<?xml-stylesheet type="text/xsl" href="https://devzone.nordicsemi.com/cfs-file/__key/system/syndication/rss.xsl" media="screen"?><rss version="2.0" xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:slash="http://purl.org/rss/1.0/modules/slash/" xmlns:wfw="http://wellformedweb.org/CommentAPI/" xmlns:atom="http://www.w3.org/2005/Atom"><channel><title>BC840 Low power current in System ON</title><link>https://devzone.nordicsemi.com/f/nordic-q-a/88475/bc840-low-power-current-in-system-on</link><description>I am using a BC840 on custom PCB for a low power data logging application and am struggling to get lower than 270uA sleep current. This part has the 32mHz external crystal and our custom PCB provides the 32.768kHz crystal. I am using upstream Zephyr and</description><dc:language>en-US</dc:language><generator>Telligent Community 13</generator><lastBuildDate>Thu, 02 Jun 2022 08:47:41 GMT</lastBuildDate><atom:link rel="self" type="application/rss+xml" href="https://devzone.nordicsemi.com/f/nordic-q-a/88475/bc840-low-power-current-in-system-on" /><item><title>RE: BC840 Low power current in System ON</title><link>https://devzone.nordicsemi.com/thread/370618?ContentTypeID=1</link><pubDate>Thu, 02 Jun 2022 08:47:41 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:5fed0ee8-9b44-4863-ab43-a8cac1997b5e</guid><dc:creator>Kenneth</dc:creator><description>&lt;p&gt;In situations like this I recommend to also get an nRF52840-DK to measure on in parallell, I believe most examples in zephyr should be pretty power optimized as long as you remove disbale&amp;nbsp;CONFIG_SERIAL as you already do. You may something as simple as this for comparison:&lt;br /&gt;&lt;a href="https://devzone.nordicsemi.com/f/nordic-q-a/76231/nrf52840-zephyr-how-to-achieve-low-current-consumption"&gt;https://devzone.nordicsemi.com/f/nordic-q-a/76231/nrf52840-zephyr-how-to-achieve-low-current-consumption&lt;/a&gt;&amp;nbsp;&lt;/p&gt;
&lt;p&gt;&lt;span&gt;Kenneth&lt;/span&gt;&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: BC840 Low power current in System ON</title><link>https://devzone.nordicsemi.com/thread/370546?ContentTypeID=1</link><pubDate>Wed, 01 Jun 2022 23:46:12 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:4dcec23f-be6e-432a-bb93-6d20619bf636</guid><dc:creator>dakejahl</dc:creator><description>&lt;p&gt;I have configured only the GPIO I am using, so there should be none that are accidentally input floating. I assume the default state of IO is high-z and they should be left floating? I did try the finger test, but the footprint is BGA so it probably isn&amp;#39;t of much help. I just audited all of the GPIO again and everything looks to be configured correctly.&amp;nbsp;&lt;/p&gt;
&lt;p&gt;&lt;/p&gt;
&lt;p&gt;Do you know if there is anything special I need to do in order to ensure the 32MHz external crystal is disabled during sleep? The technical reference says that power savings clock control is&amp;nbsp;done automatically when nothing is using it, but perhaps it&amp;#39;s not actually getting disabled. The shell command `nrf_clock_control` does show the HFCLK as being &amp;quot;off&amp;quot; when sleeping, but maybe there&amp;#39;s a bug?&lt;br /&gt;&lt;br /&gt;The current draw from the MCU is 250uA, since 20uA is the quiescent current of the PCB.&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: BC840 Low power current in System ON</title><link>https://devzone.nordicsemi.com/thread/370432?ContentTypeID=1</link><pubDate>Wed, 01 Jun 2022 11:56:50 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:145cd0e0-25f0-489b-a039-8649b114c442</guid><dc:creator>Kenneth</dc:creator><description>&lt;p&gt;I have not tried you code, but in general you may find this useful:&lt;br /&gt;&lt;a href="https://devzone.nordicsemi.com/nordic/nordic-blog/b/blog/posts/optimizing-power-on-nrf52-designs"&gt;https://devzone.nordicsemi.com/nordic/nordic-blog/b/blog/posts/optimizing-power-on-nrf52-designs&lt;/a&gt;&lt;/p&gt;
&lt;p&gt;However the 270uA is a slightly odd value, have you tried moving your finger around the board and check if the current drastically changes? I am thinking it can be a floating input pin that cause excessive current, if that it the case then typically it will change if touched by a finger.&lt;/p&gt;
&lt;p&gt;Kenneth&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item></channel></rss>
