Failed to load readback protection status: async task failure
I am using nRF52833 on a custom board and trying to use J-link to connect the IC with SWD.
But when I opened the programmer to connect my device, it got this error log:
And I tried to use nRF command line and type "nrfjprog --recover" and it will proceed successfully.
But when I type in "nrfjprog --eraseall", it got this error:
C:\Users\u10166>nrfjprog --eraseall --log
[error]: [SeggerBackend] - JLinkARM.dll reported "-1", "An unknown error.".
[error]: [SeggerBackend] - JLinkARM.dll ReadMemU32 detected a read error 1.
[error]: [SeggerBackend] - This typically indicates the read was blocked by a memory protection mechanism.
ERROR: JLinkARM DLL reported an error. Try again. If error condition
ERROR: persists, run the same command again with argument --log, contact Nordic
ERROR: Semiconductor and provide the generated log.log file to them.
Do someone know why this is happened?
  • Hi Vincent,
    From the log:
    Since the protection mechanism is enabled, that means you need to execute "nrfjprog --recover" to disable the memory protection mechanism before erasing ("nrfjprog --recover").
    See the nrfjprog commands description:
    --recover Erases all user flash memory and disables the readback protection mechanism if enabled.
    --eraseall Erases all user available program flash memory and the UICR page. Can be combined with the --qspieraseall operation.
    Note the following limitation:
    • For nRF51 devices with a pre-programmed SoftDevice, only the user available code flash and UICR will be erased.
    Amanda
  • Thank you.
    But I tried "nrfjprog --recover" and it still have the memory protection.
    C:\Users\u10166>nrfjprog --recover
    Recovering device. This operation might take 30s.
    Erasing user code and UICR flash areas.
    Failed to read device memories.
    [error]: [  nRF52] - Failed when checking readback protect status.
    [error]: [SeggerBackend] - Failed while ensuring debug power was enabled for device connection.
    What is the command line version (nrfjprog -v) you are using? Please try the latest version.
    -Amanda
  • I have a very simlar issue with my nrf52833 on a custom board. I have no idea why one day debugging on SEGGER Embedded Studio could no longer be performed. As per similar posts on this subject I have tried --recover and -eraseall with similar error messages and the;Failed to load readback protection status: async task failure for id: 1050638938312 msg: [jlink] JLINKARM_DLL_ERROR (Origin: "Error when running operation: protection-get")
    on NRF Programmer 3.0.7. Using latest versions of nrffjprog (10.19) and Jlink 7.80c
    The chip is running through its program as per normal on power up - I just can't connect to debug. Using the nrf52833 DK for debugging and all had been fine for weeks.
    Don't forget to also provide power to your custom board while using the nrf52833 DK for debugging. If this cannot help, please create a new support case. Thanks.
    -Amanda H.
