Softdevice - The increasing size of advertisement causes crop in advertisement name
I am using nRF 52840 DK board and using nRF52SDK17.0.2. I am trying to advertise data in GAP with the name "IG_Last4CharMAC_RFL" for example "IG_4DA8_RFL" but whenever I increase below obj.data.size =2; to obj.data.size =12; it is getting increased, but advertise name is getting a crop and looks like "IG_". I have tried to find an advertising buffer in sdk_config.h file but I did not find anything related to it. What shall I do to avoid this issue?
 ret_code_t             err_code;
 ble_advertising_init_t init;
ble_advdata_service_data_t obj;
obj.service_uuid = BLE_UUID_TX_POWER_SERVICE;
obj.data.p_data = sensorData;
obj.data.size =12;
    init.advdata.name_type               = BLE_ADVDATA_FULL_NAME;
    init.advdata.include_appearance      = false;
    init.advdata.flags                   = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE; //displayed in raw as type 0x01
    init.advdata.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
    init.advdata.uuids_complete.p_uuids  = m_adv_uuids;
  // init.advdata.p_manuf_specific_data = 0xFF;
init.advdata.p_tx_power_level = &BT_TX_POWER;
    init.advdata.p_service_data_array =&obj;
    init.advdata.service_data_count=1;
      //init.config.ble_adv_primary_phy      = BLE_GAP_PHY_1MBPS;
    //init.config.ble_adv_secondary_phy    = BLE_GAP_PHY_2MBPS;
    //init.config.ble_adv_extended_enabled = true;
    //init.config.ble_adv_directed_high_duty_enabled  = true;
    init.config.ble_adv_fast_enabled  = true;
    init.config.ble_adv_fast_interval = BT_GAP_INT_MAX;
    init.config.ble_adv_slow_interval = BT_GAP_INT_MIN;
    init.config.ble_adv_fast_timeout  = APP_ADV_DURATION;
    init.config.ble_adv_slow_timeout  = APP_ADV_DURATION;
   // init.evt_handler = on_adv_evt;
  //  APP_ERROR_CHECK(err_code);
     NRF_LOG_INFO("ble_advertising_init %d",err_code);
  sd_ble_gap_tx_power_set(BLE_GAP_TX_POWER_ROLE_ADV, m_advertising.adv_handle, BT_TX_POWER);
    NRF_LOG_INFO("advertising_init done.");
I am attaching my sdk_config.h file. Please have a look and let me know or is there an alternate solution to this?
6622.sdk_config.h
Please help. Thanks in advance.
Thanks and regards,
Neeraj Dhekale
  • Hello Karl Ylvisaker,
    Thanks for confirming. I have tried to implement scan response by checking int ble_app_uart. And now 1st  7 characters are getting displayed for example "IG_4D25" still 3 more characters are yet to be displayed.
    My updated advertising_init() function is below:
    void advertising_init(void)
    uint32_t err;
    obj.data.p_data = loadcellData;
    obj.data.size =12;
       // init.advdata.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
       // init.advdata.uuids_complete.p_uuids  = m_adv_uuids;
        init.srdata.uuids_complete.p_uuids  = m_adv_uuids;
    Thanks and regards,
    Neeraj Dhekale
  • Hello again,
    Then the advertising packet is still too big to fit within the 31 byte limit.
    Currently you have flags (3 bytes), tx power (3 bytes), service data (16 bytes) and 2 bytes overhead for the name datafield. This leaves 7 bytes that you can use for the device name.
    How many bytes of the scan response packet are you using? Perhaps you could move the device name into the scan response as well, if there is more room left there. Alternatively you could try to move TX power to the scan response, to free up 3 additional bytes in the advertising data payload.
    Karl
    I moved my GAP service data (which was in advdata in the above example) to scan response and then it works. Now it is getting displayed full name as mentioned above.
    Here is updated advertising_init() function.
    uint32_t err;
    obj.data.size =12;
        init.srdata.p_tx_power_level = &BT_TX_POWER;
        init.srdata.p_service_data_array =&obj;
        init.srdata.service_data_count=1;
    Please check and correct me if I am wrong or the way I did.
    Thanks and Regards,
    Neeraj
  • Hello Neeraj,
    Now you have moved both the UUID list and the service data into the scan response, which are the two big datafields in your advertising. Keep in mind that I do not know the size of the UUID data, but since the SoftDevice would complain if it did not fit into the scan response then I would think that this is all right!
    At least I do not see any issue in the code snippet you have provided.
    I would recommend that you clean up the code a little, and remove all commented lines to increase readability and maintainability.
    Are you not going to be using an advertising event handler in your application?
    Karl
    Corrected. Moved UUID to advdata and kept service data into the scan response.
    Okay, Noted.
    Corrected and thanks for this. I will keep it in mind.
    Currently Not needed. Maybe I will use it in the future.
    Thanks and regards,
    Neeraj Dhekale
