<?xml-stylesheet type="text/xsl" href="https://devzone.nordicsemi.com/cfs-file/__key/system/syndication/rss.xsl" media="screen"?><rss version="2.0" xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:slash="http://purl.org/rss/1.0/modules/slash/" xmlns:wfw="http://wellformedweb.org/CommentAPI/" xmlns:atom="http://www.w3.org/2005/Atom"><channel><title>NMP timeout on MCUMGR</title><link>https://devzone.nordicsemi.com/f/nordic-q-a/88738/nmp-timeout-on-mcumgr</link><description>Hi,
 I build the smp_svr sample for nrf52dk_nrf52832. I installed Go on my windows machine and I am able to run the mcumgr tool. When connecting Teraterm to the UART of my board, I see the boot info and log info from the sample.
 Disconnecting teraterm</description><dc:language>en-US</dc:language><generator>Telligent Community 13</generator><lastBuildDate>Thu, 09 Jun 2022 12:19:00 GMT</lastBuildDate><atom:link rel="self" type="application/rss+xml" href="https://devzone.nordicsemi.com/f/nordic-q-a/88738/nmp-timeout-on-mcumgr" /><item><title>RE: NMP timeout on MCUMGR</title><link>https://devzone.nordicsemi.com/thread/371660?ContentTypeID=1</link><pubDate>Thu, 09 Jun 2022 12:19:00 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:e624e457-5b3c-4d03-815c-e15644f3ecdb</guid><dc:creator>Hung Bui</dc:creator><description>&lt;p&gt;Hi Bob,&lt;/p&gt;
&lt;p&gt;Could you try again without using&amp;nbsp;&lt;span&gt;overlay-shell-mgmnt.conf&amp;nbsp; ?&amp;nbsp;&lt;br /&gt;The shell-mgmnt only needed if you plan to use shell commands at the same time with mcumgr. If not you can remove it.&amp;nbsp;&lt;br /&gt;I am seeing the same issue if I include&amp;nbsp;&amp;nbsp;overlay-shell-mgmnt.conf&amp;nbsp;. It works fine if I removed the configuration.&amp;nbsp;&lt;/span&gt;&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: NMP timeout on MCUMGR</title><link>https://devzone.nordicsemi.com/thread/371605?ContentTypeID=1</link><pubDate>Thu, 09 Jun 2022 09:34:50 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:5ecadb47-19d9-415d-beba-2e193afb921d</guid><dc:creator>BvdP4Celsius</dc:creator><description>&lt;p&gt;Hi, &lt;br /&gt;I added the overlay-serial.conf, overlay-fs.conf and overlay-shell-mgmnt.conf as Kconfig fragments. (VSCode). The generated autoconfig.h shows&amp;nbsp;#define CONFIG_MCUMGR_SMP_UART 1. So I think the&amp;nbsp;&lt;span&gt;CONFIG_MCUMGR_SMP_UART=y was indeed set.&lt;br /&gt;I used the following mcumgr strings:&lt;br /&gt;mcumgr conn add acm0 type=&amp;quot;serial&amp;quot; connstring=&amp;quot;com7,baud=115200,mtu=512&amp;quot;&lt;br /&gt;resulted in &amp;quot;Connection profile acm0 successfully added&amp;quot;&lt;br /&gt;Then: mcumgr -c acm0 image list&lt;br /&gt;Resulted in &amp;quot;Error: NMP timeout&amp;quot;&lt;br /&gt;&lt;br /&gt;My final goal is to have a POC for the DFU, image update.&lt;br /&gt;I flashed a smp_svr example and want to update the application with a new hello world 2 or similar.&lt;br /&gt;I hope I am on the right track...&lt;/span&gt;&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: NMP timeout on MCUMGR</title><link>https://devzone.nordicsemi.com/thread/371598?ContentTypeID=1</link><pubDate>Thu, 09 Jun 2022 09:12:47 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:02cd46a1-e848-4842-ae1a-81c314376e1d</guid><dc:creator>Hung Bui</dc:creator><description>&lt;p&gt;Hi Bob,&lt;/p&gt;
&lt;p&gt;Could you let me know what was your connstring and type&amp;nbsp; in the mcumgr script ?&amp;nbsp;&lt;/p&gt;
&lt;p&gt;&lt;br /&gt;Have you made sure that when you compilied smp_svr you did add&amp;nbsp;CONFIG_MCUMGR_SMP_UART=y into the config ? It&amp;#39;s required for SMP_SVR to support UART.&amp;nbsp;&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item></channel></rss>
