<?xml-stylesheet type="text/xsl" href="https://devzone.nordicsemi.com/cfs-file/__key/system/syndication/rss.xsl" media="screen"?><rss version="2.0" xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:slash="http://purl.org/rss/1.0/modules/slash/" xmlns:wfw="http://wellformedweb.org/CommentAPI/" xmlns:atom="http://www.w3.org/2005/Atom"><channel><title>Optimizing LWM2M sample to use PSM</title><link>https://devzone.nordicsemi.com/f/nordic-q-a/88256/optimizing-lwm2m-sample-to-use-psm</link><description>I need help extending the LWM2M sample to use PSM to optimize the power consumption of LWM2M.
 Scenario:
 1. Enable PSM on the LWM2M sample.
 2. Set the Lifetime of the LWM2M connection to slightly longer than the PSM sleep cycle
 3. Trigger the LWM2M</description><dc:language>en-US</dc:language><generator>Telligent Community 13</generator><lastBuildDate>Mon, 30 May 2022 09:06:28 GMT</lastBuildDate><atom:link rel="self" type="application/rss+xml" href="https://devzone.nordicsemi.com/f/nordic-q-a/88256/optimizing-lwm2m-sample-to-use-psm" /><item><title>RE: Optimizing LWM2M sample to use PSM</title><link>https://devzone.nordicsemi.com/thread/369921?ContentTypeID=1</link><pubDate>Mon, 30 May 2022 09:06:28 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:7c3f98bc-b989-4fb2-94bd-b6693d1b9827</guid><dc:creator>Charlie</dc:creator><description>&lt;p&gt;Hi Jim,&lt;/p&gt;
&lt;p&gt;I am a bit confused about your comments.&lt;/p&gt;
&lt;p&gt;If you are talking about&amp;nbsp;&lt;a href="https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/nrf/applications/asset_tracker_v2/README.html"&gt;nRF9160: Asset Tracker v2 — nRF Connect SDK 1.9.99 documentation (nordicsemi.com)&lt;/a&gt;&amp;nbsp;features, your request seems already been satisfied.&lt;/p&gt;
&lt;p&gt;1) The device sends all data from the requested data list in one JSON file.&amp;nbsp;&lt;span&gt;&amp;nbsp;Data is also batched to reduce the number of messages transmitted and to be able to retain collected data while the device is offline.&lt;/span&gt;&lt;/p&gt;
&lt;p&gt;2) The device has two modes Active and Passive to sample data at different rates. You can modify the codes to switch between them according to your expected moving state threshold.&lt;/p&gt;
&lt;p&gt;If you are talking about&amp;nbsp;the LwM2M v1.1 standard, this is already fixed, and&amp;nbsp;you may need to contact the &lt;a href="https://omaspecworks.org/"&gt;OMA SpecWorks – For a Connected World&lt;/a&gt;.&amp;nbsp;The features you mentioned are also more application-level features instead of the LwM2M protocol.&lt;/p&gt;
&lt;p&gt;Best regards,&lt;/p&gt;
&lt;p&gt;Charlie&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: Optimizing LWM2M sample to use PSM</title><link>https://devzone.nordicsemi.com/thread/369572?ContentTypeID=1</link><pubDate>Wed, 25 May 2022 14:14:08 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:122db658-0d16-4ace-9da9-a886a1f1ef15</guid><dc:creator>JimWert</dc:creator><description>&lt;p&gt;Thank you, I am happy to test any early versions you may have, especially the 1.1 content.&lt;/p&gt;
&lt;p&gt;&lt;/p&gt;
&lt;p&gt;Features I would like to see in the 1.1 implementation:&lt;/p&gt;
&lt;p&gt;1. Use &amp;quot;send&amp;quot; to send a composite notification with sensor values in a single packet without the need for an observe.&lt;/p&gt;
&lt;p&gt;2. idle/active behavior so if the device is not moving it sends data at a slower rate than if it is moving.&lt;/p&gt;
&lt;p&gt;Thanks,&lt;/p&gt;
&lt;p&gt;Jim&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: Optimizing LWM2M sample to use PSM</title><link>https://devzone.nordicsemi.com/thread/369554?ContentTypeID=1</link><pubDate>Wed, 25 May 2022 13:30:57 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:06986206-0f6f-4953-bb68-120c2a0bad0b</guid><dc:creator>Charlie</dc:creator><description>&lt;p&gt;Hi James,&lt;/p&gt;
&lt;p&gt;The current&amp;nbsp;&lt;a href="https://developer.nordicsemi.com/nRF_Connect_SDK/doc/1.9.1/nrf/samples/nrf9160/lwm2m_client/README.html"&gt;nRF9160: LwM2M Client — nRF Connect SDK 1.9.1 documentation (nordicsemi.com)&lt;/a&gt;&amp;nbsp;sample does not support LWM2m object 10, but I think you can easily add your own implementation by referring to other objects.&lt;/p&gt;
&lt;p&gt;I also want to share some good news with you. We are going to add&amp;nbsp;LwM2M&amp;nbsp;v1.1 support on&lt;a href="https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/nrf/applications/asset_tracker_v2/doc/asset_tracker_v2_description.html"&gt; the Assert Tracker v2 application&lt;/a&gt; in the coming NCS 2.0.0 release. I think it would be a great reference for your development. Happy work!&lt;/p&gt;
&lt;p&gt;Charlie&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item></channel></rss>
