<?xml-stylesheet type="text/xsl" href="https://devzone.nordicsemi.com/cfs-file/__key/system/syndication/rss.xsl" media="screen"?><rss version="2.0" xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:slash="http://purl.org/rss/1.0/modules/slash/" xmlns:wfw="http://wellformedweb.org/CommentAPI/" xmlns:atom="http://www.w3.org/2005/Atom"><channel><title>%NCELLMEAS timeout</title><link>https://devzone.nordicsemi.com/f/nordic-q-a/96864/ncellmeas-timeout</link><description>Hello,
 we currently use % NCELLMEA S through the SDK API lte_lc_neighbour_cell_measurement().
 We need to understand:
 what is the maximum timeout for this function?
 at the end of the timeout, will the notification be triggered?
 is it really</description><dc:language>en-US</dc:language><generator>Telligent Community 13</generator><lastBuildDate>Thu, 05 Oct 2023 07:27:26 GMT</lastBuildDate><atom:link rel="self" type="application/rss+xml" href="https://devzone.nordicsemi.com/f/nordic-q-a/96864/ncellmeas-timeout" /><item><title>RE: %NCELLMEAS timeout</title><link>https://devzone.nordicsemi.com/thread/448939?ContentTypeID=1</link><pubDate>Thu, 05 Oct 2023 07:27:26 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:58f9ec0d-a8f8-4056-a358-548ef4980e93</guid><dc:creator>Lily Snape</dc:creator><description>&lt;p&gt;The maximum timeout for the lte_lc_neighbour_cell_measurement() function or %NCELLMEAS is determined by the settings or parameters you specify when you call the function or within your SDK. The specific timeout duration can vary based on your application&amp;#39;s requirements and configuration. &lt;span style="color:#ffffff;"&gt;&lt;a style="color:#ffffff;" href="https://mapquestdrivingdirections.io"&gt;mapquest&lt;/a&gt;&lt;/span&gt;&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: %NCELLMEAS timeout</title><link>https://devzone.nordicsemi.com/thread/412101?ContentTypeID=1</link><pubDate>Sun, 26 Feb 2023 09:57:46 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:4aee0b27-2e73-4ba2-892e-f287805a6a77</guid><dc:creator>barbiz</dc:creator><description>&lt;p&gt;Thanks for your help!&lt;/p&gt;
&lt;p&gt;&lt;/p&gt;
&lt;p&gt;Marco&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: %NCELLMEAS timeout</title><link>https://devzone.nordicsemi.com/thread/411303?ContentTypeID=1</link><pubDate>Wed, 22 Feb 2023 10:10:49 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:d44b1af3-0c88-4d07-9056-a9777ab0b934</guid><dc:creator>Didrik Rokhaug</dc:creator><description>&lt;p&gt;It depends a bit on how you use the command, and what you value most.&lt;/p&gt;
&lt;p&gt;But if power consumption is the most important, it will be a good idea to start a timer/delayable work item that will stop the search if it takes too long.&lt;/p&gt;
&lt;p&gt;However, most of the search types should finish very quickly anyway, so unless you use search type 2 or 5 with a high gci_count (or in a location with very few cells), I don&amp;#39;t really expect it to be a problem.&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: %NCELLMEAS timeout</title><link>https://devzone.nordicsemi.com/thread/411290?ContentTypeID=1</link><pubDate>Wed, 22 Feb 2023 09:33:29 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:8a836ab6-63f2-4817-b0c7-dba4365b183f</guid><dc:creator>barbiz</dc:creator><description>&lt;p&gt;Ok, thanks. So I guess that, in order to have power consumption under control, it is mandatory to send the abort command. Correct?&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: %NCELLMEAS timeout</title><link>https://devzone.nordicsemi.com/thread/410962?ContentTypeID=1</link><pubDate>Mon, 20 Feb 2023 16:55:04 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:cd76547a-fdf6-4865-8a74-b9d2c002f45c</guid><dc:creator>Didrik Rokhaug</dc:creator><description>&lt;p&gt;Hi,&lt;/p&gt;
&lt;p&gt;There is no upper limit set by that function/AT command, and depending on the search type, it will keep searching until it has done a complete search on all enabled bands.&lt;/p&gt;
&lt;p&gt;It is up to the application to decide what is &amp;quot;reasonable&amp;quot;, and the command might search for longer than what the application deems &amp;quot;reasonable&amp;quot;, depending on the search parameters and network conditions.&lt;/p&gt;
&lt;p&gt;Best regards,&lt;/p&gt;
&lt;p&gt;Didrik&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item></channel></rss>
