<?xml-stylesheet type="text/xsl" href="https://devzone.nordicsemi.com/cfs-file/__key/system/syndication/rss.xsl" media="screen"?><rss version="2.0" xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:slash="http://purl.org/rss/1.0/modules/slash/" xmlns:wfw="http://wellformedweb.org/CommentAPI/" xmlns:atom="http://www.w3.org/2005/Atom"><channel><title>Is it possible to change the APP startup address in MBR</title><link>https://devzone.nordicsemi.com/f/nordic-q-a/88395/is-it-possible-to-change-the-app-startup-address-in-mbr</link><description>Hi，
 Due to customer demand, the 52810 chip must be used during development. At present, there are too few flash resources in the application layer, and the starting address of the application layer is 0x23000. There is actually a space of 0x3000 from</description><dc:language>en-US</dc:language><generator>Telligent Community 13</generator><lastBuildDate>Mon, 30 May 2022 11:47:25 GMT</lastBuildDate><atom:link rel="self" type="application/rss+xml" href="https://devzone.nordicsemi.com/f/nordic-q-a/88395/is-it-possible-to-change-the-app-startup-address-in-mbr" /><item><title>RE: Is it possible to change the APP startup address in MBR</title><link>https://devzone.nordicsemi.com/thread/369968?ContentTypeID=1</link><pubDate>Mon, 30 May 2022 11:47:25 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:df24e8f6-6376-4624-9d77-9e4bdbc81b02</guid><dc:creator>Amanda Hsieh</dc:creator><description>&lt;p&gt;Hi,&amp;nbsp;&lt;/p&gt;
&lt;p&gt;You can take a look the release notes under&amp;nbsp;nRF5_SDK_14.1.0\components\softdevice\s132\doc. The&amp;nbsp;&lt;span&gt;S132 v5.1.0 requires Flash: 140 kB (0x23000 bytes), so the flash address should be stat from&amp;nbsp;0x23000.&amp;nbsp;&lt;/span&gt;&lt;/p&gt;
&lt;p&gt;&lt;span&gt;-Amanda&lt;/span&gt;&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: Is it possible to change the APP startup address in MBR</title><link>https://devzone.nordicsemi.com/thread/369918?ContentTypeID=1</link><pubDate>Mon, 30 May 2022 09:03:34 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:8be21481-214e-4744-9815-7b65ba9ca400</guid><dc:creator>jimmy</dc:creator><description>&lt;p&gt;Hi，&lt;/p&gt;
&lt;p&gt;I am using the S132 v5.1.0 soft device, the content of the link description does not seem to be explained.&lt;/p&gt;
&lt;p&gt;RAM has been adjusted to an appropriate size. Everything works fine when booting with flash address 0x23000. Due to insufficient flash resources, I would like to know if the FLASH startup address can be adjusted.&lt;/p&gt;
&lt;p&gt;&lt;span&gt;Regards,&lt;/span&gt;&lt;/p&gt;
&lt;p&gt;&lt;span&gt;Jimmy&lt;/span&gt;&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: Is it possible to change the APP startup address in MBR</title><link>https://devzone.nordicsemi.com/thread/369889?ContentTypeID=1</link><pubDate>Mon, 30 May 2022 07:45:23 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:ca283d77-f4c8-4be0-ad94-2e6df80f1fab</guid><dc:creator>Amanda Hsieh</dc:creator><description>&lt;p&gt;Hi,&amp;nbsp;&lt;/p&gt;
&lt;p&gt;What SD version are you using? Take a look at the&amp;nbsp;&lt;a href="https://devzone.nordicsemi.com/guides/short-range-guides/b/getting-started/posts/adjustment-of-ram-and-flash-memory"&gt;Adjustment of RAM and Flash memory&lt;/a&gt;&amp;nbsp;&lt;/p&gt;
&lt;p&gt;You should modify the &lt;span&gt;starting address according to the debug log indication.&amp;nbsp;&lt;/span&gt;&lt;/p&gt;
&lt;p&gt;&lt;span&gt;Regards,&lt;br /&gt;Amanda&lt;/span&gt;&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item></channel></rss>
