NCS DFU Supported External Flash Devices
OS: Windows
NCS: 2.2.0
We have discovered that we do not have enough internal flash space to support BLE DFU and need to add an external flash to our nRF52833-based design.
The nRF52840 DK board has an external flash (MX25R64) and BLE DFU is shown to work with the bus configured as SPI or QSPI.
 https://devzone.nordicsemi.com/f/nordic-q-a/82430/ncs-external-flash-ota-change-qspi-to-spi/345238
Our board is very small, so the MX25R64 is simply too physically large, so we are looking at the Gigadevices GD25WD40E/20E.  It is tiny at 1.2x1.2mm and supports SPI bus.
https://www.mouser.com/datasheet/2/870/gd25wd40e_gd25wd20e_datasheet_rev1_1_20221019-3081635.pdf
We have no way of verifying this device without doing another version of the board.  That is a big risk.
1.  Is there a specific memory layout of the flash for NCS DFU to work?  For example, the Gigadevices part's memory layout looks like:
2. Is there a specific list of SPI/QSPI flash devices that work with NCS DFU?
  • Kenneth,
    You are a genius!  I started digging when you focused me on MULTITHREADING and I found this reference online in a prj.conf file.  This resolved the error.
    # If you don't add this when setting CONFIG_SPI=y, you'll get a lot of undefined references
    # from the nrfx spim driver E.G. "undefined reference to `z_impl_k_sleep'"
    CONFIG_MULTITHREADING=y
  • I have wired up the SPI NOR flash and added the sfdp-bfp into both overlay files
    * boards\nrf52833dk_nrf52833.overlay
    * child_image\mcuboot\boards\nrf52833dk_nrf52833.overlay
    However, I am still seeing issues around the conf settings in prj.conf and child_image\mcuboot\boards\nrf52833dk_nrf52833.conf
    CONFIG_FLASH=y
    CONFIG_SPI=y
    CONFIG_SPI_NOR=y
    warning: SPI_NOR (defined at drivers/flash/Kconfig.nor:4) was assigned the value 'y' but got the
    value 'n'. Check these unsatisfied dependencies: DT_HAS_JEDEC_SPI_NOR_ENABLED (=n). See
    docs.zephyrproject.org/.../kconfig.html and/or look up SPI_NOR in the
    menuconfig/guiconfig interface. The Application Development Primer, Setting Configuration Values,
    and Kconfig - Tips and Best Practices sections of the manual might be helpful too.
    It still builds, but when it boots...
    *** Booting Zephyr OS build v3.2.99-ncs1 ***
    I: Starting bootloader
    W: Failed reading sectors; BOOT_MAX_IMG_SECTORS=256 - too small?
    W: Cannot upgrade: not a compatible amount of sectors
    E: Unable to determine flash sector of the image trailer
    E: Image in the primary slot is not valid!
    E: Unable to find bootable image
  • For testing can you first try to make the flash test driver to work?
    https://github.com/nrfconnect/sdk-zephyr/tree/main/tests/drivers/flash
    In your case that want to use spi you can find these two files relevant:
    boards/nrf52840dk_flash_spi.conf
    boards/nrf52840dk_mx25r_high_perf.overlay
    (remove the
    mxicy,mx25r-power-mode = "high-performance"; in your case from the .overlay)
    By modifying the .overlay file you should hopefully relatively quickly find configuration that works.
  • Kenneth,
    I took the flash app you provided and modified it for the nRF52833DK with the ISSI is25lp080d SPI NOR flash.  After a lot of experimental changes it is now passing.  This shows that the flash is connected properly and can be read/written.  I attached flash.zip for reference for everyone.
    ncs\v2.2.0\zephyr\tests\drivers\flash
    The key modifications were:
    * delete testcase.yaml
    * Modify the contents of the overlay file.
            aliases {
                    spi-flash0 = &is25lp080d;
    &pinctrl {
        spi1_default: spi1_default {
                group1 {
                        psels = <NRF_PSEL(SPIM_SCK, 0, 23)>,
                                <NRF_PSEL(SPIM_MOSI, 0, 21)>,
                                <NRF_PSEL(SPIM_MISO, 0, 22)>;
        spi1_sleep: spi1_sleep {
                group1 {
                        low-power-enable;
    &spi1 {
            compatible = "nordic,nrf-spim";     <<<<<<<<<<<<<<<<<< added
            status = "okay";
            cs-gpios = <&gpio0 20 GPIO_ACTIVE_LOW>;
            pinctrl-0 = <&spi1_default>;
            pinctrl-1 = <&spi1_sleep>;
            is25lp080d:is25lp080d@0 {
                    compatible = "jedec,spi-nor";
                    reg = <0>;
                    spi-max-frequency = <0x50000000>;
                    // see is25lp080d datasheet Section 8.29 for jedec-id
                    jedec-id = [ 9D 60 14 ];             <<<<<<<<<<<<<<<<<<  added
                    size = <8388608>;     // 8 Mbits
    Notes from getting it working.
    1.  Required added  compatible = "nordic,nrf-spim";
    2.  The jedec-id is required.  I modified it to an incorrect value and the test fails.  Confirm it is correct.
    3.  The sfdp-bfp field (used on the nRF52840DK external flash example) is not required (at least for this part) and is grossly over complex to implement.  If you get a single bit incorrect, it won't work.
    Running TESTSUITE flash_driver
    START - test_read_unaligned_address
    PASS - test_read_unaligned_address in 0.047 seconds
    TESTSUITE flash_driver succeeded
    ------ TESTSUITE SUMMARY START ------
    SUITE PASS - 100.00% [flash_driver]: pass = 1, fail = 0, skip = 0, total = 1 duration = 0.047 seconds
    - PASS - [flash_driver.test_read_unaligned_address] duration = 0.047 seconds
    ------ TESTSUITE SUMMARY END ------
    PROJECT EXECUTION SUCCESSFUL
    Now that I know the flash is hooked up correctly and can talk to it, I integrated they overlay file it into my nRF52833 DK -based "hello world dfu" project.
    The only modification I did was to both (/boards and /child_image/mcuboot/boards) both nrf52833dk_nrf52833.overlay files to use the below for dfu
            chosen {
                    nordic,pm-ext-flash = &is25lp080d;
    Instead of the below used for the flash test
            aliases {
    When I flash the board, I got this error.
    I: Bootloader chainload address offset: 0xf000
    Hello World 1! nrf52833dk_nrf52833
    If I increase CONFIG_BOOT_MAX_IMG_SECTORS=512, one error goes away.
    CONFIG_BOOT_MAX_IMG_SECTORS is a setting from the nrf52840 DK serial DFU  external flash example that I based this project on.
    https://github.com/simon-iversen/sdk-zephyr/tree/serial_dfu_ext_flash_hello_world/samples/hello_world
    1.  I can not find a reference to what CONFIG_BOOT_MAX_IMG_SECTORS  does and how it interacts with other settings.
    2.  "not a compatible amount of sectors".  What is a "compatible amount of sectors"?  Please explain.
    3. I thought the source of the issues is the fact that I don't have a pm_static.yaml like in the above serial dfu with external flash example I reference above.  Contents of pm_static.yaml
    external_flash:
      address: 0xf4000
      end_address: 0x800000
      region: external_flash
    mcuboot_secondary:
      address: 0x00000
      device: MX25R64
      end_address: 0xf4000
    This matches the output of:
    PS C:\Virtuix\nordic\myapps\hello_world\build> west build -t partition_manager_report
    -- west build: running target partition_manager_report
    [1/1] cmd.exe /C "cd /D C:\Virtuix\nordic\myapps\hello_world\b...put C:/Virtuix/nordic/myapps/hello_world/build/partitions.yml" external_flash (0x800000 - 8192kB):
    | 0x0: mcuboot_secondary (0xf4000 - 976kB) |
    | 0xf4000: external_flash (0x70c000 - 7216kB) |
    flash_primary (0x100000 - 1024kB):
    | 0x0: mcuboot (0xc000 - 48kB) |
    +---0xc000: mcuboot_primary (0xf4000 - 976kB)-----+
    | 0xc000: mcuboot_pad (0x200 - 512B) |
    +---0xc200: mcuboot_primary_app (0xf3e00 - 975kB)-+
    | 0xc200: app (0xf3e00 - 975kB) |
    sram_primary (0x40000 - 256kB):
    | 0x20000000: sram_primary (0x40000 - 256kB) |
    I then attempted to create my own pm_static.yaml
    external_flash:
      address: 0x71000
      end_address: 0x100000
    mcuboot_secondary:
      address: 0x00000
      device: is25lp080d
      end_address: 0x8f000
    Again based off the output of
    PS C:\Virtuix\nordic\myapps\hello_world_dfu\build_nrf52833dk_nrf52833> west build -t partition_manager_report
    [1/1] cmd.exe /C "cd /D C:\Virtuix\nordic\myapps\hello_world_...pps/hello_world_dfu/build_nrf52833dk_nrf52833/partitions.yml"
    external_flash (0x100000 - 1024kB):
    | 0x0: mcuboot_secondary (0x71000 - 452kB) |
    | 0x71000: external_flash (0x8f000 - 572kB) |
    flash_primary (0x80000 - 512kB):
    | 0x0: mcuboot (0xf000 - 60kB) |
    +---0xf000: mcuboot_primary (0x71000 - 452kB)-----+
    | 0xf000: mcuboot_pad (0x200 - 512B) |
    +---0xf200: mcuboot_primary_app (0x70e00 - 451kB)-+
    | 0xf200: app (0x70e00 - 451kB) |
    sram_primary (0x20000 - 128kB):
    | 0x20000000: sram_primary (0x20000 - 128kB) |
    I still get the same output.
    There is something I am simply not understanding.
    hello_world_dfu_13_3_23.zip
    flash.zip
