softdevice - How to print UART message / what is SOFTDEVICE_PRESENT and where it is defined in Segger
I am using nRF52840 DK board and nRF5SDK17.0.2.
I am trying to code to print data on UART so I have added below folder path into user include directories:
../../../config
../../../../../../components
../../../../../../components/boards
../../../../../../components/drivers_nrf/nrf_soc_nosd
../../../../../../components/libraries/atomic
../../../../../../components/libraries/balloc
../../../../../../components/libraries/bsp
../../../../../../components/libraries/delay
../../../../../../components/libraries/experimental_section_vars
../../../../../../components/libraries/fifo
../../../../../../components/libraries/log
../../../../../../components/libraries/log/src
../../../../../../components/libraries/memobj
../../../../../../components/libraries/ringbuf
../../../../../../components/libraries/strerror
../../../../../../components/libraries/uart
../../../../../../components/libraries/util
../../../../../../components/toolchain/cmsis/include
../../../../../../external/fprintf
../../../../../../integration/nrfx
../../../../../../integration/nrfx/legacy
../../../../../../modules/nrfx
../../../../../../modules/nrfx/drivers/include
../../../../../../modules/nrfx/hal
../../../../../../modules/nrfx/mdk
../config
0508.sdk_config.h
uploaded sdk_config.h file for your reference.
Also, I have added the required file to the project but still, I am getting the error below.
Compiling 'nrf_log_frontend.c'
sdk_common.h
nrf_log_frontend.c
nrf_mbr.h: No such file or directory
What is SOFTDEVICE_PRESENT and where it is defined in SEGGER?
 * Copyright (c) 2014 - 2020, Nordic Semiconductor ASA
 * All rights reserved.
/** @file
 * @defgroup uart_example_main main.c
 * @ingroup uart_example
 * @brief UART Example Application main file.
 * This file contains the source code for a sample application using UART.
#include <stdbool.h>
#include <stdint.h>
#include <stdio.h>
#include "app_uart.h"
#include "app_error.h"
#include "nrf_delay.h"
#include "nrf.h"
#include "bsp.h"
#if defined (UART_PRESENT)
#include "nrf_uart.h"
#if defined (UARTE_PRESENT)
#include "nrf_uarte.h"
//#define ENABLE_LOOPBACK_TEST  /**< if defined, then this example will be a loopback test, which means that TX should be connected to RX to get data loopback. */
#define MAX_TEST_DATA_BYTES     (15U)                /**< max number of test bytes to be used for tx and rx. */
#define UART_TX_BUF_SIZE 256                         /**< UART TX buffer size. */
#define UART_RX_BUF_SIZE 256                         /**< UART RX buffer size. */
void uart_error_handle(app_uart_evt_t * p_event)
    if (p_event->evt_type == APP_UART_COMMUNICATION_ERROR)
    else if (p_event->evt_type == APP_UART_FIFO_ERROR)
#ifdef ENABLE_LOOPBACK_TEST
/* Use flow control in loopback test. */
#define UART_HWFC APP_UART_FLOW_CONTROL_ENABLED
/** @brief Function for setting the @ref ERROR_PIN high, and then enter an infinite loop.
static void show_error(void)
    bsp_board_leds_on();
    while (true)
        // Do nothing.
/** @brief Function for testing UART loop back.
 *  @details Transmitts one character at a time to check if the data received from the loopback is same as the transmitted data.
 *  @note  @ref TX_PIN_NUMBER must be connected to @ref RX_PIN_NUMBER)
static void uart_loopback_test()
    uint8_t * tx_data = (uint8_t *)("\r\nLOOPBACK_TEST\r\n");
    uint8_t   rx_data;
    // Start sending one byte and see if you get the same
    for (uint32_t i = 0; i < MAX_TEST_DATA_BYTES; i++)
        uint32_t err_code;
        while (app_uart_put(tx_data[i]) != NRF_SUCCESS);
        nrf_delay_ms(10);
        err_code = app_uart_get(&rx_data);
        if ((rx_data != tx_data[i]) || (err_code != NRF_SUCCESS))
            show_error();
    return;
#else
/* When UART is used for communication with the host do not use flow control.*/
#define UART_HWFC APP_UART_FLOW_CONTROL_DISABLED
    uint32_t err_code;
    const app_uart_comm_params_t comm_params =
          RX_PIN_NUMBER,
          TX_PIN_NUMBER,
          RTS_PIN_NUMBER,
          CTS_PIN_NUMBER,
          UART_HWFC,
          false,
          NRF_UART_BAUDRATE_115200
#else
          NRF_UARTE_BAUDRATE_115200
                         UART_RX_BUF_SIZE,
                         UART_TX_BUF_SIZE,
                         uart_error_handle,
                         APP_IRQ_PRIORITY_LOWEST,
                         err_code);
#ifndef ENABLE_LOOPBACK_TEST
    printf("\r\nUART example started.\r\n");
    while (true)
        uint8_t cr;
        while (app_uart_get(&cr) != NRF_SUCCESS);
        while (app_uart_put(cr) != NRF_SUCCESS);
        if (cr == 'q' || cr == 'Q')
            printf(" \r\nExit!\r\n");
            while (true)
                // Do nothing.
#else
    // This part of the example is just for testing the loopback .
    while (true)
        uart_loopback_test();
I am attaching my screenshot for your reference.
What I am doing wrong? Please help.
Please find the attached code file.
Thanks and regards,
Neeraj Dhekale
    Did you upload the correct project? The project that you shared is basically the UART peripheral example, but it lacks the necessary drivers and libraries which result in build errors. Can you double check it? Also, are you using the MBR or blank project?
    regards
    Jared
  • Hello Jared,
    There is no build error at my end. I just made a zip to my working folder. Is it the correct way to export?
    Please correct me if I am wrong.
    Thanks and regards,
    Neeraj Dhekale
    I wanted to reproduce "the error" at my side by using your project. Your project didn't build successfully because there was a lot of source files and drivers that weren't included. I therefore asked if you uploaded the correct project since it built successfully on your side. Are you using the MBR or the blank project? It's PCA10056 folder right? And you are using SES?
    regards
    Jared
  • Hi Jared,
    Sorry for the late reply.
    Here is the screenshot of the building successful at my end.
    For you, I have collapsed all folders at left project explorer.
    Attaching a Screenshot of the User include directories.
    Also attaching a screenshot of Preprocessor definition
    Also, I am attaching again same project by making a working project folder as ZIP
    3073.blinky.zip
    I am using S132
    No. Its PCA10040 folder
    Yes. Correct.
    Now you might cross-check at your end. Is this information sufficient to make this project build successful at your end? Or do you need anything extra information? let me know.
    Thanks and regards,
    Neeraj Dhekale
    The PCA10040 is not the correct folder for the nRF52840 DK, it doesn't map the pins correctly nor does it adjust the memory settings correctly for the nRF52840. You should use PCA10056. Still not sure why this would result in serial data being printed out on the Debug terminal. Either way, could you see if you're able to reproduce it using the correct folder.
    regards
    Jared
