<?xml-stylesheet type="text/xsl" href="https://devzone.nordicsemi.com/cfs-file/__key/system/syndication/rss.xsl" media="screen"?><rss version="2.0" xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:slash="http://purl.org/rss/1.0/modules/slash/" xmlns:wfw="http://wellformedweb.org/CommentAPI/" xmlns:atom="http://www.w3.org/2005/Atom"><channel><title>Question about CLI Connection Issue</title><link>https://devzone.nordicsemi.com/f/nordic-q-a/88220/question-about-cli-connection-issue</link><description>Dear Support Team,
 I&amp;#39;m trying to test 802.15.4 feature with the precompiled radio_test hex file, but got an error when connecting the CLI through PuTTY. Below is the detail.
 Purpose : I would like to test basic function of 15.4, like send an Tx</description><dc:language>en-US</dc:language><generator>Telligent Community 13</generator><lastBuildDate>Wed, 25 May 2022 21:18:20 GMT</lastBuildDate><atom:link rel="self" type="application/rss+xml" href="https://devzone.nordicsemi.com/f/nordic-q-a/88220/question-about-cli-connection-issue" /><item><title>RE: Question about CLI Connection Issue</title><link>https://devzone.nordicsemi.com/thread/369622?ContentTypeID=1</link><pubDate>Wed, 25 May 2022 21:18:20 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:ca2be1ef-ab51-4f06-b72c-af3dc4d8b221</guid><dc:creator>cindy66666</dc:creator><description>&lt;p&gt;Hi Marte,&lt;/p&gt;
&lt;p&gt;After pressing reset I was able to see the text and communicate with the board. I guess previously the board was somehow not responding.&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: Question about CLI Connection Issue</title><link>https://devzone.nordicsemi.com/thread/369456?ContentTypeID=1</link><pubDate>Wed, 25 May 2022 08:40:43 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:e4e89ab5-6f75-4c48-b0a6-4a11d8d0d407</guid><dc:creator>Marte Myrvold</dc:creator><description>&lt;p&gt;Hi,&lt;/p&gt;
&lt;p&gt;The settings&amp;nbsp;seem&amp;nbsp;correct. In the guide the settings for local echo and local line editing are auto instead of force on, but it should still work.&lt;/p&gt;
[quote user="cindy66666"]Also should I expect something like board connected successfully?[/quote]
&lt;p&gt;Not from PuTTY, no. You will get an error if you are trying to connect to a COM port that is not in use, but by looking at your picture the connection has been&amp;nbsp;opened correctly. The radio test example should print the text &amp;quot;Radio test example started&amp;quot; at the beginning though. You can try&amp;nbsp;pressing the reset button on your DK after you have established the connection in PuTTY and see if it prints when it starts up.&lt;/p&gt;
&lt;p&gt;You also mentioned that you are unsure which COM port is correct, since both COM4 and COM8 shows up. One thing you can do to find&amp;nbsp;this is to run the command&amp;nbsp;&lt;strong&gt;nrfjprog --com&lt;/strong&gt;. This will show connected JLink debuggers and their associated serial ports. The debugger will show up as the serial number of your DK.&lt;/p&gt;
&lt;p&gt;Best regards,&lt;/p&gt;
&lt;p&gt;Marte&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: Question about CLI Connection Issue</title><link>https://devzone.nordicsemi.com/thread/369363?ContentTypeID=1</link><pubDate>Tue, 24 May 2022 17:22:50 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:709c63e0-ef0b-43a5-9c4c-e6a816a5e036</guid><dc:creator>cindy66666</dc:creator><description>&lt;p&gt;Hi Marte,&lt;/p&gt;
&lt;p&gt;Thanks a lot for your instruction. Now I can connect without any error. While I cannot get any return when typing CLI commands. Also should I expect something like board connected successfully?&lt;/p&gt;
&lt;p&gt;&lt;img src="https://devzone.nordicsemi.com/resized-image/__size/320x240/__key/communityserver-discussions-components-files/4/pastedimage1653412724740v2.png" alt=" " /&gt;&lt;/p&gt;
&lt;p&gt;Below are my setting details. The rest pages are using default settings but let me know if you need those info.&lt;/p&gt;
&lt;p&gt;&lt;img src="https://devzone.nordicsemi.com/resized-image/__size/320x240/__key/communityserver-discussions-components-files/4/pastedimage1653412846391v3.png" alt=" " /&gt;&lt;img src="https://devzone.nordicsemi.com/resized-image/__size/320x240/__key/communityserver-discussions-components-files/4/pastedimage1653412902714v5.png" alt=" " /&gt;&lt;img src="https://devzone.nordicsemi.com/resized-image/__size/320x240/__key/communityserver-discussions-components-files/4/pastedimage1653412870529v4.png" alt=" " /&gt;&lt;/p&gt;
&lt;p&gt;Do you have any suggestion? Looking forward to your reply!&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: Question about CLI Connection Issue</title><link>https://devzone.nordicsemi.com/thread/369246?ContentTypeID=1</link><pubDate>Tue, 24 May 2022 11:13:57 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:479c284e-208e-46f8-9867-7e2b942b1217</guid><dc:creator>Marte Myrvold</dc:creator><description>&lt;p&gt;Hi,&lt;/p&gt;
&lt;p&gt;From your first and last pictures it looks like your are trying to connect via RTT instead of UART. In the &amp;#39;Session&amp;#39; settings in PuTTY you should select &amp;#39;Serial&amp;#39;, and not &amp;#39;Telnet&amp;#39;, and then add COM port and the baud rate there:&lt;/p&gt;
&lt;p&gt;&lt;img alt=" " src="https://devzone.nordicsemi.com/resized-image/__size/500x400/__key/communityserver-discussions-components-files/4/pastedimage1653390697579v1.png" /&gt;&lt;/p&gt;
&lt;p&gt;Marte&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item></channel></rss>
