<?xml-stylesheet type="text/xsl" href="https://devzone.nordicsemi.com/cfs-file/__key/system/syndication/rss.xsl" media="screen"?><rss version="2.0" xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:slash="http://purl.org/rss/1.0/modules/slash/" xmlns:wfw="http://wellformedweb.org/CommentAPI/" xmlns:atom="http://www.w3.org/2005/Atom"><channel><title>External flash DFU over BLE ( SPI )</title><link>https://devzone.nordicsemi.com/f/nordic-q-a/88413/external-flash-dfu-over-ble-spi</link><description>HI,
 I am using BL653dvk board(customized ). I am following this link ( https://devzone.nordicsemi.com/f/nordic-q-a/82430/ncs-external-flash-ota-change-qspi-to-spi ) and according to that i have modified my prj.conf file and overlay as well as pm_static</description><dc:language>en-US</dc:language><generator>Telligent Community 13</generator><lastBuildDate>Tue, 07 Jun 2022 11:26:59 GMT</lastBuildDate><atom:link rel="self" type="application/rss+xml" href="https://devzone.nordicsemi.com/f/nordic-q-a/88413/external-flash-dfu-over-ble-spi" /><item><title>RE: External flash DFU over BLE ( SPI )</title><link>https://devzone.nordicsemi.com/thread/371118?ContentTypeID=1</link><pubDate>Tue, 07 Jun 2022 11:26:59 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:4a8aad4c-d055-41ec-b775-e032ee21f70f</guid><dc:creator>Simon</dc:creator><description>&lt;p&gt;I can see from the logs that you&amp;#39;re using NCS v1.9.1. The sample from &lt;a href="https://devzone.nordicsemi.com/f/nordic-q-a/82430/ncs-external-flash-ota-change-qspi-to-spi/345238#345238"&gt;this reply&lt;/a&gt;&amp;nbsp;was made using NCS v1.7.1.&lt;/p&gt;
&lt;p&gt;Could you try again with your modified sample using NCS v1.7.1&lt;/p&gt;
&lt;ol&gt;
&lt;li&gt;If it works then, the issue related to a difference between the NCS versions&lt;/li&gt;
&lt;li&gt;If it&amp;nbsp;doesn&amp;#39;t work, the issue is probably related to your modified sample&lt;/li&gt;
&lt;/ol&gt;
&lt;p&gt;I guess 2 will be the case, but it is nice to be certain. Let me know your results&lt;/p&gt;
&lt;p&gt;Best regards,&lt;/p&gt;
&lt;p&gt;Simon&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: External flash DFU over BLE ( SPI )</title><link>https://devzone.nordicsemi.com/thread/370581?ContentTypeID=1</link><pubDate>Thu, 02 Jun 2022 07:10:32 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:7a4b3f43-500b-4bc4-a9d8-62e4a0175ddc</guid><dc:creator>Shikamaru</dc:creator><description>[quote userid="72692" url="~/f/nordic-q-a/88413/external-flash-dfu-over-ble-spi/370284#370284"]I might not be able to look into this until Thursday/Friday. Sorry for the inconvenience.[/quote]
&lt;p&gt;hi @Simon,&amp;nbsp;&lt;/p&gt;
&lt;p&gt;&amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp;I worked on this issue. followed some tickets related to that in the forum. unfortunately the issue is still there. even tried by keeping the both slot size same also , it didn&amp;#39;t worked same logs am getting . in device manager app also app will say &amp;quot;&lt;strong&gt;validating&lt;/strong&gt;&amp;quot; after that again board will go to reset mode. here is the latest logs.&lt;/p&gt;
&lt;p&gt;&lt;pre class="ui-code" data-mode="text"&gt;
*** Booting Zephyr OS build v2.7.99-ncs1-1  ***
Starting Bluetooth Peripheral LBS example
build time: Jun  1 2022 17:58:18
I: 2 Sectors of 4096 bytes
I: alloc wra: 0, fd0
I: data wra: 0, 1c
I: SoftDevice Controller build revision:
I: 0e e7 c5 66 67 18 3c ac |...fg.&amp;lt;.
I: b3 d2 cc 81 a3 dc f1 c0 |........
I: c0 36 02 22             |.6.&amp;quot;
I: No ID address. App must call settings_load()
Bluetooth initialized
Advertising successfully started
Connected
I: Swap type: test
I: Swap type: test
I: Swap type: test
I: Swap type: test
I: Swap type: test
I: Swap type: test
I: Swap type: test
I: Swap type: test
I: Swap type: test
I: Swap type: test
I: Swap type: test
I: Swap type: test
I: Starting bootloader
W: Cannot upgrade: not a compatible amount of sectors
I: Bootloader chainload address offset: 0xc000
I: Jumping to the first image slot
I: data wra: 0, 1c
Connected
I: Swap type: test
I: Swap type: test
I: Swap type: test
I: Swap type: test
I: Swap type: test
I: Swap type: test
I: Swap type: test
I: Swap type: test
I: Swap type: test
I: Swap type: test
I: Swap type: test
I: Swap type: test
I: data wra: 0, 1c
Connected
I: Swap type: test
I: Swap type: test
I: Swap type: test
I: Swap type: test
I: Swap type: test
I: Swap type: test
I: Swap type: test
I: Swap type: test
I: Swap type: test
I: Swap type: test
&lt;/pre&gt;&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: External flash DFU over BLE ( SPI )</title><link>https://devzone.nordicsemi.com/thread/370284?ContentTypeID=1</link><pubDate>Tue, 31 May 2022 15:45:14 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:8cd0b5c6-ed0b-4d2e-8b72-53f5474ddc5a</guid><dc:creator>Simon</dc:creator><description>&lt;p&gt;&lt;span&gt;Hello Shikamaru,&lt;/span&gt;&lt;/p&gt;
&lt;p&gt;&lt;span&gt;I might not be able to look into this until Thursday/Friday. Sorry for the inconvenience.&lt;/span&gt;&lt;/p&gt;
&lt;p&gt;&lt;span&gt;Best regards,&lt;/span&gt;&lt;/p&gt;
&lt;p&gt;&lt;span&gt;Simon&lt;/span&gt;&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item></channel></rss>
