltage-is-set-below-3-0v</link><description>Hello,
 While developing the device, I found that the SAADC module on the NRF52833 incorrectly measures the voltage on the NRF_SAADC_INPUT_VDD channel if you set the REGOUT0 register to a value other than UICR_REGOUT0_VOUT_3V0 or UICR_REGOUT0_VOUT_3V3</description><dc:language>en-US</dc:language><generator>Telligent Community 13</generator><lastBuildDate>Wed, 26 Jan 2022 12:30:27 GMT</lastBuildDate><atom:link rel="self" type="application/rss+xml" href="https://devzone.nordicsemi.com/f/nordic-q-a/83924/nrf52833-saadc-incorrectly-measures-nrf_saadc_input_vdd-channel-when-supply-voltage-is-set-below-3-0v" /><item><title>RE: NRF52833 SAADC incorrectly measures NRF_SAADC_INPUT_VDD channel when supply voltage is set below 3.0v</title><link>https://devzone.nordicsemi.com/thread/349754?ContentTypeID=1</link><pubDate>Wed, 26 Jan 2022 12:30:27 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:44cecc4e-6f6f-454a-9577-b2d2ece5b2df</guid><dc:creator>haakonsh</dc:creator><description>&lt;p&gt;No&amp;nbsp;apologies needed, mistakes are part of the job&amp;nbsp;&amp;nbsp;:)&amp;nbsp;&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: NRF52833 SAADC incorrectly measures NRF_SAADC_INPUT_VDD channel when supply voltage is set below 3.0v</title><link>https://devzone.nordicsemi.com/thread/349597?ContentTypeID=1</link><pubDate>Tue, 25 Jan 2022 15:08:19 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:acd43ee1-7be1-46ff-ad2d-a038cdae7cea</guid><dc:creator>2gav</dc:creator><description>&lt;p&gt;Okay, I checked everything myself. I apologize, it was my mistake. A voltage higher than 3.8v is applied to one pin of the processor. Obviously this leads to problems related to the internal reference voltage of the ADC.&lt;/p&gt;
&lt;p&gt;Since I checked the operation of the UICR register at the same time, I can say that setting the voltage through the REGOUT0 register works perfectly.&lt;/p&gt;
&lt;p&gt;Thank you very much and once again I apologize for my mistake.&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: NRF52833 SAADC incorrectly measures NRF_SAADC_INPUT_VDD channel when supply voltage is set below 3.0v</title><link>https://devzone.nordicsemi.com/thread/349548?ContentTypeID=1</link><pubDate>Tue, 25 Jan 2022 13:26:38 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:039e8652-0d87-4bbf-a00e-8cb04a7f74b8</guid><dc:creator>haakonsh</dc:creator><description>&lt;p&gt;I&amp;#39;ve yet to replicate the problem, but I did think of something that we need to verify, and that is the actual voltage on the VDD rail. Do you have a multimeter that you can check VDD in the different settings in UICR?&lt;br /&gt;&lt;br /&gt;I ask because I think it&amp;#39;s more likely an issue with the VDD rail than the SAADC.&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: NRF52833 SAADC incorrectly measures NRF_SAADC_INPUT_VDD channel when supply voltage is set below 3.0v</title><link>https://devzone.nordicsemi.com/thread/349412?ContentTypeID=1</link><pubDate>Tue, 25 Jan 2022 06:03:52 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:1854ff64-b94f-48a1-a1e5-398e55c63735</guid><dc:creator>2gav</dc:creator><description>&lt;p&gt;Of course, only I cannot do it qualitatively for 2.1v. Only up to 2.4v.&lt;/p&gt;
&lt;p&gt;This is for 3.0v:&lt;/p&gt;
&lt;p&gt;&lt;pre class="ui-code" data-mode="text"&gt;&amp;lt;info&amp;gt; app: VDD: 3000 mv; ADC RESOLUTION: 10 bits
&amp;lt;info&amp;gt; app: SAADC HAL simple example started.
&amp;lt;info&amp;gt; app: ADC event number: 0
&amp;lt;info&amp;gt; app: ADC=860 (3023 mV)
&amp;lt;info&amp;gt; app: ADC=861 (3027 mV)
&amp;lt;info&amp;gt; app: ADC=859 (3020 mV)
&amp;lt;info&amp;gt; app: ADC=857 (3013 mV)
&amp;lt;info&amp;gt; app: ADC event number: 1
&amp;lt;info&amp;gt; app: ADC=858 (3016 mV)
&amp;lt;info&amp;gt; app: ADC event number: 2
&amp;lt;info&amp;gt; app: ADC event number: 3
&amp;lt;info&amp;gt; app: ADC event number: 4
&amp;lt;info&amp;gt; app: ADC=857 (3013 mV)&lt;/pre&gt;&lt;/p&gt;
&lt;p&gt;&lt;span&gt;This is for 2.7v:&lt;/span&gt;&lt;/p&gt;
&lt;p&gt;&lt;span&gt;&lt;pre class="ui-code" data-mode="text"&gt;&amp;lt;info&amp;gt; app: VDD: 2700 mv; ADC RESOLUTION: 10 bits
&amp;lt;info&amp;gt; app: ADC=562 (1976 mV)
&amp;lt;info&amp;gt; app: ADC=565 (1986 mV)
&amp;lt;info&amp;gt; app: ADC=564 (1983 mV)
&amp;lt;info&amp;gt; app: ADC=563 (1979 mV)
&amp;lt;info&amp;gt; app: ADC=565 (1986 mV)&lt;/pre&gt;&lt;/span&gt;&lt;/p&gt;
&lt;p&gt;&lt;span&gt;This is for 2.4v:&lt;/span&gt;&lt;/p&gt;
&lt;p&gt;&lt;span&gt;&lt;pre class="ui-code" data-mode="text"&gt;&amp;lt;info&amp;gt; app: VDD: 2400 mv; ADC RESOLUTION: 10 bits
&amp;lt;info&amp;gt; app: ADC=516 (1814 mV)
&amp;lt;info&amp;gt; app: ADC=517 (1818 mV)
&amp;lt;info&amp;gt; app: ADC=515 (1811 mV)
&amp;lt;info&amp;gt; app: ADC=514 (1807 mV)
&amp;lt;info&amp;gt; app: ADC=516 (1814 mV)&lt;/pre&gt;&lt;/span&gt;&lt;/p&gt;
&lt;p&gt;&lt;span&gt;If my data is not confirmed with you, then this is very good. So the problem is somewhere in my device. And I apologize in advance for the panic.&lt;/span&gt;&lt;/p&gt;
&lt;p&gt;&lt;span&gt;Thank you, very very much.&lt;/span&gt;&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: NRF52833 SAADC incorrectly measures NRF_SAADC_INPUT_VDD channel when supply voltage is set below 3.0v</title><link>https://devzone.nordicsemi.com/thread/349309?ContentTypeID=1</link><pubDate>Mon, 24 Jan 2022 14:42:12 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:8589e818-74db-4009-90ac-ab4465b8596b</guid><dc:creator>haakonsh</dc:creator><description>&lt;p&gt;I&amp;#39;ll try to replicated the issue on my end.&amp;nbsp;&lt;br /&gt;&lt;br /&gt;Can you share a couple of ADC values at&amp;nbsp;UICR_REGOUT0_VOUT_3V0 and&amp;nbsp;UICR_REGOUT0_VOUT_2V1 ?&amp;nbsp;&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item></channel></rss>
