<?xml-stylesheet type="text/xsl" href="https://devzone.nordicsemi.com/cfs-file/__key/system/syndication/rss.xsl" media="screen"?><rss version="2.0" xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:slash="http://purl.org/rss/1.0/modules/slash/" xmlns:wfw="http://wellformedweb.org/CommentAPI/" xmlns:atom="http://www.w3.org/2005/Atom"><channel><title>MPU Fault in mesh light sample</title><link>https://devzone.nordicsemi.com/f/nordic-q-a/97546/mpu-fault-in-mesh-light-sample</link><description>Hello,
 When I&amp;#39;m trying to use Light sample with nrf52840dk I got this error when I try to assign a publish address using nrf Mesh app.
 I&amp;#39;m using the sample without any modifications.
 tools:
 ncs: v2.2.0
 dk: nrf52480
 Thanks in advance</description><dc:language>en-US</dc:language><generator>Telligent Community 13</generator><lastBuildDate>Fri, 22 Sep 2023 14:54:14 GMT</lastBuildDate><atom:link rel="self" type="application/rss+xml" href="https://devzone.nordicsemi.com/f/nordic-q-a/97546/mpu-fault-in-mesh-light-sample" /><item><title>RE: MPU Fault in mesh light sample</title><link>https://devzone.nordicsemi.com/thread/447273?ContentTypeID=1</link><pubDate>Fri, 22 Sep 2023 14:54:14 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:b742f0f4-0ac4-4186-9d3a-7bbac717c56d</guid><dc:creator>boris bergman1</dc:creator><description>&lt;p&gt;&lt;pre class="ui-code" data-mode="text"&gt;BT Mesh settings workq: STACK: unused 368 usage 1032 / 1400 (73 %); CPU: 0 %
      : Total CPU cycles used: 222
 BT CTLR ECDH        : STACK: unused 704 usage 200 / 904 (22 %); CPU: 0 %
      : Total CPU cycles used: 1
 BT RX               : STACK: unused 920 usage 3080 / 4000 (77 %); CPU: 0 %
      : Total CPU cycles used: 135912
 BT TX               : STACK: unused 896 usage 640 / 1536 (41 %); CPU: 0 %
      : Total CPU cycles used: 1499
 thread_analyzer     : STACK: unused 584 usage 440 / 1024 (42 %); CPU: 0 %
      : Total CPU cycles used: 15439
 sysworkq            : STACK: unused 936 usage 1112 / 2048 (54 %); CPU: 0 %
      : Total CPU cycles used: 28933
 MPSL Work           : STACK: unused 472 usage 552 / 1024 (53 %); CPU: 1 %
      : Total CPU cycles used: 436337
 BT_LW_WQ            : STACK: unused 476 usage 828 / 1304 (63 %); CPU: 0 %
      : Total CPU cycles used: 144
 logging             : STACK: unused 1432 usage 616 / 2048 (30 %); CPU: 2 %
      : Total CPU cycles used: 676852
 idle                : STACK: unused 216 usage 104 / 320 (32 %); CPU: 95 %
      : Total CPU cycles used: 28679255
 ISR0                : STACK: unused 936 usage 1112 / 2048 (54 %)&lt;/pre&gt;&lt;/p&gt;
&lt;p&gt;bt_rx just didn&amp;#39;t fit in the stack. Didn&amp;#39;t know it had too be that big, issue is resolved now.&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: MPU Fault in mesh light sample</title><link>https://devzone.nordicsemi.com/thread/447264?ContentTypeID=1</link><pubDate>Fri, 22 Sep 2023 14:10:41 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:d9629d34-1e8b-4999-bd68-295d7b75b833</guid><dc:creator>boris bergman1</dc:creator><description>&lt;p&gt;I have the same issue.&amp;nbsp;&lt;pre class="ui-code" data-mode="text"&gt;Initializing...
[00:00:00.008,483] &amp;lt;inf&amp;gt; fs_nvs: 8 Sectors of 4096 bytes
[00:00:00.008,514] &amp;lt;inf&amp;gt; fs_nvs: alloc wra: 0, fe8
[00:00:00.008,514] &amp;lt;inf&amp;gt; fs_nvs: data wra: 0, 0
[00:00:00.008,697] &amp;lt;inf&amp;gt; bt_sdc_hci_driver: SoftDevice Controller build revision:
                                            e0 7e 2e c1 5e 05 85 23  46 15 dc fa 8e 29 7d 70 |.~..^..# F....)}p
                                            10 93 a5 fc                                      |....
[00:00:00.013,000] &amp;lt;inf&amp;gt; bt_hci_core: HW Platform: Nordic Semiconductor (0x0002)
[00:00:00.013,031] &amp;lt;inf&amp;gt; bt_hci_core: HW Variant: nRF52x (0x0002)
[00:00:00.013,061] &amp;lt;inf&amp;gt; bt_hci_core: Firmware: Standard Bluetooth controller (0x00) Version 224.11902 Build 2231721665
[00:00:00.013,519] &amp;lt;inf&amp;gt; bt_hci_core: No ID address. App must call settings_load()
Bluetooth initialized
[00:00:00.426,666] &amp;lt;inf&amp;gt; bt_hci_core: Identity: E1:69:11:7E:78:B6 (random)
[00:00:00.426,696] &amp;lt;inf&amp;gt; bt_hci_core: HCI: version 5.4 (0x0d) revision 0x1077, manufacturer 0x0059
[00:00:00.426,727] &amp;lt;inf&amp;gt; bt_hci_core: LMP: version 5.4 (0x0d) subver 0x1077
Mesh initialized
[00:00:07.359,436] &amp;lt;wrn&amp;gt; bt_att: Unhandled ATT code 0x1d
[00:00:20.132,965] &amp;lt;inf&amp;gt; bt_mesh_main: Primary Element: 0x0026
[00:00:24.226,898] &amp;lt;wrn&amp;gt; bt_att: Unhandled ATT code 0x1d
[00:00:26.784,393] &amp;lt;err&amp;gt; os: ***** MPU FAULT *****
[00:00:26.784,423] &amp;lt;err&amp;gt; os:   Stacking error (context area might be not valid)
[00:00:26.784,454] &amp;lt;err&amp;gt; os:   Data Access Violation
[00:00:26.784,454] &amp;lt;err&amp;gt; os:   MMFAR Address: 0x20008830
[00:00:26.784,484] &amp;lt;err&amp;gt; os: r0/a1:  0x00000000  r1/a2:  0x2000625c  r2/a3:  0x00000000
[00:00:26.784,515] &amp;lt;err&amp;gt; os: r3/a4:  0xe000ed00 r12/ip:  0x20006984 r14/lr:  0x00000000
[00:00:26.784,515] &amp;lt;err&amp;gt; os:  xpsr:  0x21000000
[00:00:26.784,545] &amp;lt;err&amp;gt; os: Faulting instruction address (r15/pc): 0x0004c73c
[00:00:26.784,576] &amp;lt;err&amp;gt; os: &amp;gt;&amp;gt;&amp;gt; ZEPHYR FATAL ERROR 2: Stack overflow on CPU 0
[00:00:26.784,637] &amp;lt;err&amp;gt; os: Current thread: 0x20002da0 (BT RX)&lt;/pre&gt;&lt;/p&gt;
&lt;p&gt;Same sample, same board, platform v2.4.2. Also I configured CONFIG_BT_RX_STACK_SIZE=3000. Get the error already when I provision with nrf app.&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: MPU Fault in mesh light sample</title><link>https://devzone.nordicsemi.com/thread/415851?ContentTypeID=1</link><pubDate>Thu, 16 Mar 2023 23:10:13 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:5ede17cb-dbaa-417d-9709-3519e77261d8</guid><dc:creator>Joakim Jakobsen</dc:creator><description>&lt;p&gt;Glad you figured it out.&lt;/p&gt;
&lt;p&gt;Thanks for sharing the solution.&lt;/p&gt;
&lt;p&gt;Br,&lt;br /&gt;Joakim&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: MPU Fault in mesh light sample</title><link>https://devzone.nordicsemi.com/thread/415142?ContentTypeID=1</link><pubDate>Tue, 14 Mar 2023 11:16:49 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:b4ac88dd-068c-4b32-b9ef-09b17a7351f1</guid><dc:creator>Mustafa</dc:creator><description>&lt;p&gt;Hey Joakim,&lt;/p&gt;
&lt;p&gt;Actually, I had to increase&amp;nbsp;CONFIG_BT_RX_STACK_SIZE, then it worked on my side.&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: MPU Fault in mesh light sample</title><link>https://devzone.nordicsemi.com/thread/415135?ContentTypeID=1</link><pubDate>Tue, 14 Mar 2023 11:02:30 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:115a9f44-fd68-4592-8207-7992537b951c</guid><dc:creator>Joakim Jakobsen</dc:creator><description>&lt;p&gt;Hi.&lt;/p&gt;
&lt;p&gt;Sorry about the delay. I wanted to test the sample before getting back to you. Have you made any progress on the issue, or do you still need assistance?&lt;/p&gt;
&lt;p&gt;&lt;/p&gt;
&lt;p&gt;I couldn&amp;#39;t see the same issue testing with a nRF52840-DK.&lt;/p&gt;
&lt;p&gt;Br,&lt;br /&gt;Joakim&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item></channel></rss>
