<?xml-stylesheet type="text/xsl" href="https://devzone.nordicsemi.com/cfs-file/__key/system/syndication/rss.xsl" media="screen"?><rss version="2.0" xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:slash="http://purl.org/rss/1.0/modules/slash/" xmlns:wfw="http://wellformedweb.org/CommentAPI/" xmlns:atom="http://www.w3.org/2005/Atom"><channel><title>DSPI example on Zephyr / nRF Connect SDK</title><link>https://devzone.nordicsemi.com/f/nordic-q-a/97642/dspi-example-on-zephyr-nrf-connect-sdk</link><description>Hello, I want to implement a dual SPI interface on a nRF52840. Unfortunately I find only very outdated examples before the &amp;quot;Zephyr time&amp;quot;. Are there any current sources somewhere? Especially also on the topic of the configuration of the devicetree.</description><dc:language>en-US</dc:language><generator>Telligent Community 13</generator><lastBuildDate>Tue, 09 May 2023 19:03:21 GMT</lastBuildDate><atom:link rel="self" type="application/rss+xml" href="https://devzone.nordicsemi.com/f/nordic-q-a/97642/dspi-example-on-zephyr-nrf-connect-sdk" /><item><title>RE: DSPI example on Zephyr / nRF Connect SDK</title><link>https://devzone.nordicsemi.com/thread/424655?ContentTypeID=1</link><pubDate>Tue, 09 May 2023 19:03:21 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:2f717daa-4003-428b-a81c-08aaa510043e</guid><dc:creator>haakonsh</dc:creator><description>&lt;p&gt;To read any node or childnode&amp;#39;s property see the &amp;quot;Example usage with DT_PROP()&amp;quot; in the DT_PATH macro documentation in zephyr\include\zephyr\devicetree.h:&amp;nbsp;&lt;br /&gt;&lt;pre class="ui-code" data-mode="c_cpp"&gt;
 * @brief Get a node identifier for a devicetree path
 * @note This macro returns a node identifier from path components. To get
 *       a path string from a node identifier, use DT_NODE_PATH() instead.
 * The arguments to this macro are the names of non-root nodes in the
 * tree required to reach the desired node, starting from the root.
 * Non-alphanumeric characters in each name must be converted to
 * underscores to form valid C tokens, and letters must be lowercased.
 * Example devicetree fragment:
 * @code{.dts}
 *             soc {
 *                     serial1: serial@40001000 {
 *                             status = &amp;quot;okay&amp;quot;;
 *                             current-speed = &amp;lt;115200&amp;gt;;
 * @endcode
 * You can use `DT_PATH(soc, serial_40001000)` to get a node identifier
 * for the `serial@40001000` node. Node labels like `serial1` cannot be
 * used as DT_PATH() arguments; use DT_NODELABEL() for those instead.
 * Example usage with DT_PROP() to get the `current-speed` property:
 * @code{.c}
 *     DT_PROP(DT_PATH(soc, serial_40001000), current_speed) // 115200
 * @endcode
 * (The `current-speed` property is also in `lowercase-and-underscores`
 * form when used with this API.)
 * When determining arguments to DT_PATH():
 * - the first argument corresponds to a child node of the root (`soc` above)
 * - a second argument corresponds to a child of the first argument
 *   (`serial_40001000` above, from the node name `serial@40001000`
 *   after lowercasing and changing `@` to `_`)
 * - and so on for deeper nodes in the desired node&amp;#39;s path
 * @param ... lowercase-and-underscores node names along the node&amp;#39;s path,
 *            with each name given as a separate argument
 * @return node identifier for the node with that path
#define DT_PATH(...) DT_PATH_INTERNAL(__VA_ARGS__)&lt;/pre&gt;&lt;br /&gt;I think you&amp;#39;ve understood it correctly, but just to be sure I&amp;#39;d like to clarify the relation between the NRFX driver and Nordic&amp;#39;s implementation of a Zephyr SPI controller driver.&amp;nbsp;&lt;/p&gt;
&lt;p&gt;Zephyr has a standard SPI Controller API, defined in zephyr\include\zephyr\drivers\spi.h.&amp;nbsp;The following&amp;nbsp;header file, zephyr\include\zephyr\devicetree\spi.h, also defines a bunch of neat DT macros for reading DT node properties of a SPI Controller node which might be useful to you.&amp;nbsp;&lt;/p&gt;
&lt;p&gt;Nordic has implemented a Zephyr SPI Controller in&amp;nbsp;zephyr\drivers\spi\spi_nrfx_spim.c. This driver gathers info from the device tree about a particular SPI Controller node (f.ex spi2: spi@40023000), and use that information to initialize the NRFX driver like you&amp;#39;ve described above.&amp;nbsp;&lt;/p&gt;
&lt;p&gt;The driver&amp;nbsp;you are creating is very close to&amp;nbsp;being another Zephyr SPI Controller implementation. If you create a new SPI Controller DT binding and .config file, and implement the API functions described in&amp;nbsp;&lt;span&gt;spi.h, you should have a fully functional Zephyr SPI Controller. That means that you can access any device on this new SPI bus as if it is just another Zephyr SPI Device, and taking advantage of built-in scheduling features like having a thread idling until the DSPI controller is available&amp;nbsp;with optional&amp;nbsp;timeouts, etc.&amp;nbsp;&lt;/span&gt;&lt;/p&gt;
&lt;p&gt;&lt;span&gt;Here&amp;#39;s the &amp;quot;top-level&amp;quot; Zephyr SPI Controller API. It consist of&amp;nbsp;two mandatory and one optional functions:&lt;br /&gt;&lt;/span&gt;&lt;/p&gt;
&lt;p&gt;&lt;span&gt;&lt;pre class="ui-code" data-mode="c_cpp"&gt;/**
 * @brief SPI driver API
 * This is the mandatory API any SPI driver needs to expose.
__subsystem struct spi_driver_api {
	spi_api_io transceive;
#ifdef CONFIG_SPI_ASYNC
	spi_api_io_async transceive_async;
#endif /* CONFIG_SPI_ASYNC */
	spi_api_release release;
};&lt;/pre&gt;&lt;/span&gt;&lt;/p&gt;
&lt;p&gt;&lt;span&gt;If you create this SPI Controller implementation, you&amp;#39;ll be able to understand almost any other Zephyr driver. How the drivers interact with the devicetree, and how to add device drivers to zephyr, like adding devices to your new DSPI bus.&amp;nbsp;&lt;/span&gt;&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: DSPI example on Zephyr / nRF Connect SDK</title><link>https://devzone.nordicsemi.com/thread/424317?ContentTypeID=1</link><pubDate>Mon, 08 May 2023 13:53:02 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:35273318-3493-4c2c-9f8a-1a59d6496f03</guid><dc:creator>Thurow</dc:creator><description>&lt;p&gt;Did I understand it correctly?&lt;br /&gt;I can&amp;#39;t write:&lt;/p&gt;
&lt;p&gt;&lt;code&gt;#define SPIBB1_NODE DT_NODELABEL(spi1)&lt;/code&gt;&lt;br /&gt;&lt;code&gt;static const struct device *const spi1_dev = DEVICE_DT_GET(SPIBB1_NODE);&lt;/code&gt;&lt;br /&gt;&lt;br /&gt;because the NRFX_SPIM driver is not a Zephyr driver, but is one layer below. Right?&amp;nbsp;I am now virtually at &amp;quot;HAL level&amp;quot; with completely different (Nordic in-house) API. Therefore I now have to marry both worlds.&lt;br /&gt;According to the Nordic in-house API I create a SPIM driver instance with&lt;/p&gt;
&lt;p&gt;&lt;code&gt;nrfx_err_t err_code = nrfx_spim_init(&amp;amp;m_spim1, &amp;amp;spim1_config, NULL, NULL);&lt;/code&gt;&lt;br /&gt;&lt;br /&gt;in it. spim1_config holds the config values in the Nordic in-house world. Thereforce I set spim1_config with the Nordic in-house API:&lt;/p&gt;
&lt;p&gt;&lt;code&gt;nrfx_spim_config_t spim1_config = NRFX_SPIM_DEFAULT_CONFIG(SCK_PIN, MOSI_PIN, MISO_PIN, NRFX_SPIM_PIN_NOT_USED);&lt;/code&gt;&lt;/p&gt;
&lt;p&gt;I get the individual values for this from the devicetree, which again belongs to the Zephyr world. However, since the two APIs are independent of each other, I can&amp;#39;t fetch all the values of a node together, but use macros to fetch each value individually. So I have to read out the pins one by one, the SPI mode, the clock rate etc. Right?&lt;/p&gt;
&lt;p&gt;Even after studying the source, I did not really understand how to get to the pins, for example, because there are too many &amp;quot;recursive structures&amp;quot; here. As an example:&lt;/p&gt;
&lt;p&gt;&lt;code&gt;&amp;amp;pinctrl {&lt;/code&gt;&lt;br /&gt;&lt;code&gt;&amp;nbsp;&amp;nbsp; &amp;nbsp;spi1_default: spi1_default {&lt;/code&gt;&lt;br /&gt;&lt;code&gt;&amp;nbsp;&amp;nbsp; &amp;nbsp;&amp;nbsp;&amp;nbsp; &amp;nbsp;group1 {&lt;/code&gt;&lt;br /&gt;&lt;code&gt;&amp;nbsp;&amp;nbsp; &amp;nbsp;&amp;nbsp;&amp;nbsp; &amp;nbsp;&amp;nbsp;&amp;nbsp; &amp;nbsp;psels = &amp;lt;NRF_PSEL(SPIM_SCK, 0, 13)&amp;gt;,&lt;/code&gt;&lt;br /&gt;&lt;code&gt;&amp;nbsp;&amp;nbsp; &amp;nbsp;&amp;nbsp;&amp;nbsp; &amp;nbsp;&amp;nbsp;&amp;nbsp; &amp;nbsp;&amp;nbsp;&amp;nbsp; &amp;nbsp;&amp;nbsp;&amp;nbsp; &amp;nbsp;&amp;lt;NRF_PSEL(SPIM_MOSI, 0, 14)&amp;gt;,&lt;/code&gt;&lt;br /&gt;&lt;code&gt;&amp;nbsp;&amp;nbsp; &amp;nbsp;&amp;nbsp;&amp;nbsp; &amp;nbsp;&amp;nbsp;&amp;nbsp; &amp;nbsp;&amp;nbsp;&amp;nbsp; &amp;nbsp;&amp;nbsp;&amp;nbsp; &amp;nbsp;&amp;lt;NRF_PSEL(SPIM_MISO, 0, 15)&amp;gt;;&lt;/code&gt;&lt;br /&gt;&lt;code&gt;&amp;nbsp;&amp;nbsp; &amp;nbsp;&amp;nbsp;&amp;nbsp; &amp;nbsp;};&lt;/code&gt;&lt;br /&gt;&lt;code&gt;&amp;nbsp;&amp;nbsp; &amp;nbsp;};&lt;/code&gt;&lt;br /&gt;&lt;br /&gt;&lt;code&gt;&amp;nbsp;&amp;nbsp; &amp;nbsp;spi1_sleep: spi1_sleep {&lt;/code&gt;&lt;br /&gt;&lt;code&gt;&amp;nbsp;&amp;nbsp; &amp;nbsp;&amp;nbsp;&amp;nbsp; &amp;nbsp;group1 {&lt;/code&gt;&lt;br /&gt;&lt;code&gt;&amp;nbsp;&amp;nbsp; &amp;nbsp;&amp;nbsp;&amp;nbsp; &amp;nbsp;&amp;nbsp;&amp;nbsp; &amp;nbsp;psels = &amp;lt;NRF_PSEL(SPIM_SCK, 0, 13)&amp;gt;,&lt;/code&gt;&lt;br /&gt;&lt;code&gt;&amp;nbsp;&amp;nbsp; &amp;nbsp;&amp;nbsp;&amp;nbsp; &amp;nbsp;&amp;nbsp;&amp;nbsp; &amp;nbsp;&amp;nbsp;&amp;nbsp; &amp;nbsp;&amp;nbsp;&amp;nbsp; &amp;nbsp;&amp;lt;NRF_PSEL(SPIM_MOSI, 0, 14)&amp;gt;,&lt;/code&gt;&lt;br /&gt;&lt;code&gt;&amp;nbsp;&amp;nbsp; &amp;nbsp;&amp;nbsp;&amp;nbsp; &amp;nbsp;&amp;nbsp;&amp;nbsp; &amp;nbsp;&amp;nbsp;&amp;nbsp; &amp;nbsp;&amp;nbsp;&amp;nbsp; &amp;nbsp;&amp;lt;NRF_PSEL(SPIM_MISO, 0, 15)&amp;gt;;&lt;/code&gt;&lt;br /&gt;&lt;code&gt;&amp;nbsp;&amp;nbsp; &amp;nbsp;&amp;nbsp;&amp;nbsp; &amp;nbsp;&amp;nbsp;&amp;nbsp; &amp;nbsp;low-power-enable;&lt;/code&gt;&lt;br /&gt;&lt;code&gt;&amp;nbsp;&amp;nbsp; &amp;nbsp;&amp;nbsp;&amp;nbsp; &amp;nbsp;};&lt;/code&gt;&lt;br /&gt;&lt;code&gt;&amp;nbsp;&amp;nbsp; &amp;nbsp;};&lt;/code&gt;&lt;br /&gt;...&lt;br /&gt;&lt;code&gt;};&lt;/code&gt;&lt;/p&gt;
&lt;p&gt;&lt;code&gt;&amp;amp;spi1 {&lt;/code&gt;&lt;br /&gt;&lt;code&gt;&amp;nbsp;&amp;nbsp; &amp;nbsp;compatible = &amp;quot;nordic,nrf-spi&amp;quot;;&lt;/code&gt;&lt;br /&gt;&lt;code&gt;&amp;nbsp;&amp;nbsp; &amp;nbsp;status = &amp;quot;okay&amp;quot;;&lt;/code&gt;&lt;br /&gt;&lt;code&gt;&amp;nbsp;&amp;nbsp; &amp;nbsp;pinctrl-0 = &amp;lt;&amp;amp;spi1_default&amp;gt;;&lt;/code&gt;&lt;br /&gt;&lt;code&gt;&amp;nbsp;&amp;nbsp; &amp;nbsp;pinctrl-1 = &amp;lt;&amp;amp;spi1_sleep&amp;gt;;&lt;/code&gt;&lt;br /&gt;&lt;code&gt;&amp;nbsp;&amp;nbsp; &amp;nbsp;cs-gpios = &amp;lt;&amp;amp;gpio0 11 GPIO_ACTIVE_LOW&amp;gt;;&lt;/code&gt;&lt;br /&gt;&lt;code&gt;};&lt;/code&gt;&lt;/p&gt;
&lt;p&gt;&lt;code&gt;How do I get the DT_PROP() macro to e.g. SPIM_SCK of spi1?&lt;/code&gt;&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: DSPI example on Zephyr / nRF Connect SDK</title><link>https://devzone.nordicsemi.com/thread/423684?ContentTypeID=1</link><pubDate>Thu, 04 May 2023 07:47:41 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:3d392170-575e-49fc-8514-48cd597900ed</guid><dc:creator>haakonsh</dc:creator><description>[quote user="Thurow"]Haakonsh, thank you for your patience! This is really a big help for me on this completely new environment for me.[/quote]
&lt;p&gt;Ofc! :)&amp;nbsp;&lt;/p&gt;
&lt;p&gt;Zephyr has a big learning-curve and I&amp;#39;m still learing myself.&amp;nbsp;The nRF52 has a lot of features that make it very-very flexible, but that also adds&amp;nbsp;to the learning-curve.&amp;nbsp;So don&amp;#39;t worry about not &amp;#39;getting it&amp;#39; immidiately, you&amp;#39;ll clear the curve soon enough.&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: DSPI example on Zephyr / nRF Connect SDK</title><link>https://devzone.nordicsemi.com/thread/423617?ContentTypeID=1</link><pubDate>Wed, 03 May 2023 17:04:59 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:38d61fa8-640f-4141-9203-69a66a374e30</guid><dc:creator>Thurow</dc:creator><description>&lt;p&gt;Haakonsh, thank you for your patience! This is really a big help for me on this completely new environment for me.&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: DSPI example on Zephyr / nRF Connect SDK</title><link>https://devzone.nordicsemi.com/thread/423599?ContentTypeID=1</link><pubDate>Wed, 03 May 2023 14:03:40 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:d52c4711-fac6-40e2-a6eb-5736af051e11</guid><dc:creator>haakonsh</dc:creator><description>[quote user="Thurow"]Can&amp;#39;t I somehow take the pinout from the DTS description?[/quote]
&lt;p&gt;You can use the&amp;nbsp;DT_PROP() macro to get the value of a given property of a given node. See&amp;nbsp;include/zephyr/devicetree.h:607 and&amp;nbsp;&lt;a href="https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/zephyr/build/dts/api-usage.html"&gt;https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/zephyr/build/dts/api-usage.html&lt;/a&gt;.&lt;/p&gt;
&lt;p&gt;&lt;/p&gt;
&lt;p&gt;-edit:&lt;/p&gt;
&lt;p&gt;You should not use the blocking sample as you&amp;#39;ll need to use asynchronous features of the SPIM peripherals.&lt;/p&gt;
&lt;p&gt;-another edit:&lt;/p&gt;
&lt;p&gt;You should try the generic PPI sample to get familiar with how the PPI system works.&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: DSPI example on Zephyr / nRF Connect SDK</title><link>https://devzone.nordicsemi.com/thread/423516?ContentTypeID=1</link><pubDate>Wed, 03 May 2023 11:30:22 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:a4f59aac-0700-4601-8c8d-90b3bce33345</guid><dc:creator>Thurow</dc:creator><description>&lt;p&gt;First of all, thank you! That was the solution. &lt;br /&gt;Now I continue to work analogously to the samples modules\hal\nordic\nrfx\samples\src\nrfx_spim\blocking and nonblocking. Are there any other sources I should study?&lt;br /&gt;&lt;br /&gt;My first question already concerns the line&lt;br /&gt;&lt;br /&gt;&amp;nbsp;nrfx_spim_config_t spim_config = NRFX_SPIM_DEFAULT_CONFIG(SCK_PIN,&lt;br /&gt;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp; MOSI_PIN,&lt;br /&gt;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp; MISO_PIN,&lt;br /&gt;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp; NRFX_SPIM_PIN_NOT_USED);&lt;br /&gt;&lt;br /&gt;Can&amp;#39;t I somehow take the pinout from the DTS description?&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: DSPI example on Zephyr / nRF Connect SDK</title><link>https://devzone.nordicsemi.com/thread/423467?ContentTypeID=1</link><pubDate>Wed, 03 May 2023 08:44:51 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:a1a03bff-a178-4c57-aa49-c396e725664a</guid><dc:creator>haakonsh</dc:creator><description>[quote user="Thurow"]&lt;code&gt;&amp;amp;spi1 {&lt;/code&gt;&lt;br /&gt;&lt;code&gt;&amp;nbsp;&amp;nbsp; &amp;nbsp;compatible = &amp;quot;nordic,nrf-spi&amp;quot;;&lt;/code&gt;[/quote]
&lt;p&gt;There&amp;#39;s the problem, the default &amp;#39;compatible&amp;#39;&amp;nbsp;field has been overridden to use SPI instead of SPIM.&lt;/p&gt;
&lt;p&gt;This is the spi1 node from nrf52840.dtsi:&amp;nbsp;&lt;br /&gt;&lt;pre class="ui-code" data-mode="c_cpp"&gt;spi1: spi@40004000 {
			 * This spi node can be SPI, SPIM, or SPIS,
			 * for the user to pick:
			 * compatible = &amp;quot;nordic,nrf-spi&amp;quot; or
			 *              &amp;quot;nordic,nrf-spim&amp;quot; or
			 *              &amp;quot;nordic,nrf-spis&amp;quot;.
			compatible = &amp;quot;nordic,nrf-spim&amp;quot;;
			#address-cells = &amp;lt;1&amp;gt;;
			#size-cells = &amp;lt;0&amp;gt;;
			reg = &amp;lt;0x40004000 0x1000&amp;gt;;
			interrupts = &amp;lt;4 NRF_DEFAULT_IRQ_PRIORITY&amp;gt;;
			max-frequency = &amp;lt;DT_FREQ_M(8)&amp;gt;;
			status = &amp;quot;disabled&amp;quot;;
		};&lt;/pre&gt;&lt;/p&gt;
&lt;p&gt;-Edit: &lt;br /&gt;The &amp;#39;compatible&amp;#39; field of any SPI node determines which SPI driver will be included by Zephyr&amp;#39;s build system. You can set the &amp;#39;compatible&amp;#39; field to any device tree binding that is itself &amp;#39;compatible&amp;#39; with the &amp;#39;spi-controller.yaml&amp;#39; binding. Where the&amp;nbsp;spi-controller.yaml binding is the base devicetree binding for Zephyr&amp;#39;s SPI&amp;nbsp;controller.&amp;nbsp;That means that if you set spi1&amp;#39;s &amp;#39;compatible&amp;#39; field to &amp;#39;st,stm32-spi&amp;#39;, Zephyr&amp;#39;s build system would include the spi_ll_stm32 driver instead.&amp;nbsp;&lt;/p&gt;
&lt;p&gt;See&amp;nbsp;zephyr\drivers\spi\CMakeLists.txt for how a given SPI driver is included.&amp;nbsp;&lt;/p&gt;
&lt;p&gt;For the&amp;nbsp;spi_nrfx_spim driver:&amp;nbsp;&lt;br /&gt;zephyr_library_sources_ifdef(CONFIG_NRFX_SPIM &amp;nbsp; &amp;nbsp; &amp;nbsp; spi_nrfx_spim.c)&lt;/p&gt;
&lt;p&gt;&lt;/p&gt;
&lt;p&gt;I suggest that you study the devicetree bindings a bit. If you ctrl+click the &amp;#39;nordic,nrf-spim&amp;#39; binding in VS code you&amp;#39;ll open the actual binding file. The binding contain useful information on what&amp;nbsp;information a node that is &amp;#39;compatible&amp;#39; must contain, as well as links to parent bindings through the &amp;#39;include&amp;#39; field.&lt;br /&gt;&lt;br /&gt;&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: DSPI example on Zephyr / nRF Connect SDK</title><link>https://devzone.nordicsemi.com/thread/423384?ContentTypeID=1</link><pubDate>Tue, 02 May 2023 18:05:44 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:789cc41d-39b6-4925-9b33-aa4ca6b88b6b</guid><dc:creator>Thurow</dc:creator><description>&lt;p&gt;DTS is nrf52840dk_nrf52840.dts without changes&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: DSPI example on Zephyr / nRF Connect SDK</title><link>https://devzone.nordicsemi.com/thread/423380?ContentTypeID=1</link><pubDate>Tue, 02 May 2023 17:47:10 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:7bd98ae2-a99b-477f-b422-1167fd4598ba</guid><dc:creator>Thurow</dc:creator><description>&lt;p&gt;The overlay:&lt;/p&gt;
&lt;p&gt;&lt;code&gt;&amp;amp;pinctrl {&lt;/code&gt;&lt;br /&gt;&lt;code&gt;&amp;nbsp;&amp;nbsp; &amp;nbsp;spi1_default: spi1_default {&lt;/code&gt;&lt;br /&gt;&lt;code&gt;&amp;nbsp;&amp;nbsp; &amp;nbsp;&amp;nbsp;&amp;nbsp; &amp;nbsp;group1 {&lt;/code&gt;&lt;br /&gt;&lt;code&gt;&amp;nbsp;&amp;nbsp; &amp;nbsp;&amp;nbsp;&amp;nbsp; &amp;nbsp;&amp;nbsp;&amp;nbsp; &amp;nbsp;psels = &amp;lt;NRF_PSEL(SPIM_SCK, 0, 13)&amp;gt;,&lt;/code&gt;&lt;br /&gt;&lt;code&gt;&amp;nbsp;&amp;nbsp; &amp;nbsp;&amp;nbsp;&amp;nbsp; &amp;nbsp;&amp;nbsp;&amp;nbsp; &amp;nbsp;&amp;nbsp;&amp;nbsp; &amp;nbsp;&amp;nbsp;&amp;nbsp; &amp;nbsp;&amp;lt;NRF_PSEL(SPIM_MOSI, 0, 14)&amp;gt;,&lt;/code&gt;&lt;br /&gt;&lt;code&gt;&amp;nbsp;&amp;nbsp; &amp;nbsp;&amp;nbsp;&amp;nbsp; &amp;nbsp;&amp;nbsp;&amp;nbsp; &amp;nbsp;&amp;nbsp;&amp;nbsp; &amp;nbsp;&amp;nbsp;&amp;nbsp; &amp;nbsp;&amp;lt;NRF_PSEL(SPIM_MISO, 0, 15)&amp;gt;;&lt;/code&gt;&lt;br /&gt;&lt;code&gt;&amp;nbsp;&amp;nbsp; &amp;nbsp;&amp;nbsp;&amp;nbsp; &amp;nbsp;};&lt;/code&gt;&lt;br /&gt;&lt;code&gt;&amp;nbsp;&amp;nbsp; &amp;nbsp;};&lt;/code&gt;&lt;br /&gt;&lt;br /&gt;&lt;code&gt;&amp;nbsp;&amp;nbsp; &amp;nbsp;spi1_sleep: spi1_sleep {&lt;/code&gt;&lt;br /&gt;&lt;code&gt;&amp;nbsp;&amp;nbsp; &amp;nbsp;&amp;nbsp;&amp;nbsp; &amp;nbsp;group1 {&lt;/code&gt;&lt;br /&gt;&lt;code&gt;&amp;nbsp;&amp;nbsp; &amp;nbsp;&amp;nbsp;&amp;nbsp; &amp;nbsp;&amp;nbsp;&amp;nbsp; &amp;nbsp;psels = &amp;lt;NRF_PSEL(SPIM_SCK, 0, 13)&amp;gt;,&lt;/code&gt;&lt;br /&gt;&lt;code&gt;&amp;nbsp;&amp;nbsp; &amp;nbsp;&amp;nbsp;&amp;nbsp; &amp;nbsp;&amp;nbsp;&amp;nbsp; &amp;nbsp;&amp;nbsp;&amp;nbsp; &amp;nbsp;&amp;nbsp;&amp;nbsp; &amp;nbsp;&amp;lt;NRF_PSEL(SPIM_MOSI, 0, 14)&amp;gt;,&lt;/code&gt;&lt;br /&gt;&lt;code&gt;&amp;nbsp;&amp;nbsp; &amp;nbsp;&amp;nbsp;&amp;nbsp; &amp;nbsp;&amp;nbsp;&amp;nbsp; &amp;nbsp;&amp;nbsp;&amp;nbsp; &amp;nbsp;&amp;nbsp;&amp;nbsp; &amp;nbsp;&amp;lt;NRF_PSEL(SPIM_MISO, 0, 15)&amp;gt;;&lt;/code&gt;&lt;br /&gt;&lt;code&gt;&amp;nbsp;&amp;nbsp; &amp;nbsp;&amp;nbsp;&amp;nbsp; &amp;nbsp;&amp;nbsp;&amp;nbsp; &amp;nbsp;low-power-enable;&lt;/code&gt;&lt;br /&gt;&lt;code&gt;&amp;nbsp;&amp;nbsp; &amp;nbsp;&amp;nbsp;&amp;nbsp; &amp;nbsp;};&lt;/code&gt;&lt;br /&gt;&lt;code&gt;&amp;nbsp;&amp;nbsp; &amp;nbsp;};&lt;/code&gt;&lt;br /&gt;&lt;br /&gt;&lt;code&gt;&amp;nbsp;&amp;nbsp; &amp;nbsp;spi2_default: spi2_default {&lt;/code&gt;&lt;br /&gt;&lt;code&gt;&amp;nbsp;&amp;nbsp; &amp;nbsp;&amp;nbsp;&amp;nbsp; &amp;nbsp;group1 {&lt;/code&gt;&lt;br /&gt;&lt;code&gt;&amp;nbsp;&amp;nbsp; &amp;nbsp;&amp;nbsp;&amp;nbsp; &amp;nbsp;&amp;nbsp;&amp;nbsp; &amp;nbsp;psels = &amp;lt;NRF_PSEL(SPIM_SCK, 0, 16)&amp;gt;,&lt;/code&gt;&lt;br /&gt;&lt;code&gt;&amp;nbsp;&amp;nbsp; &amp;nbsp;&amp;nbsp;&amp;nbsp; &amp;nbsp;&amp;nbsp;&amp;nbsp; &amp;nbsp;&amp;nbsp;&amp;nbsp; &amp;nbsp;&amp;nbsp;&amp;nbsp; &amp;nbsp;&amp;lt;NRF_PSEL(SPIM_MOSI, 0, 25)&amp;gt;,&lt;/code&gt;&lt;br /&gt;&lt;code&gt;&amp;nbsp;&amp;nbsp; &amp;nbsp;&amp;nbsp;&amp;nbsp; &amp;nbsp;&amp;nbsp;&amp;nbsp; &amp;nbsp;&amp;nbsp;&amp;nbsp; &amp;nbsp;&amp;nbsp;&amp;nbsp; &amp;nbsp;&amp;lt;NRF_PSEL(SPIM_MISO, 0, 24)&amp;gt;;&lt;/code&gt;&lt;br /&gt;&lt;code&gt;&amp;nbsp;&amp;nbsp; &amp;nbsp;&amp;nbsp;&amp;nbsp; &amp;nbsp;};&lt;/code&gt;&lt;br /&gt;&lt;code&gt;&amp;nbsp;&amp;nbsp; &amp;nbsp;};&lt;/code&gt;&lt;br /&gt;&lt;br /&gt;&lt;code&gt;&amp;nbsp;&amp;nbsp; &amp;nbsp;spi2_sleep: spi2_sleep {&lt;/code&gt;&lt;br /&gt;&lt;code&gt;&amp;nbsp;&amp;nbsp; &amp;nbsp;&amp;nbsp;&amp;nbsp; &amp;nbsp;group1 {&lt;/code&gt;&lt;br /&gt;&lt;code&gt;&amp;nbsp;&amp;nbsp; &amp;nbsp;&amp;nbsp;&amp;nbsp; &amp;nbsp;&amp;nbsp;&amp;nbsp; &amp;nbsp;psels = &amp;lt;NRF_PSEL(SPIM_SCK, 0, 16)&amp;gt;,&lt;/code&gt;&lt;br /&gt;&lt;code&gt;&amp;nbsp;&amp;nbsp; &amp;nbsp;&amp;nbsp;&amp;nbsp; &amp;nbsp;&amp;nbsp;&amp;nbsp; &amp;nbsp;&amp;nbsp;&amp;nbsp; &amp;nbsp;&amp;nbsp;&amp;nbsp; &amp;nbsp;&amp;lt;NRF_PSEL(SPIM_MOSI, 0, 25)&amp;gt;,&lt;/code&gt;&lt;br /&gt;&lt;code&gt;&amp;nbsp;&amp;nbsp; &amp;nbsp;&amp;nbsp;&amp;nbsp; &amp;nbsp;&amp;nbsp;&amp;nbsp; &amp;nbsp;&amp;nbsp;&amp;nbsp; &amp;nbsp;&amp;nbsp;&amp;nbsp; &amp;nbsp;&amp;lt;NRF_PSEL(SPIM_MISO, 0, 24)&amp;gt;;&lt;/code&gt;&lt;br /&gt;&lt;code&gt;&amp;nbsp;&amp;nbsp; &amp;nbsp;&amp;nbsp;&amp;nbsp; &amp;nbsp;&amp;nbsp;&amp;nbsp; &amp;nbsp;low-power-enable;&lt;/code&gt;&lt;br /&gt;&lt;code&gt;&amp;nbsp;&amp;nbsp; &amp;nbsp;&amp;nbsp;&amp;nbsp; &amp;nbsp;};&lt;/code&gt;&lt;br /&gt;&lt;code&gt;&amp;nbsp;&amp;nbsp; &amp;nbsp;};&lt;/code&gt;&lt;br /&gt;&lt;code&gt;};&lt;/code&gt;&lt;br /&gt;&lt;br /&gt;&lt;code&gt;&amp;amp;spi1 {&lt;/code&gt;&lt;br /&gt;&lt;code&gt;&amp;nbsp;&amp;nbsp; &amp;nbsp;compatible = &amp;quot;nordic,nrf-spi&amp;quot;;&lt;/code&gt;&lt;br /&gt;&lt;code&gt;&amp;nbsp;&amp;nbsp; &amp;nbsp;status = &amp;quot;okay&amp;quot;;&lt;/code&gt;&lt;br /&gt;&lt;code&gt;&amp;nbsp;&amp;nbsp; &amp;nbsp;pinctrl-0 = &amp;lt;&amp;amp;spi1_default&amp;gt;;&lt;/code&gt;&lt;br /&gt;&lt;code&gt;&amp;nbsp;&amp;nbsp; &amp;nbsp;pinctrl-1 = &amp;lt;&amp;amp;spi1_sleep&amp;gt;;&lt;/code&gt;&lt;br /&gt;&lt;code&gt;&amp;nbsp;&amp;nbsp; &amp;nbsp;cs-gpios = &amp;lt;&amp;amp;gpio0 11 GPIO_ACTIVE_LOW&amp;gt;;&lt;/code&gt;&lt;br /&gt;&lt;code&gt;};&lt;/code&gt;&lt;br /&gt;&lt;br /&gt;&lt;code&gt;&amp;amp;spi2 {&lt;/code&gt;&lt;br /&gt;&lt;code&gt;&amp;nbsp;&amp;nbsp; &amp;nbsp;compatible = &amp;quot;nordic,nrf-spi&amp;quot;;&lt;/code&gt;&lt;br /&gt;&lt;code&gt;&amp;nbsp;&amp;nbsp; &amp;nbsp;status = &amp;quot;okay&amp;quot;;&lt;/code&gt;&lt;br /&gt;&lt;code&gt;&amp;nbsp;&amp;nbsp; &amp;nbsp;pinctrl-0 = &amp;lt;&amp;amp;spi2_default&amp;gt;;&lt;/code&gt;&lt;br /&gt;&lt;code&gt;&amp;nbsp;&amp;nbsp; &amp;nbsp;pinctrl-1 = &amp;lt;&amp;amp;spi2_sleep&amp;gt;;&lt;/code&gt;&lt;br /&gt;&lt;code&gt;&amp;nbsp;&amp;nbsp; &amp;nbsp;cs-gpios = &amp;lt;&amp;amp;gpio0 11 GPIO_ACTIVE_LOW&amp;gt;;&lt;/code&gt;&lt;br /&gt;&lt;code&gt;};&lt;/code&gt;&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: DSPI example on Zephyr / nRF Connect SDK</title><link>https://devzone.nordicsemi.com/thread/423364?ContentTypeID=1</link><pubDate>Tue, 02 May 2023 15:33:14 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:9d2ada00-27b5-41e1-97b7-c2dfafad4b1a</guid><dc:creator>haakonsh</dc:creator><description>&lt;p&gt;&amp;quot;CONFIG_NRFX_SPI1=y&amp;quot;&lt;/p&gt;
&lt;p&gt;I think you have defined&amp;nbsp;the spi1/spim1 DTS node as &amp;#39;spi&amp;#39; instead of &amp;#39;spim&amp;#39;. Can you share your DTS files and overlays?&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: DSPI example on Zephyr / nRF Connect SDK</title><link>https://devzone.nordicsemi.com/thread/423356?ContentTypeID=1</link><pubDate>Tue, 02 May 2023 14:56:55 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:2c5adc47-01db-43bd-943f-643571efc91e</guid><dc:creator>Thurow</dc:creator><description>&lt;p&gt;Yes, &lt;span&gt;#include&lt;/span&gt;&lt;span&gt; &lt;/span&gt;&lt;span&gt;&amp;lt;nrfx_spim.h&amp;gt;&lt;/span&gt;&lt;/p&gt;
&lt;p&gt;&lt;span&gt;&lt;/span&gt;&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: DSPI example on Zephyr / nRF Connect SDK</title><link>https://devzone.nordicsemi.com/thread/423355?ContentTypeID=1</link><pubDate>Tue, 02 May 2023 14:53:55 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:e5ab6409-ae7b-4240-979f-7f8c5f664c8b</guid><dc:creator>Thurow</dc:creator><description>&lt;p&gt;&lt;span&gt;build/zephyr/.config:&lt;/span&gt;&lt;/p&gt;
&lt;p&gt;&lt;span&gt;&lt;pre class="ui-code" data-mode="c_cpp"&gt;CONFIG_SENSOR=y
CONFIG_TEMP_NRF5=y
CONFIG_GPIO=y
# CONFIG_KSCAN is not set
# CONFIG_WIFI is not set
CONFIG_SPI=y
CONFIG_ADC_INIT_PRIORITY=50
CONFIG_GPIO_INIT_PRIORITY=40
# CONFIG_WATCHDOG is not set
# CONFIG_MODEM is not set
# CONFIG_UART_INTERRUPT_DRIVEN is not set
# CONFIG_I2C is not set
# CONFIG_BT_HCI_ACL_FLOW_CONTROL is not set
CONFIG_BT_HCI_VS_EXT=y
CONFIG_BOARD=&amp;quot;nrf52840dk_nrf52840&amp;quot;
CONFIG_BT_CTLR=y
CONFIG_SOC=&amp;quot;nRF52840_QIAA&amp;quot;
CONFIG_SOC_SERIES=&amp;quot;nrf52&amp;quot;
CONFIG_NUM_IRQS=48
CONFIG_SYS_CLOCK_HW_CYCLES_PER_SEC=32768
CONFIG_CLOCK_CONTROL_INIT_PRIORITY=30
CONFIG_FLASH_SIZE=1024
CONFIG_FLASH_BASE_ADDRESS=0x0
CONFIG_ICACHE_LINE_SIZE=32
CONFIG_DCACHE_LINE_SIZE=32
CONFIG_HEAP_MEM_POOL_SIZE=0
CONFIG_ROM_START_OFFSET=0
CONFIG_PINCTRL=y
# CONFIG_RESET is not set
CONFIG_CLOCK_CONTROL=y
CONFIG_SOC_HAS_TIMING_FUNCTIONS=y
CONFIG_ARCH_HAS_CUSTOM_BUSY_WAIT=y
CONFIG_PM=y
# CONFIG_PM_DEVICE is not set
CONFIG_LOG_DOMAIN_NAME=&amp;quot;&amp;quot;
CONFIG_NRF_RTC_TIMER=y
CONFIG_SYS_CLOCK_TICKS_PER_SEC=32768
CONFIG_BUILD_OUTPUT_HEX=y
CONFIG_SERIAL_INIT_PRIORITY=55
# CONFIG_FPU is not set
# CONFIG_MBEDTLS is not set
# CONFIG_CODE_DATA_RELOCATION is not set
# CONFIG_CPU_HAS_CUSTOM_FIXED_SOC_MPU_REGIONS is not set
CONFIG_TINYCRYPT=y
CONFIG_SERIAL=y
CONFIG_MAIN_STACK_SIZE=2048
# CONFIG_SRAM_VECTOR_TABLE is not set
CONFIG_BT_USER_PHY_UPDATE=y
CONFIG_MP_MAX_NUM_CPUS=1
CONFIG_PLATFORM_SPECIFIC_INIT=y
CONFIG_HAS_DTS=y
# Devicetree Info
CONFIG_DT_HAS_ARDUINO_UNO_ADC_ENABLED=y
CONFIG_DT_HAS_ARDUINO_HEADER_R3_ENABLED=y
CONFIG_DT_HAS_ARM_ARMV7M_ITM_ENABLED=y
CONFIG_DT_HAS_ARM_CORTEX_M4F_ENABLED=y
CONFIG_DT_HAS_ARM_CRYPTOCELL_310_ENABLED=y
CONFIG_DT_HAS_ARM_V7M_NVIC_ENABLED=y
CONFIG_DT_HAS_FIXED_PARTITIONS_ENABLED=y
CONFIG_DT_HAS_GPIO_KEYS_ENABLED=y
CONFIG_DT_HAS_GPIO_LEDS_ENABLED=y
CONFIG_DT_HAS_MMIO_SRAM_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_ACL_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_CC310_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_CCM_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_CLOCK_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_ECB_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_EGU_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_FICR_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_GPIO_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_GPIOTE_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_IEEE802154_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_MWU_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_PINCTRL_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_POWER_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_PPI_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_PWM_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_QSPI_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_RADIO_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_RNG_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_RTC_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_SAADC_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_SPI_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_SPIM_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_SWI_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_TEMP_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_TIMER_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_TWI_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_UARTE_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_UICR_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_USBD_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_WDT_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF52_FLASH_CONTROLLER_ENABLED=y
CONFIG_DT_HAS_NORDIC_QSPI_NOR_ENABLED=y
CONFIG_DT_HAS_PWM_LEDS_ENABLED=y
CONFIG_DT_HAS_SOC_NV_FLASH_ENABLED=y
CONFIG_DT_HAS_ZEPHYR_BT_HCI_ENTROPY_ENABLED=y
# end of Devicetree Info
# Modules
# Available modules.
# nrf (T:/tools/ncs/v2.3.0/nrf)
CONFIG_NUM_METAIRQ_PRIORITIES=0
CONFIG_LOG_BUFFER_SIZE=1024
# CONFIG_INIT_STACKS is not set
# Nordic nRF Connect
CONFIG_WARN_EXPERIMENTAL=y
CONFIG_PRIVILEGED_STACK_SIZE=1024
CONFIG_BT_BUF_CMD_TX_COUNT=2
CONFIG_ENTROPY_GENERATOR=y
CONFIG_INIT_ARCH_HW_AT_BOOT=y
CONFIG_NORDIC_QSPI_NOR_FLASH_LAYOUT_PAGE_SIZE=4096
# CONFIG_NCS_SAMPLES_DEFAULTS is not set
CONFIG_LOG_DEFAULT_LEVEL=3
# Image build variants
# CONFIG_NCS_MCUBOOT_IN_BUILD is not set
# end of Image build variants
# CONFIG_NCS_SAMPLE_MCUMGR_BT_OTA_DFU_SPEEDUP is not set
CONFIG_BT_L2CAP_TX_MTU=498
CONFIG_BT_BUF_ACL_TX_SIZE=502
CONFIG_BT_BUF_ACL_RX_SIZE=502
CONFIG_BT_CTLR_DATA_LENGTH_MAX=251
# Bootloader
# CONFIG_BUILD_S1_VARIANT is not set
# CONFIG_SECURE_BOOT is not set
CONFIG_PM_PARTITION_SIZE_PROVISION=0x1000
# CONFIG_B0_MIN_PARTITION_SIZE is not set
CONFIG_PM_PARTITION_SIZE_B0_IMAGE=0x8000
# CONFIG_SECURE_BOOT_CRYPTO is not set
# Secure Boot firmware validation
CONFIG_SB_VALIDATION_INFO_MAGIC=0x86518483
CONFIG_SB_VALIDATION_POINTER_MAGIC=0x6919b47e
CONFIG_SB_VALIDATION_INFO_CRYPTO_ID=1
CONFIG_SB_VALIDATION_INFO_VERSION=2
CONFIG_SB_VALIDATION_METADATA_OFFSET=0
CONFIG_SB_VALIDATE_FW_SIGNATURE=y
# end of Secure Boot firmware validation
# end of Bootloader
# Bluetooth Low Energy
CONFIG_BT_MAX_CONN=1
CONFIG_BT_LL_SOFTDEVICE=y
# SoftDevice Controller
CONFIG_BT_LL_SOFTDEVICE_BUILD_TYPE_LIB=y
CONFIG_BT_HCI_TX_STACK_SIZE=1536
CONFIG_BT_RX_STACK_SIZE=1536
# CONFIG_BT_CTLR_SDC_LLPM is not set
CONFIG_BT_CTLR_SDC_PERIPHERAL_COUNT=1
CONFIG_BT_CTLR_SDC_MAX_CONN_EVENT_LEN_DEFAULT=7500
CONFIG_BT_CTLR_SDC_TX_PACKET_COUNT=3
CONFIG_BT_CTLR_SDC_RX_PACKET_COUNT=2
CONFIG_BT_CTLR_SDC_SCAN_BUFFER_COUNT=3
CONFIG_BT_CTLR_SDC_PERIODIC_SYNC_BUFFER_COUNT=2
CONFIG_BT_CTLR_SDC_RX_PRIO=6
# CONFIG_BT_CTLR_DF is not set
CONFIG_BT_LL_SOFTDEVICE_PERIPHERAL=y
# CONFIG_BT_LL_SOFTDEVICE_MULTIROLE is not set
CONFIG_BT_SDC_ADDITIONAL_MEMORY=0
CONFIG_BT_CTLR_ECDH_LIB_OBERON=y
# CONFIG_BT_CTLR_ECDH_LIB_TINYCRYPT is not set
CONFIG_BT_CTLR_ECDH_STACK_SIZE=900
# CONFIG_BT_CTLR_ECDH_IN_MPSL_WORK is not set
# CONFIG_BT_CTLR_LE_POWER_CONTROL is not set
# end of SoftDevice Controller
# BLE Libraries
# CONFIG_BT_GATT_POOL is not set
# CONFIG_BT_GATT_DM is not set
# CONFIG_BT_ADV_PROV is not set
# CONFIG_BT_CONN_CTX is not set
# Bluetooth Services
# CONFIG_BT_AMS_CLIENT is not set
# CONFIG_BT_ANCS_CLIENT is not set
# CONFIG_BT_BAS_CLIENT is not set
# CONFIG_BT_BMS is not set
# CONFIG_BT_CTS_CLIENT is not set
# CONFIG_BT_DFU_SMP is not set
# CONFIG_BT_GATTP is not set
# CONFIG_BT_HIDS is not set
# CONFIG_BT_HOGP is not set
# CONFIG_BT_LBS is not set
# CONFIG_BT_NSMS is not set
# CONFIG_BT_NUS is not set
# CONFIG_BT_NUS_CLIENT is not set
# CONFIG_BT_RSCS is not set
# CONFIG_BT_THROUGHPUT is not set
# CONFIG_BT_LATENCY is not set
# CONFIG_BT_LATENCY_CLIENT is not set
# CONFIG_BT_HRS_CLIENT is not set
# CONFIG_BT_DDFS is not set
# CONFIG_BT_MDS is not set
# CONFIG_BT_CGMS is not set
# CONFIG_BT_FAST_PAIR is not set
CONFIG_BT_DIS=y
CONFIG_BT_DIS_FW_REV=y
CONFIG_BT_DIS_FW_REV_STR=&amp;quot;0.1&amp;quot;
CONFIG_BT_GATT_AUTO_SEC_REQ=y
# end of Bluetooth Services
# BLE over nRF RPC
# CONFIG_BT_RPC is not set
# CONFIG_BT_RPC_STACK is not set
# CONFIG_BT_CENTRAL is not set
CONFIG_BT_PERIPHERAL=y
# CONFIG_BT_OBSERVER is not set
CONFIG_BT_BROADCASTER=y
CONFIG_BT_CONN=y
# CONFIG_BT_REMOTE_VERSION is not set
CONFIG_BT_PHY_UPDATE=y
CONFIG_BT_DATA_LEN_UPDATE=y
# CONFIG_BT_EXT_ADV is not set
# CONFIG_BT_DIS_SETTINGS is not set
CONFIG_BT_DIS_MODEL=&amp;quot;Rope Encoder&amp;quot;
CONFIG_BT_DIS_MANUF=&amp;quot;FlexiJet&amp;quot;
# CONFIG_BT_DIS_PNP is not set
# CONFIG_BT_DIS_SERIAL_NUMBER is not set
CONFIG_BT_DIS_HW_REV=y
CONFIG_BT_DIS_HW_REV_STR=&amp;quot;0.1&amp;quot;
# CONFIG_BT_DIS_SW_REV is not set
CONFIG_BT_BAS=y
# CONFIG_BT_BAS_LOG_LEVEL_OFF is not set
# CONFIG_BT_BAS_LOG_LEVEL_ERR is not set
# CONFIG_BT_BAS_LOG_LEVEL_WRN is not set
CONFIG_BT_BAS_LOG_LEVEL_INF=y
# CONFIG_BT_BAS_LOG_LEVEL_DBG is not set
CONFIG_BT_BAS_LOG_LEVEL=3
# CONFIG_BT_HRS is not set
# CONFIG_BT_TPS is not set
# CONFIG_BT_IAS is not set
# CONFIG_BT_IAS_CLIENT is not set
CONFIG_BT_IAS_CLIENT_LOG_LEVEL=3
CONFIG_BT_IAS_CLIENT_LOG_LEVEL_INHERIT=y
# CONFIG_BT_IAS_CLIENT_LOG_LEVEL_OFF is not set
# CONFIG_BT_IAS_CLIENT_LOG_LEVEL_ERR is not set
# CONFIG_BT_IAS_CLIENT_LOG_LEVEL_WRN is not set
# CONFIG_BT_IAS_CLIENT_LOG_LEVEL_INF is not set
# CONFIG_BT_IAS_CLIENT_LOG_LEVEL_DBG is not set
# CONFIG_BT_IAS_LOG_LEVEL_OFF is not set
# CONFIG_BT_IAS_LOG_LEVEL_ERR is not set
# CONFIG_BT_IAS_LOG_LEVEL_WRN is not set
CONFIG_BT_IAS_LOG_LEVEL_INF=y
# CONFIG_BT_IAS_LOG_LEVEL_DBG is not set
CONFIG_BT_IAS_LOG_LEVEL=3
# CONFIG_BT_OTS is not set
# CONFIG_BT_OTS_CLIENT is not set
CONFIG_BT_BUF_ACL_TX_COUNT=3
CONFIG_BT_BUF_ACL_RX_COUNT=6
CONFIG_BT_BUF_EVT_RX_SIZE=68
CONFIG_BT_BUF_EVT_RX_COUNT=10
CONFIG_BT_BUF_EVT_DISCARDABLE_SIZE=43
CONFIG_BT_BUF_EVT_DISCARDABLE_COUNT=3
CONFIG_BT_BUF_CMD_TX_SIZE=65
CONFIG_BT_HAS_HCI_VS=y
CONFIG_BT_HCI_VS=y
# CONFIG_BT_HCI_VS_EVT is not set
# CONFIG_BT_HCI_VS_FATAL_ERROR is not set
# CONFIG_BT_WAIT_NOP is not set
CONFIG_BT_RPA=y
CONFIG_BT_ASSERT=y
CONFIG_BT_ASSERT_VERBOSE=y
# CONFIG_BT_ASSERT_PANIC is not set
CONFIG_BT_DEBUG_NONE=y
# CONFIG_BT_DEBUG_LOG is not set
# CONFIG_BT_DEBUG_MONITOR_UART is not set
# CONFIG_BT_DEBUG_MONITOR_RTT is not set
CONFIG_BT_LONG_WQ=y
CONFIG_BT_LONG_WQ_STACK_SIZE=1300
CONFIG_BT_LONG_WQ_PRIO=10
CONFIG_BT_HCI_HOST=y
# CONFIG_BT_HCI_TX_STACK_SIZE_WITH_PROMPT is not set
CONFIG_BT_HCI_TX_PRIO=7
CONFIG_BT_HCI_RESERVE=0
# CONFIG_BT_RECV_BLOCKING is not set
# CONFIG_BT_RECV_WORKQ_SYS is not set
CONFIG_BT_RECV_WORKQ_BT=y
CONFIG_BT_RX_PRIO=8
CONFIG_BT_DRIVER_RX_HIGH_PRIO=6
# CONFIG_BT_AUDIO is not set
# CONFIG_BT_FILTER_ACCEPT_LIST is not set
CONFIG_BT_LIM_ADV_TIMEOUT=30
CONFIG_BT_CONN_TX_MAX=3
CONFIG_BT_AUTO_PHY_UPDATE=y
CONFIG_BT_USER_DATA_LEN_UPDATE=y
CONFIG_BT_AUTO_DATA_LEN_UPDATE=y
# CONFIG_BT_REMOTE_INFO is not set
CONFIG_BT_SMP=y
# CONFIG_BT_PRIVACY is not set
# CONFIG_BT_SIGNING is not set
# CONFIG_BT_SMP_APP_PAIRING_ACCEPT is not set
# CONFIG_BT_SMP_SC_PAIR_ONLY is not set
# CONFIG_BT_SMP_SC_ONLY is not set
# CONFIG_BT_SMP_OOB_LEGACY_PAIR_ONLY is not set
# CONFIG_BT_SMP_DISABLE_LEGACY_JW_PASSKEY is not set
# CONFIG_BT_SMP_ALLOW_UNAUTH_OVERWRITE is not set
# CONFIG_BT_ID_UNPAIR_MATCHING_BONDS is not set
# CONFIG_BT_ID_ALLOW_UNAUTH_OVERWRITE is not set
# CONFIG_BT_FIXED_PASSKEY is not set
# CONFIG_BT_USE_DEBUG_KEYS is not set
CONFIG_BT_BONDABLE=y
# CONFIG_BT_BONDING_REQUIRED is not set
# CONFIG_BT_STORE_DEBUG_KEYS is not set
CONFIG_BT_SMP_ENFORCE_MITM=y
# CONFIG_BT_KEYS_OVERWRITE_OLDEST is not set
CONFIG_BT_SMP_MIN_ENC_KEY_SIZE=7
CONFIG_BT_L2CAP_TX_BUF_COUNT=3
CONFIG_BT_L2CAP_TX_FRAG_COUNT=2
# CONFIG_BT_L2CAP_DYNAMIC_CHANNEL is not set
CONFIG_BT_L2CAP_LOG_LEVEL=3
CONFIG_BT_L2CAP_LOG_LEVEL_INHERIT=y
# CONFIG_BT_L2CAP_LOG_LEVEL_OFF is not set
# CONFIG_BT_L2CAP_LOG_LEVEL_ERR is not set
# CONFIG_BT_L2CAP_LOG_LEVEL_WRN is not set
# CONFIG_BT_L2CAP_LOG_LEVEL_INF is not set
# CONFIG_BT_L2CAP_LOG_LEVEL_DBG is not set
# CONFIG_BT_ATT_ENFORCE_FLOW is not set
CONFIG_BT_ATT_PREPARE_COUNT=0
CONFIG_BT_ATT_RETRY_ON_SEC_ERR=y
CONFIG_BT_GATT_SERVICE_CHANGED=y
# CONFIG_BT_GATT_DYNAMIC_DB is not set
CONFIG_BT_GATT_CACHING=y
# CONFIG_BT_GATT_NOTIFY_MULTIPLE is not set
# CONFIG_BT_GATT_ENFORCE_CHANGE_UNAWARE is not set
CONFIG_BT_GATT_ENFORCE_SUBSCRIPTION=y
# CONFIG_BT_GATT_CLIENT is not set
CONFIG_BT_GATT_READ_MULTIPLE=y
CONFIG_BT_GATT_READ_MULT_VAR_LEN=y
CONFIG_BT_GAP_AUTO_UPDATE_CONN_PARAMS=y
CONFIG_BT_GAP_PERIPHERAL_PREF_PARAMS=y
CONFIG_BT_PERIPHERAL_PREF_MIN_INT=24
CONFIG_BT_PERIPHERAL_PREF_MAX_INT=40
CONFIG_BT_PERIPHERAL_PREF_LATENCY=0
CONFIG_BT_PERIPHERAL_PREF_TIMEOUT=42
CONFIG_BT_MAX_PAIRED=1
CONFIG_BT_CREATE_CONN_TIMEOUT=3
CONFIG_BT_CONN_PARAM_UPDATE_TIMEOUT=5000
CONFIG_BT_CONN_PARAM_RETRY_COUNT=3
CONFIG_BT_CONN_PARAM_RETRY_TIMEOUT=5000
# CONFIG_BT_DEVICE_NAME_DYNAMIC is not set
CONFIG_BT_DEVICE_NAME=&amp;quot;Rope Encoder&amp;quot;
# CONFIG_BT_DEVICE_APPEARANCE_DYNAMIC is not set
CONFIG_BT_DEVICE_APPEARANCE=1344
CONFIG_BT_ID_MAX=1
CONFIG_BT_ECC=y
# CONFIG_BT_TINYCRYPT_ECC is not set
# CONFIG_BT_HOST_CCM is not set
# CONFIG_BT_LOG_SNIFFER_INFO is not set
# CONFIG_BT_TESTING is not set
# CONFIG_BT_BREDR is not set
# CONFIG_BT_HCI_VS_EVT_USER is not set
CONFIG_BT_CRYPTO=y
# CONFIG_BT_DEBUG_CRYPTO is not set
CONFIG_BT_CRYPTO_LOG_LEVEL=3
CONFIG_BT_CRYPTO_LOG_LEVEL_INHERIT=y
# CONFIG_BT_CRYPTO_LOG_LEVEL_OFF is not set
# CONFIG_BT_CRYPTO_LOG_LEVEL_ERR is not set
# CONFIG_BT_CRYPTO_LOG_LEVEL_WRN is not set
# CONFIG_BT_CRYPTO_LOG_LEVEL_INF is not set
# CONFIG_BT_CRYPTO_LOG_LEVEL_DBG is not set
# end of BLE over nRF RPC
# end of Bluetooth Low Energy
# DFU
# CONFIG_DFU_MULTI_IMAGE is not set
# CONFIG_DFU_TARGET is not set
# end of DFU
# CONFIG_ESB is not set
# CONFIG_ESB_LOG_LEVEL_OFF is not set
# CONFIG_ESB_LOG_LEVEL_ERR is not set
# CONFIG_ESB_LOG_LEVEL_WRN is not set
CONFIG_ESB_LOG_LEVEL_INF=y
# CONFIG_ESB_LOG_LEVEL_DBG is not set
CONFIG_ESB_LOG_LEVEL=3
# Peripheral CPU DFU (PCD)
# CONFIG_PCD is not set
# CONFIG_PCD_APP is not set
# CONFIG_PCD_NET is not set
# end of Peripheral CPU DFU (PCD)
# Networking
# Application protocols
# nRF Cloud
# Client ID (nRF Cloud Device ID)
CONFIG_NRF_CLOUD_CLIENT_ID_SRC_COMPILE_TIME=y
CONFIG_NRF_CLOUD_CLIENT_ID=&amp;quot;my-client-id&amp;quot;
# end of Client ID (nRF Cloud Device ID)
# CONFIG_NRF_CLOUD_MQTT is not set
# CONFIG_NRF_CLOUD_FOTA is not set
# CONFIG_NRF_CLOUD_FOTA_FULL_MODEM_UPDATE is not set
# CONFIG_NRF_CLOUD_REST is not set
# CONFIG_NRF_CLOUD_ALERTS is not set
# CONFIG_NRF_CLOUD_ALERTS_LOG_LEVEL_OFF is not set
# CONFIG_NRF_CLOUD_ALERTS_LOG_LEVEL_ERR is not set
# CONFIG_NRF_CLOUD_ALERTS_LOG_LEVEL_WRN is not set
CONFIG_NRF_CLOUD_ALERTS_LOG_LEVEL_INF=y
# CONFIG_NRF_CLOUD_ALERTS_LOG_LEVEL_DBG is not set
CONFIG_NRF_CLOUD_ALERTS_LOG_LEVEL=3
# CONFIG_NRF_CLOUD_GATEWAY is not set
# CONFIG_NRF_CLOUD_LOG_LEVEL_OFF is not set
# CONFIG_NRF_CLOUD_LOG_LEVEL_ERR is not set
# CONFIG_NRF_CLOUD_LOG_LEVEL_WRN is not set
CONFIG_NRF_CLOUD_LOG_LEVEL_INF=y
# CONFIG_NRF_CLOUD_LOG_LEVEL_DBG is not set
CONFIG_NRF_CLOUD_LOG_LEVEL=3
# end of nRF Cloud
# CONFIG_REST_CLIENT is not set
# CONFIG_DOWNLOAD_CLIENT is not set
# CONFIG_AWS_IOT is not set
# CONFIG_AWS_JOBS is not set
# CONFIG_AZURE_IOT_HUB is not set
# Self-Registration (Zi ZHu Ce)
# end of Self-Registration (Zi ZHu Ce)
# CONFIG_ICAL_PARSER is not set
# CONFIG_FTP_CLIENT is not set
# CONFIG_LWM2M_CLIENT_UTILS is not set
# CONFIG_WIFI_CREDENTIALS is not set
# CONFIG_WIFI_CREDENTIALS_STATIC is not set
# CONFIG_MQTT_HELPER is not set
# end of Application protocols
# end of Networking
# NFC
# CONFIG_NFC_NDEF is not set
# CONFIG_NFC_NDEF_PARSER is not set
# CONFIG_NFC_NDEF_PAYLOAD_TYPE_COMMON is not set
# CONFIG_NFC_T2T_PARSER is not set
# CONFIG_NFC_T4T_NDEF_FILE is not set
# CONFIG_NFC_T4T_ISODEP is not set
# CONFIG_NFC_T4T_APDU is not set
# CONFIG_NFC_T4T_CC_FILE is not set
# CONFIG_NFC_T4T_HL_PROCEDURE is not set
# CONFIG_NFC_PLATFORM is not set
# CONFIG_NFC_TNEP_TAG is not set
# CONFIG_NFC_TNEP_POLLER is not set
# CONFIG_NFC_TNEP_CH is not set
# end of NFC
# CONFIG_APP_EVENT_MANAGER is not set
# CONFIG_NRF_PROFILER is not set
# CONFIG_FW_INFO is not set
# Debug
# CONFIG_PPI_TRACE is not set
# CONFIG_CPU_LOAD is not set
# end of Debug
# CONFIG_SHELL_BT_NUS is not set
# CONFIG_MPSL_FEM_ONLY is not set
CONFIG_MPSL_FEM_API_AVAILABLE=y
# CONFIG_MPSL_FEM_DEVICE_CONFIG_254 is not set
# CONFIG_MPSL_FEM_LOG_LEVEL_OFF is not set
# CONFIG_MPSL_FEM_LOG_LEVEL_ERR is not set
# CONFIG_MPSL_FEM_LOG_LEVEL_WRN is not set
CONFIG_MPSL_FEM_LOG_LEVEL_INF=y
# CONFIG_MPSL_FEM_LOG_LEVEL_DBG is not set
CONFIG_MPSL_FEM_LOG_LEVEL=3
CONFIG_MPSL_THREAD_COOP_PRIO=6
CONFIG_MPSL_WORK_STACK_SIZE=1024
CONFIG_MPSL_TIMESLOT_SESSION_COUNT=0
# CONFIG_MPSL_ASSERT_HANDLER is not set
# CONFIG_MPSL_LOG_LEVEL_OFF is not set
# CONFIG_MPSL_LOG_LEVEL_ERR is not set
# CONFIG_MPSL_LOG_LEVEL_WRN is not set
CONFIG_MPSL_LOG_LEVEL_INF=y
# CONFIG_MPSL_LOG_LEVEL_DBG is not set
CONFIG_MPSL_LOG_LEVEL=3
# Partition Manager
# CONFIG_PARTITION_MANAGER_ENABLED is not set
CONFIG_SRAM_SIZE=256
CONFIG_SRAM_BASE_ADDRESS=0x20000000
# Zephyr subsystem configurations
# end of Zephyr subsystem configurations
# NCS subsystem configurations
# CONFIG_PM_SINGLE_IMAGE is not set
CONFIG_PM_EXTERNAL_FLASH_BASE=0
# CONFIG_PM_OVERRIDE_EXTERNAL_DRIVER_CHECK is not set
CONFIG_PM_SRAM_BASE=0x20000000
CONFIG_PM_SRAM_SIZE=0x40000
# end of Partition Manager
# nRF RPC (Remote Procedure Call) library
# end of nRF RPC (Remote Procedure Call) library
# CONFIG_ZIGBEE is not set
# Full Modem Firmware Update Management(FMFU)
# CONFIG_MGMT_FMFU_LOG_LEVEL_OFF is not set
# CONFIG_MGMT_FMFU_LOG_LEVEL_ERR is not set
# CONFIG_MGMT_FMFU_LOG_LEVEL_WRN is not set
CONFIG_MGMT_FMFU_LOG_LEVEL_INF=y
# CONFIG_MGMT_FMFU_LOG_LEVEL_DBG is not set
CONFIG_MGMT_FMFU_LOG_LEVEL=3
# end of Full Modem Firmware Update Management(FMFU)
# CONFIG_CAF is not set
# Nordic IEEE 802.15.4
# end of Nordic IEEE 802.15.4
# CONFIG_DM_MODULE is not set
# Libraries
# Binary libraries
# end of Binary libraries
# CONFIG_ADP536X is not set
# CONFIG_AT_MONITOR is not set
# CONFIG_DISABLE_FLASH_PATCH is not set
# CONFIG_LTE_LINK_CONTROL is not set
CONFIG_NRF_ACL_FLASH_REGION_SIZE=0x1000
CONFIG_FPROTECT_BLOCK_SIZE=0x1000
# CONFIG_FPROTECT is not set
# CONFIG_AT_CUSTOM_CMD is not set
# CONFIG_DK_LIBRARY is not set
# CONFIG_MODEM_INFO is not set
CONFIG_MULTITHREADING_LOCK=y
CONFIG_RESET_ON_FATAL_ERROR=y
# CONFIG_FATAL_ERROR_LOG_LEVEL_OFF is not set
# CONFIG_FATAL_ERROR_LOG_LEVEL_ERR is not set
# CONFIG_FATAL_ERROR_LOG_LEVEL_WRN is not set
CONFIG_FATAL_ERROR_LOG_LEVEL_INF=y
# CONFIG_FATAL_ERROR_LOG_LEVEL_DBG is not set
CONFIG_FATAL_ERROR_LOG_LEVEL=3
# CONFIG_SMS is not set
# CONFIG_SUPL_CLIENT_LIB is not set
# CONFIG_DATE_TIME is not set
# CONFIG_HW_ID_LIBRARY is not set
# CONFIG_RAM_POWER_DOWN_LIBRARY is not set
# CONFIG_WAVE_GEN_LIB is not set
# CONFIG_HW_UNIQUE_KEY_LOAD is not set
CONFIG_HW_UNIQUE_KEY_PARTITION_SIZE=0x1000
# CONFIG_MODEM_JWT is not set
# CONFIG_QOS is not set
# CONFIG_SFLOAT is not set
# CONFIG_CONTIN_ARRAY is not set
# CONFIG_PCM_MIX is not set
# CONFIG_TONE is not set
# CONFIG_PSCM is not set
# CONFIG_DATA_FIFO is not set
# end of Libraries
# Device Drivers
# CONFIG_BT_DRIVER_QUIRK_NO_AUTO_DLE is not set
CONFIG_ENTROPY_CC3XX=y
CONFIG_HW_CC3XX=y
# CONFIG_ETH_RTT is not set
# CONFIG_SENSOR_SIM is not set
# CONFIG_SENSOR_STUB is not set
# CONFIG_PMW3360 is not set
# CONFIG_PAW3212 is not set
# CONFIG_NRF_SW_LPUART is not set
CONFIG_NRFX_GPIOTE_NUM_OF_EVT_HANDLERS=1
CONFIG_CLOCK_CONTROL_MPSL=y
CONFIG_SOC_FLASH_NRF_RADIO_SYNC_MPSL_TIMESLOT_SESSION_COUNT=0
CONFIG_TEMP_NRF5_MPSL=y
# end of Device Drivers
# External libraries
# end of External libraries
# Test
CONFIG_ZTEST_MULTICORE_DEFAULT_SETTINGS=y
# CONFIG_UNITY is not set
# Mocks
# CONFIG_MOCK_NRF_MODEM_AT is not set
# end of Mocks
# end of Test
# end of Nordic nRF Connect
CONFIG_ZEPHYR_NRF_MODULE=y
# end of nrf (T:/tools/ncs/v2.3.0/nrf)
# hostap (T:/tools/ncs/v2.3.0/modules/lib/hostap)
CONFIG_POSIX_MAX_FDS=4
CONFIG_ZEPHYR_HOSTAP_MODULE=y
# end of hostap (T:/tools/ncs/v2.3.0/modules/lib/hostap)
# mcuboot (T:/tools/ncs/v2.3.0/bootloader/mcuboot)
# MCUboot
CONFIG_BOOT_SIGNATURE_KEY_FILE=&amp;quot;&amp;quot;
CONFIG_DT_FLASH_WRITE_BLOCK_SIZE=4
CONFIG_MCUBOOT_USB_SUPPORT=y
# end of MCUboot
CONFIG_ZEPHYR_MCUBOOT_MODULE=y
# end of mcuboot (T:/tools/ncs/v2.3.0/bootloader/mcuboot)
# mbedtls (T:/tools/ncs/v2.3.0/modules/crypto/mbedtls)
CONFIG_ZEPHYR_MBEDTLS_MODULE=y
CONFIG_MBEDTLS_BUILTIN=y
# CONFIG_MBEDTLS_LIBRARY is not set
# end of mbedtls (T:/tools/ncs/v2.3.0/modules/crypto/mbedtls)
# trusted-firmware-m (T:/tools/ncs/v2.3.0/modules/tee/tf-m/trusted-firmware-m)
# CONFIG_BOOTLOADER_MCUBOOT is not set
CONFIG_ZEPHYR_TRUSTED_FIRMWARE_M_MODULE=y
# end of trusted-firmware-m (T:/tools/ncs/v2.3.0/modules/tee/tf-m/trusted-firmware-m)
# cjson (T:/tools/ncs/v2.3.0/modules/lib/cjson)
CONFIG_ZEPHYR_CJSON_MODULE=y
# end of cjson (T:/tools/ncs/v2.3.0/modules/lib/cjson)
# azure-sdk-for-c (T:/tools/ncs/v2.3.0/modules/lib/azure-sdk-for-c)
# CONFIG_AZURE_SDK is not set
CONFIG_ZEPHYR_AZURE_SDK_FOR_C_MODULE=y
# end of azure-sdk-for-c (T:/tools/ncs/v2.3.0/modules/lib/azure-sdk-for-c)
# memfault-firmware-sdk (T:/tools/ncs/v2.3.0/modules/lib/memfault-firmware-sdk)
# CONFIG_MEMFAULT is not set
CONFIG_ZEPHYR_MEMFAULT_FIRMWARE_SDK_MODULE=y
# end of memfault-firmware-sdk (T:/tools/ncs/v2.3.0/modules/lib/memfault-firmware-sdk)
# cirrus-logic (T:/tools/ncs/v2.3.0/modules/hal/cirrus-logic)
# CONFIG_HW_CODEC_CIRRUS_LOGIC is not set
CONFIG_ZEPHYR_CIRRUS_LOGIC_MODULE=y
# end of cirrus-logic (T:/tools/ncs/v2.3.0/modules/hal/cirrus-logic)
# openthread (T:/tools/ncs/v2.3.0/modules/lib/openthread)
# CONFIG_OPENTHREAD is not set
CONFIG_ZEPHYR_OPENTHREAD_MODULE=y
# end of openthread (T:/tools/ncs/v2.3.0/modules/lib/openthread)
# canopennode (T:/tools/ncs/v2.3.0/modules/lib/canopennode)
CONFIG_ZEPHYR_CANOPENNODE_MODULE=y
# end of canopennode (T:/tools/ncs/v2.3.0/modules/lib/canopennode)
# chre (T:/tools/ncs/v2.3.0/modules/lib/chre)
CONFIG_ZEPHYR_CHRE_MODULE=y
# CONFIG_CHRE is not set
# end of chre (T:/tools/ncs/v2.3.0/modules/lib/chre)
# fatfs (T:/tools/ncs/v2.3.0/modules/fs/fatfs)
CONFIG_ZEPHYR_FATFS_MODULE=y
# end of fatfs (T:/tools/ncs/v2.3.0/modules/fs/fatfs)
# hal_nordic (T:/tools/ncs/v2.3.0/modules/hal/nordic)
CONFIG_ZEPHYR_HAL_NORDIC_MODULE=y
CONFIG_HAS_NORDIC_DRIVERS=y
# Nordic drivers
# CONFIG_NRF_802154_SOURCE_HAL_NORDIC is not set
# CONFIG_NRF_802154_RADIO_DRIVER is not set
# CONFIG_NRF_802154_SER_RADIO is not set
# end of Nordic drivers
CONFIG_HAS_NRFX=y
# nrfx drivers
# CONFIG_NRFX_CLOCK is not set
# CONFIG_NRFX_COMP is not set
# CONFIG_NRFX_EGU0 is not set
# CONFIG_NRFX_EGU1 is not set
# CONFIG_NRFX_EGU2 is not set
# CONFIG_NRFX_EGU3 is not set
# CONFIG_NRFX_EGU4 is not set
# CONFIG_NRFX_EGU5 is not set
CONFIG_NRFX_GPIOTE=y
# CONFIG_NRFX_I2S is not set
# CONFIG_NRFX_NFCT is not set
# CONFIG_NRFX_NVMC is not set
# CONFIG_NRFX_PDM is not set
# CONFIG_NRFX_POWER is not set
CONFIG_NRFX_PPI=y
# CONFIG_NRFX_PWM0 is not set
# CONFIG_NRFX_PWM1 is not set
# CONFIG_NRFX_PWM2 is not set
# CONFIG_NRFX_PWM3 is not set
# CONFIG_NRFX_QDEC is not set
# CONFIG_NRFX_QSPI is not set
# CONFIG_NRFX_RNG is not set
# CONFIG_NRFX_RTC0 is not set
# CONFIG_NRFX_RTC1 is not set
# CONFIG_NRFX_RTC2 is not set
# CONFIG_NRFX_SAADC is not set
CONFIG_NRFX_SPI=y
# CONFIG_NRFX_SPI0 is not set
CONFIG_NRFX_SPI1=y
CONFIG_NRFX_SPI2=y
CONFIG_NRFX_SPIM=y
CONFIG_NRFX_SPIM3=y
# CONFIG_NRFX_SYSTICK is not set
# CONFIG_NRFX_TEMP is not set
# CONFIG_NRFX_TIMER0 is not set
# CONFIG_NRFX_TIMER1 is not set
# CONFIG_NRFX_TIMER2 is not set
# CONFIG_NRFX_TIMER3 is not set
# CONFIG_NRFX_TIMER4 is not set
# CONFIG_NRFX_TWI0 is not set
# CONFIG_NRFX_TWI1 is not set
# CONFIG_NRFX_UARTE0 is not set
# CONFIG_NRFX_UARTE1 is not set
# CONFIG_NRFX_USBD is not set
# CONFIG_NRFX_WDT0 is not set
# Peripheral Resource Sharing module
# CONFIG_NRFX_PRS_BOX_0 is not set
# CONFIG_NRFX_PRS_BOX_1 is not set
# CONFIG_NRFX_PRS_BOX_2 is not set
# CONFIG_NRFX_PRS_BOX_3 is not set
# CONFIG_NRFX_PRS_BOX_4 is not set
# end of Peripheral Resource Sharing module
# end of nrfx drivers
# end of hal_nordic (T:/tools/ncs/v2.3.0/modules/hal/nordic)
# liblc3 (T:/tools/ncs/v2.3.0/modules/lib/liblc3)
CONFIG_ZEPHYR_LIBLC3_MODULE=y
# end of liblc3 (T:/tools/ncs/v2.3.0/modules/lib/liblc3)
# littlefs (T:/tools/ncs/v2.3.0/modules/fs/littlefs)
CONFIG_ZEPHYR_LITTLEFS_MODULE=y
# end of littlefs (T:/tools/ncs/v2.3.0/modules/fs/littlefs)
# loramac-node (T:/tools/ncs/v2.3.0/modules/lib/loramac-node)
CONFIG_ZEPHYR_LORAMAC_NODE_MODULE=y
# CONFIG_HAS_SEMTECH_RADIO_DRIVERS is not set
# end of loramac-node (T:/tools/ncs/v2.3.0/modules/lib/loramac-node)
# lvgl (T:/tools/ncs/v2.3.0/modules/lib/gui/lvgl)
CONFIG_ZEPHYR_LVGL_MODULE=y
# end of lvgl (T:/tools/ncs/v2.3.0/modules/lib/gui/lvgl)
# lz4 (T:/tools/ncs/v2.3.0/modules/lib/lz4)
CONFIG_ZEPHYR_LZ4_MODULE=y
# CONFIG_LZ4 is not set
# end of lz4 (T:/tools/ncs/v2.3.0/modules/lib/lz4)
# nanopb (T:/tools/ncs/v2.3.0/modules/lib/nanopb)
CONFIG_ZEPHYR_NANOPB_MODULE=y
# CONFIG_NANOPB is not set
# end of nanopb (T:/tools/ncs/v2.3.0/modules/lib/nanopb)
# picolibc (T:/tools/ncs/v2.3.0/modules/lib/picolibc)
# CONFIG_PICOLIBC_MODULE is not set
CONFIG_ZEPHYR_PICOLIBC_MODULE=y
# end of picolibc (T:/tools/ncs/v2.3.0/modules/lib/picolibc)
# TraceRecorder (T:/tools/ncs/v2.3.0/modules/debug/TraceRecorder)
CONFIG_ZEPHYR_TRACERECORDER_MODULE=y
# end of TraceRecorder (T:/tools/ncs/v2.3.0/modules/debug/TraceRecorder)
# uoscore-uedhoc (T:/tools/ncs/v2.3.0/modules/lib/uoscore-uedhoc)
CONFIG_ZEPHYR_UOSCORE_UEDHOC_MODULE=y
# end of uoscore-uedhoc (T:/tools/ncs/v2.3.0/modules/lib/uoscore-uedhoc)
# zcbor (T:/tools/ncs/v2.3.0/modules/lib/zcbor)
CONFIG_ZEPHYR_ZCBOR_MODULE=y
# CONFIG_ZCBOR is not set
# end of zcbor (T:/tools/ncs/v2.3.0/modules/lib/zcbor)
# zscilib (T:/tools/ncs/v2.3.0/modules/lib/zscilib)
# CONFIG_ZSL is not set
CONFIG_ZEPHYR_ZSCILIB_MODULE=y
# end of zscilib (T:/tools/ncs/v2.3.0/modules/lib/zscilib)
# nrfxlib (T:/tools/ncs/v2.3.0/nrfxlib)
# Nordic nrfxlib
CONFIG_NRF_MODEM_SHMEM_CTRL_SIZE=0x4e8
# CONFIG_NFC_T2T_NRFXLIB is not set
# CONFIG_NFC_T4T_NRFXLIB is not set
CONFIG_MPSL=y
CONFIG_MPSL_BUILD_TYPE_LIB=y
# Crypto libraries for nRF5x SOCs.
CONFIG_NRFXLIB_CRYPTO=y
CONFIG_CRYPTOCELL_CC310_USABLE=y
CONFIG_CRYPTOCELL_USABLE=y
CONFIG_NRF_OBERON=y
# CONFIG_NRF_CC310_BL is not set
CONFIG_NRF_CC3XX_PLATFORM=y
# CONFIG_HW_CC3XX_INTERRUPT is not set
CONFIG_CC3XX_MUTEX_LOCK=y
# CONFIG_CC3XX_ATOMIC_LOCK is not set
# end of Crypto libraries for nRF5x SOCs.
# nrf_security module
# CONFIG_NORDIC_SECURITY_BACKEND is not set
# CONFIG_NRF_SECURITY is not set
# end of nrf_security module
# CONFIG_NRF_RPC is not set
CONFIG_NRF_802154_SOURCE_NRFXLIB=y
# CONFIG_GZLL is not set
# CONFIG_NRF_DM is not set
# CONFIG_LC3_PLC_DISABLED is not set
CONFIG_LC3_ENC_CHAN_MAX=1
CONFIG_LC3_DEC_CHAN_MAX=1
# Encoder sample rates
CONFIG_LC3_ENC_SAMPLE_RATE_8KHZ_SUPPORT=y
CONFIG_LC3_ENC_SAMPLE_RATE_16KHZ_SUPPORT=y
CONFIG_LC3_ENC_SAMPLE_RATE_24KHZ_SUPPORT=y
CONFIG_LC3_ENC_SAMPLE_RATE_32KHZ_SUPPORT=y
CONFIG_LC3_ENC_SAMPLE_RATE_441KHZ_SUPPORT=y
CONFIG_LC3_ENC_SAMPLE_RATE_48KHZ_SUPPORT=y
# end of Encoder sample rates
# Decoder sample rates
CONFIG_LC3_DEC_SAMPLE_RATE_8KHZ_SUPPORT=y
CONFIG_LC3_DEC_SAMPLE_RATE_16KHZ_SUPPORT=y
CONFIG_LC3_DEC_SAMPLE_RATE_24KHZ_SUPPORT=y
CONFIG_LC3_DEC_SAMPLE_RATE_32KHZ_SUPPORT=y
CONFIG_LC3_DEC_SAMPLE_RATE_441KHZ_SUPPORT=y
CONFIG_LC3_DEC_SAMPLE_RATE_48KHZ_SUPPORT=y
# end of Decoder sample rates
# end of Nordic nrfxlib
CONFIG_ZEPHYR_NRFXLIB_MODULE=y
# end of nrfxlib (T:/tools/ncs/v2.3.0/nrfxlib)
# connectedhomeip (T:/tools/ncs/v2.3.0/modules/lib/matter)
# CONFIG_CHIP is not set
# CONFIG_CHIP_LOG_SIZE_OPTIMIZATION is not set
CONFIG_ZEPHYR_CONNECTEDHOMEIP_MODULE=y
# end of connectedhomeip (T:/tools/ncs/v2.3.0/modules/lib/matter)
# Optional modules. Make sure they&amp;#39;re installed, via the project manifest.
CONFIG_HAS_CMSIS_CORE=y
CONFIG_HAS_CMSIS_CORE_M=y
# CONFIG_CMSIS_NN is not set
# CONFIG_LIBMETAL is not set
# CONFIG_LVGL is not set
# CONFIG_HAS_MEC_HAL is not set
# CONFIG_HAS_MPFS_HAL is not set
# CONFIG_OPENAMP is not set
# CONFIG_SOF is not set
# CONFIG_MIPI_SYST_LIB is not set
# CONFIG_HAS_TELINK_DRIVERS is not set
# CONFIG_TINYCBOR is not set
# CONFIG_TINYCRYPT_CTR_PRNG is not set
# CONFIG_TINYCRYPT_SHA256 is not set
# CONFIG_TINYCRYPT_ECC_DH is not set
# CONFIG_TINYCRYPT_ECC_DSA is not set
CONFIG_TINYCRYPT_AES=y
# CONFIG_TINYCRYPT_AES_CBC is not set
# CONFIG_TINYCRYPT_AES_CTR is not set
# CONFIG_TINYCRYPT_AES_CCM is not set
CONFIG_TINYCRYPT_AES_CMAC=y
# CONFIG_MCUBOOT_BOOTUTIL_LIB is not set
# Unavailable modules, please install those via the project manifest.
# hal_gigadevice module not available.
# Trusted-firmware-a module not available.
# end of Modules
CONFIG_BOARD_REVISION=&amp;quot;$BOARD_REVISION&amp;quot;
# CONFIG_NET_DRIVERS is not set
CONFIG_BOARD_NRF52840DK_NRF52840=y
# Board Options
CONFIG_BOARD_ENABLE_DCDC=y
CONFIG_BOARD_ENABLE_DCDC_HV=y
# end of Board Options
# CONFIG_SOC_SERIES_BEETLE is not set
# CONFIG_SOC_SERIES_ARM_DESIGNSTART is not set
# CONFIG_SOC_SERIES_FVP_AEMV8R_AARCH32 is not set
# CONFIG_SOC_SERIES_MPS2 is not set
# CONFIG_SOC_SERIES_MPS3 is not set
# CONFIG_SOC_SERIES_MUSCA_B1 is not set
# CONFIG_SOC_SERIES_MUSCA_S1 is not set
# CONFIG_SOC_SERIES_AST10X0 is not set
# CONFIG_SOC_SERIES_SAMC20 is not set
# CONFIG_SOC_SERIES_SAMC21 is not set
# CONFIG_SOC_SERIES_SAMD20 is not set
# CONFIG_SOC_SERIES_SAMD21 is not set
# CONFIG_SOC_SERIES_SAMD51 is not set
# CONFIG_SOC_SERIES_SAME51 is not set
# CONFIG_SOC_SERIES_SAME53 is not set
# CONFIG_SOC_SERIES_SAME54 is not set
# CONFIG_SOC_SERIES_SAML21 is not set
# CONFIG_SOC_SERIES_SAMR21 is not set
# CONFIG_SOC_SERIES_SAMR34 is not set
# CONFIG_SOC_SERIES_SAMR35 is not set
# CONFIG_SOC_SERIES_SAM3X is not set
# CONFIG_SOC_SERIES_SAM4E is not set
# CONFIG_SOC_SERIES_SAM4L is not set
# CONFIG_SOC_SERIES_SAM4S is not set
# CONFIG_SOC_SERIES_SAME70 is not set
# CONFIG_SOC_SERIES_SAMV71 is not set
# CONFIG_SOC_SERIES_VALKYRIE is not set
# CONFIG_SOC_SERIES_VIPER is not set
# CONFIG_SOC_SERIES_PSOC62 is not set
# CONFIG_SOC_SERIES_PSOC63 is not set
# CONFIG_SOC_SERIES_GD32E10X is not set
# CONFIG_SOC_SERIES_GD32E50X is not set
# CONFIG_SOC_SERIES_GD32F3X0 is not set
# CONFIG_SOC_SERIES_GD32F403 is not set
# CONFIG_SOC_SERIES_GD32F4XX is not set
# CONFIG_SOC_SERIES_XMC_4XXX is not set
# CONFIG_SOC_SERIES_CYCLONE5 is not set
# CONFIG_SOC_SERIES_MEC1501X is not set
# CONFIG_SOC_SERIES_MEC1701X is not set
# CONFIG_SOC_SERIES_MEC172X is not set
# CONFIG_SOC_SERIES_NRF51X is not set
CONFIG_SOC_SERIES_NRF52X=y
# CONFIG_SOC_SERIES_NRF53X is not set
# CONFIG_SOC_SERIES_NRF91X is not set
# CONFIG_SOC_SERIES_NPCX7 is not set
# CONFIG_SOC_SERIES_NPCX9 is not set
# CONFIG_SOC_SERIES_M48X is not set
# CONFIG_SOC_SERIES_IMX_6X_M4 is not set
# CONFIG_SOC_SERIES_IMX7_M4 is not set
# CONFIG_SOC_SERIES_IMX8ML_M7 is not set
# CONFIG_SOC_SERIES_IMX8MM_M4 is not set
# CONFIG_SOC_SERIES_IMX8MQ_M4 is not set
# CONFIG_SOC_SERIES_IMX_RT5XX is not set
# CONFIG_SOC_SERIES_IMX_RT6XX is not set
# CONFIG_SOC_SERIES_IMX_RT is not set
# CONFIG_SOC_SERIES_KINETIS_K2X is not set
# CONFIG_SOC_SERIES_KINETIS_K6X is not set
# CONFIG_SOC_SERIES_KINETIS_K8X is not set
# CONFIG_SOC_SERIES_KINETIS_KE1XF is not set
# CONFIG_SOC_SERIES_KINETIS_KL2X is not set
# CONFIG_SOC_SERIES_KINETIS_KV5X is not set
# CONFIG_SOC_SERIES_KINETIS_KWX is not set
# CONFIG_SOC_SERIES_LPC11U6X is not set
# CONFIG_SOC_SERIES_LPC51U68 is not set
# CONFIG_SOC_SERIES_LPC54XXX is not set
# CONFIG_SOC_SERIES_LPC55XXX is not set
# CONFIG_SOC_SERIES_S32ZE_R52 is not set
# CONFIG_SOC_EOS_S3 is not set
# CONFIG_SOC_SERIES_RCAR_GEN3 is not set
# CONFIG_SOC_SERIES_DA1469X is not set
# CONFIG_SOC_SERIES_RP2XXX is not set
# CONFIG_SOC_SERIES_EFM32GG11B is not set
# CONFIG_SOC_SERIES_EFM32HG is not set
# CONFIG_SOC_SERIES_EFM32JG12B is not set
# CONFIG_SOC_SERIES_EFM32PG12B is not set
# CONFIG_SOC_SERIES_EFM32PG1B is not set
# CONFIG_SOC_SERIES_EFM32WG is not set
# CONFIG_SOC_SERIES_EFR32BG13P is not set
# CONFIG_SOC_SERIES_EFR32FG13P is not set
# CONFIG_SOC_SERIES_EFR32FG1P is not set
# CONFIG_SOC_SERIES_EFR32MG12P is not set
# CONFIG_SOC_SERIES_EFR32MG21 is not set
# CONFIG_SOC_SERIES_STM32F0X is not set
# CONFIG_SOC_SERIES_STM32F1X is not set
# CONFIG_SOC_SERIES_STM32F2X is not set
# CONFIG_SOC_SERIES_STM32F3X is not set
# CONFIG_SOC_SERIES_STM32F4X is not set
# CONFIG_SOC_SERIES_STM32F7X is not set
# CONFIG_SOC_SERIES_STM32G0X is not set
# CONFIG_SOC_SERIES_STM32G4X is not set
# CONFIG_SOC_SERIES_STM32H7X is not set
# CONFIG_SOC_SERIES_STM32L0X is not set
# CONFIG_SOC_SERIES_STM32L1X is not set
# CONFIG_SOC_SERIES_STM32L4X is not set
# CONFIG_SOC_SERIES_STM32L5X is not set
# CONFIG_SOC_SERIES_STM32MP1X is not set
# CONFIG_SOC_SERIES_STM32U5X is not set
# CONFIG_SOC_SERIES_STM32WBX is not set
# CONFIG_SOC_SERIES_STM32WLX is not set
# CONFIG_SOC_TI_LM3S6965 is not set
# CONFIG_SOC_SERIES_CC13X2_CC26X2 is not set
# CONFIG_SOC_SERIES_CC32XX is not set
# CONFIG_SOC_SERIES_MSP432P4XX is not set
# CONFIG_SOC_SERIES_XILINX_XC7ZXXX is not set
# CONFIG_SOC_SERIES_XILINX_XC7ZXXXS is not set
# CONFIG_SOC_XILINX_ZYNQMP_RPU is not set
# Hardware Configuration
CONFIG_CPU_HAS_ARM_MPU=y
CONFIG_HAS_SWO=y
CONFIG_SOC_FAMILY=&amp;quot;nordic_nrf&amp;quot;
CONFIG_SOC_FAMILY_NRF=y
CONFIG_HAS_HW_NRF_ACL=y
CONFIG_HAS_HW_NRF_CC310=y
CONFIG_HAS_HW_NRF_CCM=y
CONFIG_HAS_HW_NRF_CCM_LFLEN_8BIT=y
CONFIG_HAS_HW_NRF_CLOCK=y
CONFIG_HAS_HW_NRF_ECB=y
CONFIG_HAS_HW_NRF_EGU0=y
CONFIG_HAS_HW_NRF_EGU1=y
CONFIG_HAS_HW_NRF_EGU2=y
CONFIG_HAS_HW_NRF_EGU3=y
CONFIG_HAS_HW_NRF_EGU4=y
CONFIG_HAS_HW_NRF_EGU5=y
CONFIG_HAS_HW_NRF_GPIO0=y
CONFIG_HAS_HW_NRF_GPIO1=y
CONFIG_HAS_HW_NRF_GPIOTE=y
CONFIG_HAS_HW_NRF_MWU=y
CONFIG_HAS_HW_NRF_NVMC_PE=y
CONFIG_HAS_HW_NRF_POWER=y
CONFIG_HAS_HW_NRF_PPI=y
CONFIG_HAS_HW_NRF_PWM0=y
CONFIG_HAS_HW_NRF_QSPI=y
CONFIG_HAS_HW_NRF_RADIO_BLE_2M=y
CONFIG_HAS_HW_NRF_RADIO_BLE_CODED=y
CONFIG_HAS_HW_NRF_RADIO_IEEE802154=y
CONFIG_HAS_HW_NRF_RADIO_TX_PWR_HIGH=y
CONFIG_HAS_HW_NRF_RNG=y
CONFIG_HAS_HW_NRF_RTC0=y
CONFIG_HAS_HW_NRF_RTC1=y
CONFIG_HAS_HW_NRF_RTC2=y
CONFIG_HAS_HW_NRF_SAADC=y
CONFIG_HAS_HW_NRF_SPI1=y
CONFIG_HAS_HW_NRF_SPI2=y
CONFIG_HAS_HW_NRF_SPIM3=y
CONFIG_HAS_HW_NRF_SWI0=y
CONFIG_HAS_HW_NRF_SWI1=y
CONFIG_HAS_HW_NRF_SWI2=y
CONFIG_HAS_HW_NRF_SWI3=y
CONFIG_HAS_HW_NRF_SWI4=y
CONFIG_HAS_HW_NRF_SWI5=y
CONFIG_HAS_HW_NRF_TEMP=y
CONFIG_HAS_HW_NRF_TIMER0=y
CONFIG_HAS_HW_NRF_TIMER1=y
CONFIG_HAS_HW_NRF_TIMER2=y
CONFIG_HAS_HW_NRF_TIMER3=y
CONFIG_HAS_HW_NRF_TIMER4=y
CONFIG_HAS_HW_NRF_TWI0=y
CONFIG_HAS_HW_NRF_UARTE0=y
CONFIG_HAS_HW_NRF_UARTE1=y
CONFIG_HAS_HW_NRF_USBD=y
CONFIG_HAS_HW_NRF_WDT0=y
CONFIG_NRF_HW_RTC1_RESERVED=y
CONFIG_SOC_NRF52840=y
# CONFIG_SOC_NRF52805_CAAA is not set
# CONFIG_SOC_NRF52810_QFAA is not set
# CONFIG_SOC_NRF52811_QFAA is not set
# CONFIG_SOC_NRF52820_QDAA is not set
# CONFIG_SOC_NRF52832_CIAA is not set
# CONFIG_SOC_NRF52832_QFAA is not set
# CONFIG_SOC_NRF52832_QFAB is not set
# CONFIG_SOC_NRF52833_QIAA is not set
CONFIG_SOC_NRF52840_QIAA=y
CONFIG_SOC_DCDC_NRF52X=y
CONFIG_SOC_DCDC_NRF52X_HV=y
CONFIG_GPIO_AS_PINRESET=y
CONFIG_NRF_ENABLE_ICACHE=y
CONFIG_NRF_RTC_TIMER_USER_CHAN_COUNT=0
CONFIG_NRF_SOC_SECURE_SUPPORTED=y
# CONFIG_NFCT_PINS_AS_GPIOS is not set
CONFIG_NRF_APPROTECT_USE_UICR=y
# CONFIG_NRF_APPROTECT_LOCK is not set
# CONFIG_NRF_TRACE_PORT is not set
# CONFIG_BUILD_OUTPUT_INFO_HEADER is not set
# CONFIG_SOC_LOG_LEVEL_OFF is not set
# CONFIG_SOC_LOG_LEVEL_ERR is not set
# CONFIG_SOC_LOG_LEVEL_WRN is not set
CONFIG_SOC_LOG_LEVEL_INF=y
# CONFIG_SOC_LOG_LEVEL_DBG is not set
CONFIG_SOC_LOG_LEVEL=3
# end of Hardware Configuration
CONFIG_SOC_COMPATIBLE_NRF=y
CONFIG_SOC_COMPATIBLE_NRF52X=y
# ARM Options
CONFIG_ARCH=&amp;quot;arm&amp;quot;
CONFIG_CPU_CORTEX=y
# CONFIG_CODE_DATA_RELOCATION_SRAM is not set
CONFIG_CPU_CORTEX_M=y
CONFIG_ISA_THUMB2=y
CONFIG_ASSEMBLER_ISA_THUMB2=y
CONFIG_COMPILER_ISA_THUMB2=y
CONFIG_STACK_ALIGN_DOUBLE_WORD=y
# CONFIG_RUNTIME_NMI is not set
CONFIG_FAULT_DUMP=2
CONFIG_ARM_STACK_PROTECTION=y
CONFIG_FP16=y
CONFIG_FP16_IEEE=y
# CONFIG_FP16_ALT is not set
CONFIG_CPU_CORTEX_M4=y
CONFIG_CPU_CORTEX_M_HAS_SYSTICK=y
CONFIG_CPU_CORTEX_M_HAS_DWT=y
CONFIG_CPU_CORTEX_M_HAS_BASEPRI=y
CONFIG_CPU_CORTEX_M_HAS_VTOR=y
CONFIG_CPU_CORTEX_M_HAS_PROGRAMMABLE_FAULT_PRIOS=y
CONFIG_ARMV7_M_ARMV8_M_MAINLINE=y
CONFIG_ARMV7_M_ARMV8_M_FP=y
# ARM Cortex-M0/M0+/M1/M3/M4/M7/M23/M33 options
CONFIG_GEN_ISR_TABLES=y
CONFIG_ZERO_LATENCY_IRQS=y
CONFIG_ZERO_LATENCY_LEVELS=1
# CONFIG_SW_VECTOR_RELAY is not set
# CONFIG_CORTEX_M_DWT is not set
# CONFIG_TRAP_UNALIGNED_ACCESS is not set
# end of ARM Cortex-M0/M0+/M1/M3/M4/M7/M23/M33 options
CONFIG_NULL_POINTER_EXCEPTION_DETECTION_NONE=y
# CONFIG_NULL_POINTER_EXCEPTION_DETECTION_DWT is not set
# CONFIG_NULL_POINTER_EXCEPTION_DETECTION_MPU is not set
CONFIG_GEN_IRQ_VECTOR_TABLE=y
CONFIG_ARM_MPU=y
CONFIG_ARM_MPU_REGION_MIN_ALIGN_AND_SIZE=32
CONFIG_MPU_STACK_GUARD=y
# CONFIG_MPU_ALLOW_FLASH_WRITE is not set
# CONFIG_MPU_DISABLE_BACKGROUND_MAP is not set
# CONFIG_CUSTOM_SECTION_ALIGN is not set
CONFIG_CUSTOM_SECTION_MIN_ALIGN_SIZE=32
# end of ARM Options
CONFIG_ARM=y
CONFIG_ARCH_IS_SET=y
# General Architecture Options
# CONFIG_SEMIHOST is not set
# CONFIG_ARCH_LOG_LEVEL_OFF is not set
# CONFIG_ARCH_LOG_LEVEL_ERR is not set
# CONFIG_ARCH_LOG_LEVEL_WRN is not set
CONFIG_ARCH_LOG_LEVEL_INF=y
# CONFIG_ARCH_LOG_LEVEL_DBG is not set
CONFIG_ARCH_LOG_LEVEL=3
CONFIG_LITTLE_ENDIAN=y
CONFIG_HW_STACK_PROTECTION=y
# CONFIG_USERSPACE is not set
CONFIG_KOBJECT_TEXT_AREA=256
CONFIG_KOBJECT_DATA_AREA_RESERVE_EXTRA_PERCENT=100
CONFIG_KOBJECT_RODATA_AREA_EXTRA_BYTES=16
CONFIG_GEN_PRIV_STACKS=y
# CONFIG_STACK_GROWS_UP is not set
# Interrupt Configuration
# CONFIG_DYNAMIC_INTERRUPTS is not set
CONFIG_ARCH_IRQ_VECTOR_TABLE_ALIGN=4
CONFIG_IRQ_VECTOR_TABLE_JUMP_BY_ADDRESS=y
# CONFIG_IRQ_VECTOR_TABLE_JUMP_BY_CODE is not set
CONFIG_GEN_SW_ISR_TABLE=y
CONFIG_ARCH_SW_ISR_TABLE_ALIGN=4
CONFIG_GEN_IRQ_START_VECTOR=0
# CONFIG_EXTRA_EXCEPTION_INFO is not set
# end of Interrupt Configuration
# end of General Architecture Options
CONFIG_ARCH_HAS_SINGLE_THREAD_SUPPORT=y
CONFIG_ARCH_HAS_TIMING_FUNCTIONS=y
CONFIG_ARCH_HAS_STACK_PROTECTION=y
CONFIG_ARCH_HAS_USERSPACE=y
CONFIG_ARCH_HAS_EXECUTABLE_PAGE_BIT=y
CONFIG_ARCH_HAS_RAMFUNC_SUPPORT=y
CONFIG_ARCH_HAS_NESTED_EXCEPTION_DETECTION=y
CONFIG_ARCH_SUPPORTS_COREDUMP=y
CONFIG_ARCH_SUPPORTS_ARCH_HW_INIT=y
CONFIG_ARCH_HAS_EXTRA_EXCEPTION_INFO=y
CONFIG_ARCH_HAS_THREAD_LOCAL_STORAGE=y
CONFIG_ARCH_HAS_SUSPEND_TO_RAM=y
CONFIG_ARCH_HAS_THREAD_ABORT=y
CONFIG_ARCH_HAS_CODE_DATA_RELOCATION=y
CONFIG_CPU_HAS_FPU=y
CONFIG_CPU_HAS_MPU=y
CONFIG_MPU=y
# CONFIG_MPU_LOG_LEVEL_OFF is not set
# CONFIG_MPU_LOG_LEVEL_ERR is not set
# CONFIG_MPU_LOG_LEVEL_WRN is not set
CONFIG_MPU_LOG_LEVEL_INF=y
# CONFIG_MPU_LOG_LEVEL_DBG is not set
CONFIG_MPU_LOG_LEVEL=3
CONFIG_MPU_REQUIRES_POWER_OF_TWO_ALIGNMENT=y
CONFIG_SRAM_REGION_PERMISSIONS=y
# Floating Point Options
# end of Floating Point Options
# Cache Options
# end of Cache Options
CONFIG_TOOLCHAIN_HAS_BUILTIN_FFS=y
# General Kernel Options
# CONFIG_KERNEL_LOG_LEVEL_OFF is not set
# CONFIG_KERNEL_LOG_LEVEL_ERR is not set
# CONFIG_KERNEL_LOG_LEVEL_WRN is not set
CONFIG_KERNEL_LOG_LEVEL_INF=y
# CONFIG_KERNEL_LOG_LEVEL_DBG is not set
CONFIG_KERNEL_LOG_LEVEL=3
CONFIG_MULTITHREADING=y
CONFIG_NUM_COOP_PRIORITIES=16
CONFIG_NUM_PREEMPT_PRIORITIES=15
CONFIG_MAIN_THREAD_PRIORITY=0
CONFIG_COOP_ENABLED=y
CONFIG_PREEMPT_ENABLED=y
CONFIG_PRIORITY_CEILING=-127
# CONFIG_SCHED_DEADLINE is not set
# CONFIG_SCHED_CPU_MASK is not set
CONFIG_IDLE_STACK_SIZE=320
CONFIG_ISR_STACK_SIZE=2048
CONFIG_THREAD_STACK_INFO=y
# CONFIG_THREAD_CUSTOM_DATA is not set
CONFIG_ERRNO=y
CONFIG_SCHED_DUMB=y
# CONFIG_SCHED_SCALABLE is not set
# CONFIG_SCHED_MULTIQ is not set
# CONFIG_WAITQ_SCALABLE is not set
CONFIG_WAITQ_DUMB=y
# Kernel Debugging and Metrics
CONFIG_BOOT_BANNER=y
CONFIG_BOOT_DELAY=0
CONFIG_THREAD_MONITOR=y
# CONFIG_THREAD_NAME is not set
# CONFIG_THREAD_RUNTIME_STATS is not set
# end of Kernel Debugging and Metrics
# Work Queue Options
CONFIG_SYSTEM_WORKQUEUE_PRIORITY=-1
# CONFIG_SYSTEM_WORKQUEUE_NO_YIELD is not set
# end of Work Queue Options
# Atomic Operations
CONFIG_ATOMIC_OPERATIONS_BUILTIN=y
# end of Atomic Operations
# Timer API Options
CONFIG_TIMESLICING=y
CONFIG_TIMESLICE_SIZE=0
CONFIG_TIMESLICE_PRIORITY=0
# CONFIG_TIMESLICE_PER_THREAD is not set
CONFIG_POLL=y
# end of Timer API Options
# Other Kernel Object Options
# CONFIG_MEM_SLAB_TRACE_MAX_UTILIZATION is not set
CONFIG_NUM_MBOX_ASYNC_MSGS=10
# CONFIG_EVENTS is not set
# CONFIG_PIPES is not set
CONFIG_KERNEL_MEM_POOL=y
# end of Other Kernel Object Options
CONFIG_ARCH_HAS_CUSTOM_SWAP_TO_MAIN=y
CONFIG_SWAP_NONATOMIC=y
CONFIG_SYS_CLOCK_EXISTS=y
CONFIG_TIMEOUT_64BIT=y
CONFIG_SYS_CLOCK_MAX_TIMEOUT_DAYS=365
CONFIG_XIP=y
# Initialization Priorities
CONFIG_KERNEL_INIT_PRIORITY_OBJECTS=30
CONFIG_KERNEL_INIT_PRIORITY_DEFAULT=40
CONFIG_KERNEL_INIT_PRIORITY_DEVICE=50
CONFIG_APPLICATION_INIT_PRIORITY=90
# end of Initialization Priorities
# Security Options
# CONFIG_STACK_CANARIES is not set
CONFIG_STACK_POINTER_RANDOM=0
# end of Security Options
# SMP Options
CONFIG_MP_NUM_CPUS=1
# end of SMP Options
CONFIG_TICKLESS_KERNEL=y
# end of General Kernel Options
# Device Options
# end of Device Options
# Virtual Memory Support
# end of Virtual Memory Support
# Device Drivers
# CONFIG_LORA is not set
CONFIG_CONSOLE=y
CONFIG_CONSOLE_INPUT_MAX_LINE_LEN=128
CONFIG_CONSOLE_HAS_DRIVER=y
# CONFIG_CONSOLE_HANDLER is not set
CONFIG_CONSOLE_INIT_PRIORITY=60
CONFIG_UART_CONSOLE=y
# CONFIG_UART_CONSOLE_DEBUG_SERVER_HOOKS is not set
# CONFIG_UART_CONSOLE_MCUMGR is not set
CONFIG_UART_CONSOLE_INPUT_EXPIRED=y
CONFIG_UART_CONSOLE_INPUT_EXPIRED_TIMEOUT=15000
# CONFIG_RAM_CONSOLE is not set
# CONFIG_RTT_CONSOLE is not set
# CONFIG_IPM_CONSOLE_SENDER is not set
# CONFIG_IPM_CONSOLE_RECEIVER is not set
# CONFIG_UART_MCUMGR is not set
# CONFIG_UART_CONSOLE_LOG_LEVEL_OFF is not set
# CONFIG_UART_CONSOLE_LOG_LEVEL_ERR is not set
# CONFIG_UART_CONSOLE_LOG_LEVEL_WRN is not set
CONFIG_UART_CONSOLE_LOG_LEVEL_INF=y
# CONFIG_UART_CONSOLE_LOG_LEVEL_DBG is not set
CONFIG_UART_CONSOLE_LOG_LEVEL=3
# CONFIG_GSM_MUX is not set
# CONFIG_EFI_CONSOLE is not set
CONFIG_HAS_SEGGER_RTT=y
CONFIG_USE_SEGGER_RTT=y
CONFIG_SEGGER_RTT_CUSTOM_LOCKING=y
CONFIG_SEGGER_RTT_MAX_NUM_UP_BUFFERS=3
CONFIG_SEGGER_RTT_MAX_NUM_DOWN_BUFFERS=3
CONFIG_SEGGER_RTT_BUFFER_SIZE_UP=1024
CONFIG_SEGGER_RTT_BUFFER_SIZE_DOWN=16
CONFIG_SEGGER_RTT_PRINTF_BUFFER_SIZE=64
CONFIG_SEGGER_RTT_MODE_NO_BLOCK_SKIP=y
# CONFIG_SEGGER_RTT_MODE_NO_BLOCK_TRIM is not set
# CONFIG_SEGGER_RTT_MODE_BLOCK_IF_FIFO_FULL is not set
CONFIG_SEGGER_RTT_MODE=0
# CONFIG_SEGGER_RTT_MEMCPY_USE_BYTELOOP is not set
CONFIG_SEGGER_RTT_SECTION_NONE=y
# CONFIG_SEGGER_RTT_SECTION_DTCM is not set
CONFIG_ETH_INIT_PRIORITY=80
# CONFIG_MDIO is not set
# Capabilities
CONFIG_SERIAL_HAS_DRIVER=y
CONFIG_SERIAL_SUPPORT_ASYNC=y
CONFIG_SERIAL_SUPPORT_INTERRUPT=y
# CONFIG_UART_LOG_LEVEL_OFF is not set
# CONFIG_UART_LOG_LEVEL_ERR is not set
# CONFIG_UART_LOG_LEVEL_WRN is not set
CONFIG_UART_LOG_LEVEL_INF=y
# CONFIG_UART_LOG_LEVEL_DBG is not set
CONFIG_UART_LOG_LEVEL=3
CONFIG_UART_USE_RUNTIME_CONFIGURE=y
# CONFIG_UART_ASYNC_API is not set
# CONFIG_UART_LINE_CTRL is not set
# CONFIG_UART_DRV_CMD is not set
# CONFIG_UART_WIDE_DATA is not set
# CONFIG_UART_PIPE is not set
# Serial Drivers
CONFIG_UART_NRFX=y
CONFIG_UART_0_NRF_UARTE=y
CONFIG_UART_0_ENHANCED_POLL_OUT=y
# CONFIG_UART_0_NRF_PARITY_BIT is not set
CONFIG_UART_0_NRF_TX_BUFFER_SIZE=32
CONFIG_UART_1_NRF_UARTE=y
CONFIG_UART_1_ENHANCED_POLL_OUT=y
# CONFIG_UART_1_NRF_PARITY_BIT is not set
CONFIG_UART_ENHANCED_POLL_OUT=y
CONFIG_NRF_UARTE_PERIPHERAL=y
# Interrupt Controllers
CONFIG_INTC_INIT_PRIORITY=40
# CONFIG_INTC_LOG_LEVEL_OFF is not set
# CONFIG_INTC_LOG_LEVEL_ERR is not set
# CONFIG_INTC_LOG_LEVEL_WRN is not set
CONFIG_INTC_LOG_LEVEL_INF=y
# CONFIG_INTC_LOG_LEVEL_DBG is not set
CONFIG_INTC_LOG_LEVEL=3
# CONFIG_MULTI_LEVEL_INTERRUPTS is not set
# CONFIG_INTC_ESP32 is not set
# end of Interrupt Controllers
# Timer Drivers
# CONFIG_TIMER_READS_ITS_FREQUENCY_AT_RUNTIME is not set
# CONFIG_SYSTEM_CLOCK_SLOPPY_IDLE is not set
CONFIG_SYSTEM_CLOCK_INIT_PRIORITY=0
CONFIG_TICKLESS_CAPABLE=y
CONFIG_NRF_RTC_TIMER_LOCK_ZERO_LATENCY_IRQS=y
# CONFIG_NRF_RTC_TIMER_TRIGGER_OVERFLOW is not set
# CONFIG_SYSTEM_CLOCK_NO_WAIT is not set
# CONFIG_SYSTEM_CLOCK_WAIT_FOR_AVAILABILITY is not set
CONFIG_SYSTEM_CLOCK_WAIT_FOR_STABILITY=y
# end of Timer Drivers
# CONFIG_ENTROPY_LOG_LEVEL_OFF is not set
# CONFIG_ENTROPY_LOG_LEVEL_ERR is not set
# CONFIG_ENTROPY_LOG_LEVEL_WRN is not set
CONFIG_ENTROPY_LOG_LEVEL_INF=y
# CONFIG_ENTROPY_LOG_LEVEL_DBG is not set
CONFIG_ENTROPY_LOG_LEVEL=3
CONFIG_ENTROPY_INIT_PRIORITY=50
CONFIG_ENTROPY_NRF5_RNG=y
# CONFIG_ENTROPY_NRF5_BIAS_CORRECTION is not set
CONFIG_ENTROPY_NRF5_THR_POOL_SIZE=8
CONFIG_ENTROPY_NRF5_THR_THRESHOLD=4
CONFIG_ENTROPY_NRF5_ISR_POOL_SIZE=16
CONFIG_ENTROPY_NRF5_ISR_THRESHOLD=12
CONFIG_ENTROPY_BT_HCI=y
CONFIG_ENTROPY_HAS_DRIVER=y
# CONFIG_PCIE is not set
# CONFIG_PCIE_ENDPOINT is not set
# CONFIG_GPIO_LOG_LEVEL_OFF is not set
# CONFIG_GPIO_LOG_LEVEL_ERR is not set
# CONFIG_GPIO_LOG_LEVEL_WRN is not set
CONFIG_GPIO_LOG_LEVEL_INF=y
# CONFIG_GPIO_LOG_LEVEL_DBG is not set
CONFIG_GPIO_LOG_LEVEL=3
# CONFIG_GPIO_GET_DIRECTION is not set
# CONFIG_GPIO_GET_CONFIG is not set
CONFIG_GPIO_NRFX=y
# CONFIG_FXL6408_LOG_LEVEL_OFF is not set
# CONFIG_FXL6408_LOG_LEVEL_ERR is not set
# CONFIG_FXL6408_LOG_LEVEL_WRN is not set
CONFIG_FXL6408_LOG_LEVEL_INF=y
# CONFIG_FXL6408_LOG_LEVEL_DBG is not set
CONFIG_FXL6408_LOG_LEVEL=3
CONFIG_SPI_ASYNC=y
# CONFIG_SPI_SLAVE is not set
# CONFIG_SPI_EXTENDED_MODES is not set
CONFIG_SPI_INIT_PRIORITY=70
CONFIG_SPI_COMPLETION_TIMEOUT_TOLERANCE=200
# CONFIG_SPI_LOG_LEVEL_OFF is not set
# CONFIG_SPI_LOG_LEVEL_ERR is not set
# CONFIG_SPI_LOG_LEVEL_WRN is not set
CONFIG_SPI_LOG_LEVEL_INF=y
# CONFIG_SPI_LOG_LEVEL_DBG is not set
CONFIG_SPI_LOG_LEVEL=3
CONFIG_SPI_NRFX=y
CONFIG_SPI_1_NRF_SPI=y
CONFIG_SPI_2_NRF_SPI=y
CONFIG_SPI_3_NRF_SPIM=y
CONFIG_SPI_NRFX_RAM_BUFFER_SIZE=8
# CONFIG_SDHC is not set
# CONFIG_I3C is not set
# CONFIG_I2S is not set
# CONFIG_DAI is not set
# CONFIG_PWM is not set
# CONFIG_PINMUX is not set
CONFIG_ADC=y
CONFIG_ADC_CONFIGURABLE_INPUTS=y
CONFIG_ADC_ASYNC=y
# CONFIG_ADC_LOG_LEVEL_OFF is not set
# CONFIG_ADC_LOG_LEVEL_ERR is not set
# CONFIG_ADC_LOG_LEVEL_WRN is not set
CONFIG_ADC_LOG_LEVEL_INF=y
# CONFIG_ADC_LOG_LEVEL_DBG is not set
CONFIG_ADC_LOG_LEVEL=3
CONFIG_ADC_NRFX_SAADC=y
# CONFIG_DAC is not set
# CONFIG_W1 is not set
# CONFIG_CLOCK_CONTROL_LOG_LEVEL_OFF is not set
# CONFIG_CLOCK_CONTROL_LOG_LEVEL_ERR is not set
# CONFIG_CLOCK_CONTROL_LOG_LEVEL_WRN is not set
CONFIG_CLOCK_CONTROL_LOG_LEVEL_INF=y
# CONFIG_CLOCK_CONTROL_LOG_LEVEL_DBG is not set
CONFIG_CLOCK_CONTROL_LOG_LEVEL=3
CONFIG_CLOCK_CONTROL_NRF_FORCE_ALT=y
CONFIG_CLOCK_CONTROL_NRF=y
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_RC is not set
CONFIG_CLOCK_CONTROL_NRF_K32SRC_XTAL=y
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_SYNTH is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_EXT_LOW_SWING is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_EXT_FULL_SWING is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_500PPM is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_250PPM is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_150PPM is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_100PPM is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_75PPM is not set
CONFIG_CLOCK_CONTROL_NRF_K32SRC_50PPM=y
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_30PPM is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_20PPM is not set
CONFIG_CLOCK_CONTROL_NRF_ACCURACY=50
# CONFIG_PTP_CLOCK is not set
# CONFIG_IPM is not set
# CONFIG_FLASH is not set
# CONFIG_SENSOR_LOG_LEVEL_OFF is not set
# CONFIG_SENSOR_LOG_LEVEL_ERR is not set
# CONFIG_SENSOR_LOG_LEVEL_WRN is not set
CONFIG_SENSOR_LOG_LEVEL_INF=y
# CONFIG_SENSOR_LOG_LEVEL_DBG is not set
CONFIG_SENSOR_LOG_LEVEL=3
CONFIG_SENSOR_INIT_PRIORITY=90
# CONFIG_SENSOR_INFO is not set
# Device Drivers
CONFIG_TEMP_NRF5_FORCE_ALT=y
CONFIG_TMP112_FULL_SCALE_RUNTIME=y
CONFIG_TMP112_SAMPLING_FREQUENCY_RUNTIME=y
# CONFIG_COUNTER is not set
# CONFIG_DMA is not set
# CONFIG_UDC_DRIVER is not set
# CONFIG_USB_DEVICE_DRIVER is not set
# CONFIG_CRYPTO is not set
# CONFIG_DISPLAY is not set
# CONFIG_LED_STRIP is not set
# CONFIG_LED is not set
# CONFIG_CAN is not set
# CONFIG_AUDIO is not set
# CONFIG_NEURAL_NET_ACCEL is not set
# CONFIG_HWINFO is not set
# CONFIG_ESPI is not set
# CONFIG_PS2 is not set
# CONFIG_VIDEO is not set
# CONFIG_EEPROM is not set
# CONFIG_PECI is not set
# CONFIG_PECI_INTERRUPT_DRIVEN is not set
# CONFIG_REGULATOR is not set
# CONFIG_MEMC is not set
# CONFIG_VIRTUALIZATION is not set
# CONFIG_EDAC is not set
# CONFIG_PM_CPU_OPS is not set
# Miscellaneous Drivers
# CONFIG_GROVE_LCD_RGB is not set
# end of Miscellaneous Drivers
# CONFIG_DISK_DRIVERS is not set
# CONFIG_CACHE is not set
# CONFIG_SYSCON is not set
# CONFIG_BBRAM is not set
# CONFIG_FPGA is not set
# CONFIG_PINCTRL_LOG_LEVEL_OFF is not set
# CONFIG_PINCTRL_LOG_LEVEL_ERR is not set
# CONFIG_PINCTRL_LOG_LEVEL_WRN is not set
CONFIG_PINCTRL_LOG_LEVEL_INF=y
# CONFIG_PINCTRL_LOG_LEVEL_DBG is not set
CONFIG_PINCTRL_LOG_LEVEL=3
CONFIG_PINCTRL_STORE_REG=y
# CONFIG_PINCTRL_DYNAMIC is not set
CONFIG_PINCTRL_NRF=y
# CONFIG_MBOX is not set
# CONFIG_MM_DRV is not set
# CONFIG_POWER_DOMAIN is not set
# CONFIG_USBC_TCPC_DRIVER is not set
# CONFIG_USBC_LOG_LEVEL_OFF is not set
# CONFIG_USBC_LOG_LEVEL_ERR is not set
# CONFIG_USBC_LOG_LEVEL_WRN is not set
CONFIG_USBC_LOG_LEVEL_INF=y
# CONFIG_USBC_LOG_LEVEL_DBG is not set
CONFIG_USBC_LOG_LEVEL=3
# CONFIG_USBC_VBUS_DRIVER is not set
# CONFIG_MIPI_DSI is not set
# CONFIG_COREDUMP_DEVICE is not set
# CONFIG_FUEL_GAUGE is not set
# C Library
CONFIG_SUPPORT_MINIMAL_LIBC=y
CONFIG_PICOLIBC_SUPPORTED=y
CONFIG_MINIMAL_LIBC=y
# CONFIG_PICOLIBC is not set
# CONFIG_NEWLIB_LIBC is not set
# CONFIG_EXTERNAL_LIBC is not set
CONFIG_HAS_NEWLIB_LIBC_NANO=y
CONFIG_MINIMAL_LIBC_NON_REENTRANT_FUNCTIONS=y
CONFIG_MINIMAL_LIBC_MALLOC=y
CONFIG_MINIMAL_LIBC_MALLOC_ARENA_SIZE=0
CONFIG_MINIMAL_LIBC_CALLOC=y
CONFIG_MINIMAL_LIBC_REALLOCARRAY=y
# CONFIG_MINIMAL_LIBC_LL_PRINTF is not set
CONFIG_MINIMAL_LIBC_OPTIMIZE_STRING_FOR_SIZE=y
# CONFIG_MINIMAL_LIBC_RAND is not set
CONFIG_MINIMAL_LIBC_TIME=y
# CONFIG_MINIMAL_LIBC_STRING_ERROR_TABLE is not set
CONFIG_STDOUT_CONSOLE=y
CONFIG_NEED_LIBC_MEM_PARTITION=y
# end of C Library
# Additional libraries
# OS Support Library
# CONFIG_JSON_LIBRARY is not set
# CONFIG_RING_BUFFER is not set
CONFIG_NOTIFY=y
# CONFIG_BASE64 is not set
CONFIG_CRC=y
# CONFIG_PRINTK_SYNC is not set
CONFIG_MPSC_PBUF=y
CONFIG_ONOFF=y
# CONFIG_SPSC_PBUF is not set
# CONFIG_SHARED_MULTI_HEAP is not set
# CONFIG_WINSTREAM is not set
# CONFIG_MPSC_CLEAR_ALLOCATED is not set
CONFIG_REBOOT=y
# CONFIG_UTF8 is not set
CONFIG_CBPRINTF_COMPLETE=y
# CONFIG_CBPRINTF_NANO is not set
CONFIG_CBPRINTF_FULL_INTEGRAL=y
# CONFIG_CBPRINTF_REDUCED_INTEGRAL is not set
CONFIG_CBPRINTF_FP_SUPPORT=y
# CONFIG_CBPRINTF_FP_A_SUPPORT is not set
# CONFIG_CBPRINTF_FP_ALWAYS_A is not set
CONFIG_CBPRINTF_N_SPECIFIER=y
# CONFIG_CBPRINTF_LIBC_SUBSTS is not set
# CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_OFF is not set
# CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_ERR is not set
# CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_WRN is not set
CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_INF=y
# CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_DBG is not set
CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL=3
# CONFIG_CBPRINTF_PACKAGE_LONGDOUBLE is not set
# Heap and Memory Allocation
# CONFIG_SYS_HEAP_VALIDATE is not set
CONFIG_SYS_HEAP_ALLOC_LOOPS=3
# CONFIG_SYS_HEAP_RUNTIME_STATS is not set
# CONFIG_SYS_HEAP_LISTENER is not set
CONFIG_SYS_HEAP_SMALL_ONLY=y
# CONFIG_SYS_HEAP_BIG_ONLY is not set
# CONFIG_SYS_HEAP_AUTO is not set
# CONFIG_SYS_MEM_BLOCKS is not set
# end of Heap and Memory Allocation
# end of OS Support Library
# CONFIG_GETOPT is not set
# CONFIG_POSIX_API is not set
# CONFIG_POSIX_CLOCK is not set
CONFIG_MAX_TIMER_COUNT=5
# CONFIG_POSIX_MQUEUE is not set
# CONFIG_EVENTFD is not set
# CONFIG_OPENAMP_RSC_TABLE is not set
# Util libraries
# CONFIG_FNMATCH is not set
# end of Util libraries
# CONFIG_SMF is not set
# end of Additional libraries
# Sub Systems and OS Services
CONFIG_BT=y
# CONFIG_BT_LOG_LEVEL_OFF is not set
# CONFIG_BT_LOG_LEVEL_ERR is not set
# CONFIG_BT_LOG_LEVEL_WRN is not set
CONFIG_BT_LOG_LEVEL_INF=y
# CONFIG_BT_LOG_LEVEL_DBG is not set
CONFIG_BT_LOG_LEVEL=3
CONFIG_BT_HCI=y
# CONFIG_BT_CUSTOM is not set
# CONFIG_BT_HCI_RAW is not set
# CONFIG_BT_HCI_RAW_H4 is not set
# CONFIG_BT_HCI_RAW_CMD_EXT is not set
CONFIG_BT_CONN_TX=y
# CONFIG_BT_PER_ADV_SYNC_TRANSFER_RECEIVER is not set
# CONFIG_BT_PER_ADV_SYNC_TRANSFER_SENDER is not set
# CONFIG_BT_SCA_UPDATE is not set
# Bluetooth buffer configuration
# end of Bluetooth buffer configuration
# Bluetooth Host
# L2CAP Options
# end of L2CAP Options
# ATT and GATT Options
# end of ATT and GATT Options
# GATT Services
# end of GATT Services
# end of Bluetooth Host
CONFIG_BT_CTLR_LE_ENC_SUPPORT=y
CONFIG_BT_CTLR_EXT_REJ_IND_SUPPORT=y
CONFIG_BT_CTLR_DATA_LEN_UPDATE_SUPPORT=y
CONFIG_BT_CTLR_PRIVACY_SUPPORT=y
CONFIG_BT_CTLR_EXT_SCAN_FP_SUPPORT=y
CONFIG_BT_CTLR_PHY_UPDATE_SUPPORT=y
CONFIG_BT_CTLR_PHY_2M_SUPPORT=y
CONFIG_BT_CTLR_PHY_CODED_SUPPORT=y
CONFIG_BT_CTLR_ADV_EXT_SUPPORT=y
CONFIG_BT_CTLR_ADV_PERIODIC_SUPPORT=y
CONFIG_BT_CTLR_SYNC_PERIODIC_SUPPORT=y
CONFIG_BT_CTLR_SYNC_TRANSFER_SENDER_SUPPORT=y
CONFIG_BT_CTLR_SYNC_TRANSFER_RECEIVER_SUPPORT=y
CONFIG_BT_CTLR_CHAN_SEL_2_SUPPORT=y
CONFIG_BT_CTLR_SCA_UPDATE_SUPPORT=y
CONFIG_BT_CTLR_CONN_RSSI_SUPPORT=y
CONFIG_BT_CTLR_ECDH_SUPPORT=y
# CONFIG_BT_LL_SW_SPLIT is not set
# BLE Controller configuration
CONFIG_BT_CTLR_CRYPTO=y
CONFIG_BT_CTLR_HCI_VS_BUILD_INFO=&amp;quot;&amp;quot;
CONFIG_BT_CTLR_AD_DATA_BACKUP=y
CONFIG_BT_CTLR_RX_BUFFERS=1
# CONFIG_BT_CTLR_TX_PWR_PLUS_8 is not set
# CONFIG_BT_CTLR_TX_PWR_PLUS_7 is not set
# CONFIG_BT_CTLR_TX_PWR_PLUS_6 is not set
# CONFIG_BT_CTLR_TX_PWR_PLUS_5 is not set
# CONFIG_BT_CTLR_TX_PWR_PLUS_4 is not set
# CONFIG_BT_CTLR_TX_PWR_PLUS_3 is not set
# CONFIG_BT_CTLR_TX_PWR_PLUS_2 is not set
CONFIG_BT_CTLR_TX_PWR_0=y
# CONFIG_BT_CTLR_TX_PWR_MINUS_4 is not set
# CONFIG_BT_CTLR_TX_PWR_MINUS_8 is not set
# CONFIG_BT_CTLR_TX_PWR_MINUS_12 is not set
# CONFIG_BT_CTLR_TX_PWR_MINUS_16 is not set
# CONFIG_BT_CTLR_TX_PWR_MINUS_20 is not set
# CONFIG_BT_CTLR_TX_PWR_MINUS_40 is not set
CONFIG_BT_CTLR_TX_PWR_ANTENNA=0
# CONFIG_BT_CTLR_TX_PWR_DYNAMIC_CONTROL is not set
# BLE Controller features
CONFIG_BT_CTLR_LE_ENC=y
CONFIG_BT_CTLR_ECDH=y
CONFIG_BT_CTLR_EXT_REJ_IND=y
CONFIG_BT_CTLR_LE_PING=y
CONFIG_BT_CTLR_DATA_LENGTH=y
CONFIG_BT_CTLR_PHY=y
# CONFIG_BT_CTLR_CONN_RSSI is not set
# CONFIG_BT_CTLR_FILTER_ACCEPT_LIST is not set
# CONFIG_BT_CTLR_PRIVACY is not set
CONFIG_BT_CTLR_PHY_2M=y
# CONFIG_BT_CTLR_PHY_CODED is not set
CONFIG_BT_CTLR_CHAN_SEL_2=y
# CONFIG_BT_CTLR_ADV_EXT is not set
# CONFIG_BT_CTLR_SET_HOST_FEATURE is not set
# CONFIG_BT_CTLR_HCI_CODEC_AND_DELAY_INFO is not set
# CONFIG_BT_CTLR_ASSERT_HANDLER is not set
# CONFIG_BT_CTLR_TEST is not set
# CONFIG_BT_SHELL is not set
CONFIG_BT_COMPANY_ID=0x05F1
# Controller Area Network (CAN) bus subsystem
# CONFIG_ISOTP is not set
# end of Controller Area Network (CAN) bus subsystem
# CONFIG_CONSOLE_SUBSYS is not set
# CONFIG_CPLUSPLUS is not set
# System Monitoring Options
# CONFIG_THREAD_ANALYZER is not set
# end of System Monitoring Options
# Debugging Options
# CONFIG_DEBUG is not set
# CONFIG_STACK_USAGE is not set
# CONFIG_STACK_SENTINEL is not set
CONFIG_PRINTK=y
CONFIG_EARLY_CONSOLE=y
# CONFIG_ASSERT is not set
# CONFIG_FORCE_NO_ASSERT is not set
CONFIG_ASSERT_VERBOSE=y
# CONFIG_ASSERT_NO_FILE_INFO is not set
# CONFIG_ASSERT_NO_COND_INFO is not set
# CONFIG_ASSERT_NO_MSG_INFO is not set
# CONFIG_ASSERT_TEST is not set
# CONFIG_OVERRIDE_FRAME_POINTER_DEFAULT is not set
# CONFIG_DEBUG_INFO is not set
# CONFIG_DEBUG_THREAD_INFO is not set
# CONFIG_DEBUG_COREDUMP is not set
# end of Debugging Options
# CONFIG_DISK_ACCESS is not set
# CONFIG_EMUL is not set
# CONFIG_CHARACTER_FRAMEBUFFER is not set
# File Systems
# CONFIG_FILE_SYSTEM is not set
# CONFIG_NVS is not set
# end of File Systems
# Inter Processor Communication
# CONFIG_RPMSG_SERVICE is not set
# CONFIG_IPC_SERVICE is not set
# end of Inter Processor Communication
# CONFIG_JWT is not set
# Logging
CONFIG_LOG=y
CONFIG_LOG_MODE_DEFERRED=y
# CONFIG_LOG_MODE_IMMEDIATE is not set
# CONFIG_LOG_MODE_MINIMAL is not set
# CONFIG_LOG_FRONTEND is not set
# CONFIG_LOG_MULTIDOMAIN is not set
# Logging levels filtering
# CONFIG_LOG_RUNTIME_FILTERING is not set
CONFIG_LOG_OVERRIDE_LEVEL=0
CONFIG_LOG_MAX_LEVEL=4
# end of Logging levels filtering
# Processing
CONFIG_LOG_PRINTK=y
CONFIG_LOG_MODE_OVERFLOW=y
# CONFIG_LOG_BLOCK_IN_THREAD is not set
CONFIG_LOG_PROCESS_TRIGGER_THRESHOLD=10
CONFIG_LOG_PROCESS_THREAD=y
CONFIG_LOG_PROCESS_THREAD_STARTUP_DELAY_MS=0
CONFIG_LOG_PROCESS_THREAD_SLEEP_MS=1000
CONFIG_LOG_PROCESS_THREAD_STACK_SIZE=768
# CONFIG_LOG_PROCESS_THREAD_CUSTOM_PRIORITY is not set
CONFIG_LOG_TRACE_SHORT_TIMESTAMP=y
# CONFIG_LOG_TIMESTAMP_64BIT is not set
# CONFIG_LOG_SPEED is not set
# end of Processing
# Output Formatting
# Prepend non-hexdump log message with function name
# CONFIG_LOG_FUNC_NAME_PREFIX_ERR is not set
# CONFIG_LOG_FUNC_NAME_PREFIX_WRN is not set
# CONFIG_LOG_FUNC_NAME_PREFIX_INF is not set
CONFIG_LOG_FUNC_NAME_PREFIX_DBG=y
# end of Prepend non-hexdump log message with function name
# CONFIG_LOG_MIPI_SYST_ENABLE is not set
# CONFIG_LOG_CUSTOM_FORMAT_SUPPORT is not set
CONFIG_LOG_BACKEND_SHOW_COLOR=y
# CONFIG_LOG_INFO_COLOR_GREEN is not set
CONFIG_LOG_TAG_MAX_LEN=0
CONFIG_LOG_BACKEND_FORMAT_TIMESTAMP=y
# CONFIG_LOG_OUTPUT_FORMAT_LINUX_TIMESTAMP is not set
# end of Output Formatting
# Backends
CONFIG_LOG_BACKEND_RTT=y
# CONFIG_LOG_BACKEND_RTT_MODE_DROP is not set
CONFIG_LOG_BACKEND_RTT_MODE_BLOCK=y
# CONFIG_LOG_BACKEND_RTT_MODE_OVERWRITE is not set
CONFIG_LOG_BACKEND_RTT_OUTPUT_TEXT=y
# CONFIG_LOG_BACKEND_RTT_OUTPUT_DICTIONARY is not set
# CONFIG_LOG_BACKEND_RTT_OUTPUT_CUSTOM is not set
CONFIG_LOG_BACKEND_RTT_OUTPUT_DEFAULT=0
CONFIG_LOG_BACKEND_RTT_OUTPUT_BUFFER_SIZE=16
CONFIG_LOG_BACKEND_RTT_RETRY_CNT=4
CONFIG_LOG_BACKEND_RTT_RETRY_DELAY_MS=5
CONFIG_LOG_BACKEND_RTT_BUFFER=0
# CONFIG_LOG_BACKEND_SWO is not set
CONFIG_LOG_BACKEND_UART=y
CONFIG_LOG_BACKEND_UART_BUFFER_SIZE=1
CONFIG_LOG_BACKEND_UART_AUTOSTART=y
CONFIG_LOG_BACKEND_UART_OUTPUT_TEXT=y
# CONFIG_LOG_BACKEND_UART_OUTPUT_DICTIONARY is not set
# CONFIG_LOG_BACKEND_UART_OUTPUT_CUSTOM is not set
CONFIG_LOG_BACKEND_UART_OUTPUT_DEFAULT=0
# CONFIG_LOG_BACKEND_IPC_SERVICE is not set
# end of Backends
# Misc
CONFIG_LOG_DOMAIN_ID=0
CONFIG_LOG_USE_VLA=y
# CONFIG_LOG_ALWAYS_RUNTIME is not set
# CONFIG_LOG_FMT_SECTION is not set
# CONFIG_LOG_USE_TAGGED_ARGUMENTS is not set
# CONFIG_LOG_MEM_UTILIZATION is not set
CONFIG_LOG_FAILURE_REPORT_PERIOD=1000
# end of Misc
CONFIG_LOG_OUTPUT=y
# end of Logging
# CONFIG_DSP is not set
# Device Management
# Host command handler subsystem
# CONFIG_EC_HOST_CMD is not set
# end of Host command handler subsystem
# CONFIG_MCUMGR is not set
# CONFIG_HAWKBIT is not set
# CONFIG_UPDATEHUB is not set
# CONFIG_OSDP is not set
# end of Device Management
# CONFIG_MODBUS is not set
# Networking
CONFIG_NET_BUF=y
# CONFIG_NET_BUF_LOG is not set
# CONFIG_NET_BUF_LOG_LEVEL_OFF is not set
# CONFIG_NET_BUF_LOG_LEVEL_ERR is not set
# CONFIG_NET_BUF_LOG_LEVEL_WRN is not set
CONFIG_NET_BUF_LOG_LEVEL_INF=y
# CONFIG_NET_BUF_LOG_LEVEL_DBG is not set
CONFIG_NET_BUF_LOG_LEVEL=3
# CONFIG_NET_BUF_POOL_USAGE is not set
# CONFIG_NETWORKING is not set
# end of Networking
# Portability
# end of Portability
# Power Management
# CONFIG_PM_LOG_LEVEL_OFF is not set
# CONFIG_PM_LOG_LEVEL_ERR is not set
# CONFIG_PM_LOG_LEVEL_WRN is not set
CONFIG_PM_LOG_LEVEL_INF=y
# CONFIG_PM_LOG_LEVEL_DBG is not set
CONFIG_PM_LOG_LEVEL=3
# CONFIG_PM_S2RAM is not set
CONFIG_PM_POLICY_DEFAULT=y
# CONFIG_PM_POLICY_CUSTOM is not set
# end of Power Management
# CONFIG_SHELL is not set
# CONFIG_STATS is not set
# CONFIG_USB_DEVICE_STACK is not set
# CONFIG_USBC_STACK is not set
# CONFIG_SD_STACK is not set
# CONFIG_USB_DEVICE_STACK_NEXT is not set
# CONFIG_IMG_MANAGER is not set
# Random Number Generators
# CONFIG_ENTROPY_DEVICE_RANDOM_GENERATOR is not set
# CONFIG_XOROSHIRO_RANDOM_GENERATOR is not set
CONFIG_XOSHIRO_RANDOM_GENERATOR=y
CONFIG_CSPRING_ENABLED=y
CONFIG_HARDWARE_DEVICE_CS_GENERATOR=y
# CONFIG_CTR_DRBG_CSPRNG_GENERATOR is not set
# end of Random Number Generators
# Storage
# CONFIG_STREAM_FLASH is not set
# end of Storage
# CONFIG_SETTINGS is not set
# CONFIG_TASK_WDT is not set
# Testing
# CONFIG_ZTEST is not set
# CONFIG_ZTEST_MOCKING is not set
# CONFIG_ZTRESS is not set
# CONFIG_TEST is not set
CONFIG_COVERAGE_GCOV_HEAP_SIZE=16384
# CONFIG_TEST_USERSPACE is not set
# end of Testing
# CONFIG_TIMING_FUNCTIONS is not set
# CONFIG_TRACING is not set
# CONFIG_RTIO is not set
# CONFIG_ZBUS is not set
# end of Sub Systems and OS Services
CONFIG_TOOLCHAIN_GNUARMEMB=y
# Build and Link Features
# Linker Options
# CONFIG_LINKER_ORPHAN_SECTION_PLACE is not set
CONFIG_LINKER_ORPHAN_SECTION_WARN=y
# CONFIG_LINKER_ORPHAN_SECTION_ERROR is not set
CONFIG_HAS_FLASH_LOAD_OFFSET=y
# CONFIG_USE_DT_CODE_PARTITION is not set
CONFIG_FLASH_LOAD_OFFSET=0
CONFIG_FLASH_LOAD_SIZE=0
CONFIG_LD_LINKER_SCRIPT_SUPPORTED=y
CONFIG_LD_LINKER_TEMPLATE=y
# CONFIG_CMAKE_LINKER_GENERATOR is not set
# CONFIG_HAVE_CUSTOM_LINKER_SCRIPT is not set
CONFIG_KERNEL_ENTRY=&amp;quot;__start&amp;quot;
CONFIG_LINKER_SORT_BY_ALIGNMENT=y
CONFIG_SRAM_OFFSET=0
# Linker Sections
# CONFIG_LINKER_USE_BOOT_SECTION is not set
# CONFIG_LINKER_USE_PINNED_SECTION is not set
CONFIG_LINKER_GENERIC_SECTIONS_PRESENT_AT_BOOT=y
CONFIG_LINKER_LAST_SECTION_ID=y
CONFIG_LINKER_LAST_SECTION_ID_PATTERN=0xE015E015
# end of Linker Sections
# end of Linker Options
# Compiler Options
# CONFIG_CODING_GUIDELINE_CHECK is not set
# CONFIG_NATIVE_APPLICATION is not set
# CONFIG_SIZE_OPTIMIZATIONS is not set
# CONFIG_SPEED_OPTIMIZATIONS is not set
CONFIG_DEBUG_OPTIMIZATIONS=y
# CONFIG_NO_OPTIMIZATIONS is not set
CONFIG_COMPILER_COLOR_DIAGNOSTICS=y
CONFIG_FORTIFY_SOURCE_NONE=y
# CONFIG_FORTIFY_SOURCE_COMPILE_TIME is not set
# CONFIG_FORTIFY_SOURCE_RUN_TIME is not set
CONFIG_COMPILER_OPT=&amp;quot;&amp;quot;
# CONFIG_MISRA_SANE is not set
# end of Compiler Options
# CONFIG_ASSERT_ON_ERRORS is not set
# CONFIG_NO_RUNTIME_CHECKS is not set
CONFIG_RUNTIME_ERROR_CHECKS=y
# Build Options
CONFIG_KERNEL_BIN_NAME=&amp;quot;zephyr&amp;quot;
CONFIG_OUTPUT_STAT=y
# CONFIG_OUTPUT_SYMBOLS is not set
CONFIG_OUTPUT_DISASSEMBLY=y
# CONFIG_OUTPUT_DISASSEMBLE_ALL is not set
CONFIG_OUTPUT_PRINT_MEMORY_USAGE=y
# CONFIG_CLEANUP_INTERMEDIATE_FILES is not set
# CONFIG_BUILD_NO_GAP_FILL is not set
CONFIG_BUILD_OUTPUT_BIN=y
# CONFIG_BUILD_OUTPUT_EXE is not set
# CONFIG_BUILD_OUTPUT_S19 is not set
# CONFIG_BUILD_OUTPUT_UF2 is not set
# CONFIG_BUILD_OUTPUT_STRIPPED is not set
# CONFIG_APPLICATION_DEFINED_SYSCALL is not set
# CONFIG_MAKEFILE_EXPORTS is not set
# CONFIG_BUILD_OUTPUT_META is not set
# end of Build Options
CONFIG_WARN_DEPRECATED=y
CONFIG_ENFORCE_ZEPHYR_STDINT=y
# end of Build and Link Features
# Boot Options
# CONFIG_IS_BOOTLOADER is not set
# CONFIG_BOOTLOADER_BOSSA is not set
# end of Boot Options
# Compatibility
CONFIG_COMPAT_INCLUDES=y
# end of Compatibility
# CONFIG_LEGACY_INCLUDE_PATH is not set&lt;/pre&gt;&lt;br /&gt;&lt;/span&gt;&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: DSPI example on Zephyr / nRF Connect SDK</title><link>https://devzone.nordicsemi.com/thread/423325?ContentTypeID=1</link><pubDate>Tue, 02 May 2023 13:41:33 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:6736c13b-dc06-4a46-bb37-05e36e7b715b</guid><dc:creator>haakonsh</dc:creator><description>&lt;p&gt;Can you share&amp;nbsp;&lt;span&gt;build/zephyr/.config?&amp;nbsp;&lt;/span&gt;&lt;/p&gt;
&lt;p&gt;&lt;span&gt;Does your project include the SPIM driver&amp;#39;s header file? &amp;#39;&lt;/span&gt;&lt;span&gt;#include&lt;/span&gt;&lt;span&gt; &lt;/span&gt;&lt;span&gt;&amp;lt;nrfx_spim.h&amp;gt;&amp;#39;&lt;/span&gt;&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: DSPI example on Zephyr / nRF Connect SDK</title><link>https://devzone.nordicsemi.com/thread/423318?ContentTypeID=1</link><pubDate>Tue, 02 May 2023 13:27:49 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:2d41d6f9-5e28-4661-9528-198ee2f905cc</guid><dc:creator>Thurow</dc:creator><description>&lt;p&gt;There is no hit for &lt;span&gt;CONFIG_NRFX_SPIM1&lt;/span&gt; in build/zephyr/.config&lt;br /&gt;This is my prj.conf:&lt;/p&gt;
&lt;p&gt;&lt;code&gt;CONFIG_BT=y&lt;/code&gt;&lt;br /&gt;&lt;code&gt;CONFIG_BT_PERIPHERAL=y&lt;/code&gt;&lt;br /&gt;&lt;br /&gt;&lt;code&gt;CONFIG_LOG=y&lt;/code&gt;&lt;br /&gt;&lt;code&gt;# CONFIG_BT_DEBUG_LOG=y&lt;/code&gt;&lt;br /&gt;&lt;code&gt;CONFIG_UART_CONSOLE=y&lt;/code&gt;&lt;br /&gt;&lt;br /&gt;&lt;code&gt;# Enable Bluetooth Security Manager Protocol&lt;/code&gt;&lt;br /&gt;&lt;code&gt;CONFIG_BT_SMP=y&lt;/code&gt;&lt;br /&gt;&lt;br /&gt;&lt;code&gt;CONFIG_BT_L2CAP_TX_MTU=498&lt;/code&gt;&lt;br /&gt;&lt;code&gt;CONFIG_BT_BUF_ACL_RX_SIZE=502&lt;/code&gt;&lt;br /&gt;&lt;code&gt;CONFIG_BT_BUF_ACL_TX_SIZE=502&lt;/code&gt;&lt;br /&gt;&lt;code&gt;CONFIG_BT_CTLR_DATA_LENGTH_MAX=251&lt;/code&gt;&lt;br /&gt;&lt;code&gt;CONFIG_BT_USER_DATA_LEN_UPDATE=y&lt;/code&gt;&lt;br /&gt;&lt;code&gt;CONFIG_BT_AUTO_DATA_LEN_UPDATE=y&lt;/code&gt;&lt;br /&gt;&lt;code&gt;CONFIG_BT_USER_PHY_UPDATE=y&lt;/code&gt;&lt;br /&gt;&lt;code&gt;CONFIG_BT_AUTO_PHY_UPDATE=y&lt;/code&gt;&lt;br /&gt;&lt;br /&gt;&lt;code&gt;CONFIG_BT_DIS=y&lt;/code&gt;&lt;br /&gt;&lt;code&gt;CONFIG_BT_DIS_PNP=n&lt;/code&gt;&lt;br /&gt;&lt;code&gt;CONFIG_BT_DIS_MODEL=&amp;quot;Rope Encoder&amp;quot;&lt;/code&gt;&lt;br /&gt;&lt;code&gt;CONFIG_BT_DIS_MANUF=&amp;quot;FlexiJet&amp;quot;&lt;/code&gt;&lt;br /&gt;&lt;code&gt;CONFIG_BT_DIS_FW_REV=y&lt;/code&gt;&lt;br /&gt;&lt;code&gt;CONFIG_BT_DIS_HW_REV=y&lt;/code&gt;&lt;br /&gt;&lt;code&gt;CONFIG_BT_DIS_FW_REV_STR=&amp;quot;0.1&amp;quot;&lt;/code&gt;&lt;br /&gt;&lt;code&gt;CONFIG_BT_DIS_HW_REV_STR=&amp;quot;0.1&amp;quot;&lt;/code&gt;&lt;br /&gt;&lt;br /&gt;&lt;code&gt;CONFIG_BT_BAS=y&lt;/code&gt;&lt;br /&gt;&lt;code&gt;CONFIG_ADC=y&lt;/code&gt;&lt;br /&gt;&lt;code&gt;CONFIG_ADC_ASYNC=y&lt;/code&gt;&lt;br /&gt;&lt;br /&gt;&lt;code&gt;CONFIG_BT_DEVICE_NAME=&amp;quot;Rope Encoder&amp;quot;&lt;/code&gt;&lt;br /&gt;&lt;code&gt;CONFIG_BT_DEVICE_APPEARANCE=1344&lt;/code&gt;&lt;br /&gt;&lt;br /&gt;&lt;code&gt;CONFIG_BT_ATT_ENFORCE_FLOW=n&lt;/code&gt;&lt;br /&gt;&lt;code&gt;CONFIG_CBPRINTF_FP_SUPPORT=y&lt;/code&gt;&lt;br /&gt;&lt;code&gt;CONFIG_STDOUT_CONSOLE=y&lt;/code&gt;&lt;br /&gt;&lt;br /&gt;&lt;code&gt;CONFIG_NRFX_SPIM1=y&lt;/code&gt;&lt;br /&gt;&lt;code&gt;CONFIG_SPI=y&lt;/code&gt;&lt;br /&gt;&lt;code&gt;CONFIG_GPIO=y&lt;/code&gt;&lt;br /&gt;&lt;code&gt;CONFIG_SPI_ASYNC=y&lt;/code&gt;&lt;br /&gt;&lt;br /&gt;&lt;code&gt;#CONFIG_SPI_BITBANG=y&lt;/code&gt;&lt;br /&gt;&lt;code&gt;#CONFIG_SPI_EXTENDED_MODES=y&lt;/code&gt;&lt;br /&gt;&lt;br /&gt;&lt;code&gt;CONFIG_SECURE_BOOT_DEBUG=y&lt;/code&gt;&lt;br /&gt;&lt;code&gt;#CONFIG_NO_OPTIMIZATIONS=y&lt;/code&gt;&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: DSPI example on Zephyr / nRF Connect SDK</title><link>https://devzone.nordicsemi.com/thread/423288?ContentTypeID=1</link><pubDate>Tue, 02 May 2023 12:23:27 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:a6138586-aaa1-497e-9c71-44c5441e1b9b</guid><dc:creator>haakonsh</dc:creator><description>[quote user="Thurow"]CONFIG_NRFX_SPIM1=y is set in prj.conf[/quote]
&lt;p&gt;Does the build system set it to &amp;#39;y&amp;#39; or &amp;#39;n&amp;#39;?&amp;nbsp;&lt;br /&gt;&lt;br /&gt;Search build/zephyr/.config for &amp;#39;&lt;span&gt;CONFIG_NRFX_SPIM1&amp;#39; and verify:&lt;/span&gt;&lt;/p&gt;
&lt;ol&gt;
&lt;li&gt;That&amp;nbsp;you get a hit for&amp;nbsp;&amp;#39;&lt;span&gt;CONFIG_NRFX_SPIM1&amp;#39;.&lt;br /&gt;&lt;br /&gt;&lt;/span&gt;&lt;/li&gt;
&lt;li&gt;&lt;span&gt;Where&amp;nbsp;&amp;#39;CONFIG_NRFX_SPIM1=y&amp;#39;.&amp;nbsp;&lt;br /&gt;&lt;br /&gt;&lt;/span&gt;&lt;/li&gt;
&lt;li&gt;&lt;span&gt;And not&amp;nbsp;&amp;#39;#&amp;nbsp;&lt;span&gt;CONFIG_NRFX_SPIM1 is not set&amp;#39;&lt;/span&gt;&lt;/span&gt;&lt;span&gt;&lt;/span&gt;&lt;/li&gt;
&lt;/ol&gt;
&lt;p&gt;&lt;span&gt;&lt;span&gt;&lt;/span&gt;&lt;/span&gt;&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: DSPI example on Zephyr / nRF Connect SDK</title><link>https://devzone.nordicsemi.com/thread/422849?ContentTypeID=1</link><pubDate>Thu, 27 Apr 2023 21:00:36 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:8662f924-6ac4-4e85-8bf9-44d743b146c0</guid><dc:creator>Thurow</dc:creator><description>&lt;p&gt;I have now tried, also using example \modules\hal\nordic\nrfx\samples\src\nrfx_spim\blocking, to change SPI to NFX SPI. But I do not get further already at the beginning. I set&lt;/p&gt;
&lt;p&gt;&lt;code&gt;#include &amp;lt;nrfx_spim.h&amp;gt;&lt;/code&gt;&lt;/p&gt;
&lt;p&gt;, but already the line&lt;/p&gt;
&lt;p&gt;&lt;code&gt;static const nrfx_spim_t spim_inst = NRFX_SPIM_INSTANCE(1);&lt;/code&gt; &lt;/p&gt;
&lt;p&gt;fails, because NRFX_SPIM1_INST_IDX is undefined.&lt;/p&gt;
&lt;p&gt;CONFIG_NRFX_SPIM1=y is set in prj.conf&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: DSPI example on Zephyr / nRF Connect SDK</title><link>https://devzone.nordicsemi.com/thread/415730?ContentTypeID=1</link><pubDate>Thu, 16 Mar 2023 13:43:54 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:8779e015-0f9d-4344-b189-4297f28c40ec</guid><dc:creator>haakonsh</dc:creator><description>&lt;p&gt;I suggest you start by:&lt;/p&gt;
&lt;ol&gt;
&lt;li&gt;Read the&amp;nbsp;&lt;a href="https://infocenter.nordicsemi.com/topic/ps_nrf52840/spim.html?cp=5_0_0_5_24" rel="noopener noreferrer" target="_blank"&gt;SPIM&lt;/a&gt;&amp;nbsp;,and&amp;nbsp;&lt;a href="https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/nrfx/drivers/spim/driver.html#spim-driver" rel="noopener noreferrer" target="_blank"&gt;SPIM driver&lt;/a&gt;&amp;nbsp;and HAL&amp;nbsp;docs.&lt;br /&gt;&lt;br /&gt;&lt;/li&gt;
&lt;li&gt;Read&amp;nbsp;&lt;a href="https://infocenter.nordicsemi.com/topic/ps_nrf52840/timer.html?cp=5_0_0_5_29" rel="noopener noreferrer" target="_blank"&gt;TIMER&lt;/a&gt;,&amp;nbsp;and &lt;a href="https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/nrfx/drivers/timer/driver.html#timer-driver" rel="noopener noreferrer" target="_blank"&gt;TIMER driver&lt;/a&gt;&amp;nbsp;and HAL&amp;nbsp;docs.&lt;br /&gt;&lt;br /&gt;&lt;/li&gt;
&lt;li&gt;Read&amp;nbsp;&lt;a title="PPI" href="https://infocenter.nordicsemi.com/topic/ps_nrf52840/ppi.html?cp=5_0_0_5_15" rel="noopener noreferrer" target="_blank"&gt;PPI&lt;/a&gt;,&amp;nbsp;and &lt;a href="https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/nrfx/drivers/ppi/driver.html#ppi-driver" rel="noopener noreferrer" target="_blank"&gt;PPI driver&lt;/a&gt;&amp;nbsp;and HAL&lt;span&gt;&amp;nbsp;docs.&lt;br /&gt;&lt;br /&gt;&lt;/span&gt;&lt;/li&gt;
&lt;li&gt;Read&amp;nbsp;&lt;a title="EasyDMA" href="https://infocenter.nordicsemi.com/topic/ps_nrf52840/easydma.html?cp=5_0_0_3_5"&gt;EasyDMA&lt;/a&gt;&amp;nbsp;and&amp;nbsp;&lt;a title="EasyDMA array list" href="https://infocenter.nordicsemi.com/topic/ps_nrf52840/easydma.html?cp=5_0_0_3_5_1#arraylist"&gt;EasyDMA array list&lt;/a&gt;&amp;nbsp;docs.&amp;nbsp;&lt;/li&gt;
&lt;/ol&gt;
&lt;p&gt;&lt;/p&gt;
&lt;p&gt;I suggest the following architecture for&amp;nbsp;a 3-pin DSPI driver:&lt;/p&gt;
&lt;p&gt;Use&amp;nbsp;two SPIM instances in EasyDMA ArrayList mode, controlled by one RTC and one TIMER instance via PPI. When ArrayList is enabled you can sample the sensor &amp;#39;x&amp;#39; amount of times before you have to handle any interrupt or buffers, and this will significantly lower the scheduling/context switching overhead of servicing the sensor interface.&lt;/p&gt;
&lt;p&gt;The RTC&amp;nbsp;controls the sample rate by triggering the SPIMs&amp;#39;s&amp;nbsp;&lt;a title="TASKS_START" href="https://infocenter.nordicsemi.com/topic/ps_nrf52840/spim.html?cp=5_0_0_5_24_5_0#register.TASKS_START"&gt;TASKS_START&lt;/a&gt;&amp;nbsp;on a&amp;nbsp;&lt;a href="https://infocenter.nordicsemi.com/topic/ps_nrf52840/rtc.html?cp=5_0_0_5_21_9_6#register.EVENTS_COMPARE-0-3"&gt;EVENTS_COMPARE[n]&lt;/a&gt;&amp;nbsp;match.&amp;nbsp;&lt;/p&gt;
&lt;p&gt;When using the ArrayList feature&amp;nbsp;you now have to count how many SPIM transfers have occured with the TIMER&amp;nbsp;in COUNTER mode, and stop the SPIMs after &amp;#39;x&amp;#39; transfers. This is typically done by counting the numbers of&amp;nbsp;&lt;a title="EVENTS_END" href="https://infocenter.nordicsemi.com/topic/ps_nrf52840/spim.html?cp=5_0_0_5_24_5_6#register.EVENTS_END"&gt;EVENTS_END&lt;/a&gt;&amp;nbsp;generated by one of the SPIMs, and once you have reached your desired number of samples the TIMER&amp;#39;s&lt;span&gt;&amp;nbsp;&lt;a href="https://infocenter.nordicsemi.com/topic/ps_nrf52840/rtc.html?cp=5_0_0_5_21_9_6#register.EVENTS_COMPARE-0-3"&gt;EVENTS_COMPARE[n]&lt;/a&gt;&amp;nbsp;will fire. In the&amp;nbsp;TIMER&amp;#39;s&amp;nbsp;&lt;a href="https://infocenter.nordicsemi.com/topic/ps_nrf52840/rtc.html?cp=5_0_0_5_21_9_6#register.EVENTS_COMPARE-0-3"&gt;EVENTS_COMPARE[n]&lt;/a&gt;&amp;nbsp;ISR you can then&lt;/span&gt;&amp;nbsp;update the SPIMs&amp;#39;s&amp;nbsp;&lt;a title="RXD.PTR" href="https://infocenter.nordicsemi.com/topic/ps_nrf52840/spim.html?cp=5_0_0_5_24_5_19#register.RXD.PTR"&gt;RXD.PTR&lt;/a&gt;&amp;nbsp;registers to point to the next ArrayList buffers, and add you two previous ArrayList buffers to whatever &lt;a href="https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/zephyr/kernel/services/index.html#data-passing"&gt;Data Passing&amp;nbsp;service&lt;/a&gt; you use.&lt;/p&gt;
&lt;p&gt;You only need to connect&amp;nbsp;&lt;a title="PSEL.SCK" href="https://infocenter.nordicsemi.com/topic/ps_nrf52840/spim.html?cp=5_0_0_5_24_5_14#register.PSEL.SCK"&gt;PSEL.SCK&lt;/a&gt;&amp;nbsp;of one of the SPIM&amp;#39;s to a pin, and the two&amp;nbsp;&lt;a title="PSEL.MISO" href="https://infocenter.nordicsemi.com/topic/ps_nrf52840/spim.html?cp=5_0_0_5_24_5_16#register.PSEL.MISO"&gt;PSEL.MISO&lt;/a&gt;s to their respective pins. The rest of the PSEL. registers does not need to be used (&lt;span&gt;Disconnected by default&lt;/span&gt;), so just make sure not to write anything to them.&lt;/p&gt;
&lt;p&gt;All relevant SPIM, RTC, and TIMER tasks and events can be controlled via the PPI system, and the&amp;nbsp;&lt;span&gt;COMPARE[i]_CLEAR shortcut in&amp;nbsp;&lt;a title="SHORTS" href="https://infocenter.nordicsemi.com/topic/ps_nrf52840/timer.html?cp=5_0_0_5_29_4_7#register.SHORTS"&gt;SHORTS&lt;/a&gt;&amp;nbsp;can be used to reset the TIMER&amp;#39;s value in order to continue operation. A separate PPI channel must be used to reset the RTC value by triggering the&amp;nbsp;&lt;a title="TASKS_CLEAR" href="https://infocenter.nordicsemi.com/topic/ps_nrf52840/rtc.html?cp=5_0_0_5_21_9_2#register.TASKS_CLEAR"&gt;TASKS_CLEAR&lt;/a&gt;&amp;nbsp;on it&amp;#39;s&amp;nbsp;&lt;a href="https://infocenter.nordicsemi.com/topic/ps_nrf52840/rtc.html?cp=5_0_0_5_21_9_6#register.EVENTS_COMPARE-0-3"&gt;EVENTS_COMPARE[n]&lt;/a&gt;.&amp;nbsp;&lt;/span&gt;&lt;/p&gt;
&lt;p&gt;You need to make sure that the RXD.PTR registers are updated before the next sample event.&amp;nbsp;&lt;/p&gt;
&lt;p&gt;The only interrupt you will need to enable is the TIMER&amp;#39;s&amp;nbsp;&lt;a href="https://infocenter.nordicsemi.com/topic/ps_nrf52840/timer.html?cp=5_0_0_5_29_4_6#register.EVENTS_COMPARE-0-5"&gt;EVENTS_COMPARE[n]&lt;/a&gt;, the rest can be left disabled.&amp;nbsp;&lt;/p&gt;
&lt;p&gt;The whole interface can be started and stopped by&amp;nbsp;triggering&amp;nbsp;RTC&amp;#39;s &lt;a title="TASKS_START" href="https://infocenter.nordicsemi.com/topic/ps_nrf52840/rtc.html?cp=5_0_0_5_21_9_0#register.TASKS_START"&gt;TASKS_START&lt;/a&gt;&amp;nbsp;and &lt;a title="TASKS_STOP" href="https://infocenter.nordicsemi.com/topic/ps_nrf52840/rtc.html?cp=5_0_0_5_21_9_1#register.TASKS_STOP"&gt;TASKS_STOP&lt;/a&gt;&amp;nbsp;from SW.&amp;nbsp;&lt;/p&gt;
&lt;p&gt;If needed you can disable and enable the SPIM peripherals by writing to their&amp;nbsp;&lt;a title="ENABLE" href="https://infocenter.nordicsemi.com/topic/ps_nrf52840/spim.html?cp=5_0_0_5_24_5_13#register.ENABLE"&gt;ENABLE&lt;/a&gt;&amp;nbsp;register from SW, this will turn of the peripherals and save some power.&lt;/p&gt;
&lt;p&gt;If you find that the RTC&amp;#39;s timing accuracy/precision is too low you can swap it for another TIMER instance.&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: DSPI example on Zephyr / nRF Connect SDK</title><link>https://devzone.nordicsemi.com/thread/415456?ContentTypeID=1</link><pubDate>Wed, 15 Mar 2023 13:00:49 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:a96c8830-aa1b-4d35-ba15-9427ff65f607</guid><dc:creator>Thurow</dc:creator><description>[quote userid="13562" url="~/f/nordic-q-a/97642/dspi-example-on-zephyr-nrf-connect-sdk/415455"]The SPIM peripherals have HW CS pin control so that should not be a problem.[/quote]
&lt;p&gt;Even simpler, with BISS there is no CS, only clock and quasi MISO.&lt;/p&gt;
&lt;p&gt;So the only crucial question remains, where can I find material on how to skillfully implement the DSPI.&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: DSPI example on Zephyr / nRF Connect SDK</title><link>https://devzone.nordicsemi.com/thread/415455?ContentTypeID=1</link><pubDate>Wed, 15 Mar 2023 12:55:09 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:58e8f82e-6ff5-454b-a5a9-d9e423535137</guid><dc:creator>haakonsh</dc:creator><description>[quote user="Thurow"]I send 161 bytes of measured values per packet, so I also stay below the limit for IOS (180 bytes). A first test with 100 packets per second was already successful, so I get the 2000 measurements per second, one measurement needs &amp;quot;packed&amp;quot; 8 bytes.[/quote]
&lt;p&gt;8B*8b*2000 = 128kbps of payload throughput. That should be well within the limits for both 1mbps and 2mbps BLE PHYs, as long as the link quality is not terrible.&amp;nbsp;&lt;/p&gt;
[quote user="Thurow"]7 bytes per 250000, at higher clock rate more bytes (for more space to detect the bussy time / start bit)[/quote]
&lt;p&gt;7B*8b*(1/250000Hz) * 2000 samples/s = 0.448s. That should be fine, as long as the CS pin is toggled in a timely manner. The SPIM peripherals have HW CS pin control so that should not be a problem.&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: DSPI example on Zephyr / nRF Connect SDK</title><link>https://devzone.nordicsemi.com/thread/415303?ContentTypeID=1</link><pubDate>Tue, 14 Mar 2023 16:01:49 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:506ae759-2a18-472e-b38c-b21257f6f011</guid><dc:creator>Thurow</dc:creator><description>[quote userid="13562" url="~/f/nordic-q-a/97642/dspi-example-on-zephyr-nrf-connect-sdk/415285"]Only&amp;nbsp;SPI_LINES_SINGLE is implemented as of now. See&amp;nbsp;zephyr\drivers\spi\spi_nrfx_spim.c:153[/quote]
&lt;p&gt;First of all, thank you very much, good job. Exactly these quotes from the source help to find deeper into the SDK faster and to know where to look! This is my first project with Nordic and also with Zephyr.&lt;/p&gt;
[quote userid="13562" url="~/f/nordic-q-a/97642/dspi-example-on-zephyr-nrf-connect-sdk/415285"]How long are each SPI transfer in bytes?&amp;nbsp;[/quote]
&lt;p&gt;I send 161 bytes of measured values per packet, so I also stay below the limit for IOS (180 bytes). A first test with 100 packets per second was already successful, so I get the 2000 measurements per second, one measurement needs &amp;quot;packed&amp;quot; 8 bytes.&lt;br /&gt;&lt;br /&gt;So now the critical component is the interface DSPI.&lt;/p&gt;
[quote userid="13562" url="~/f/nordic-q-a/97642/dspi-example-on-zephyr-nrf-connect-sdk/415285"]How long are each SPI transfer in bytes?[/quote]
&lt;p&gt;7 bytes per 250000, at higher clock rate more bytes (for more space to detect the bussy time / start bit)&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: DSPI example on Zephyr / nRF Connect SDK</title><link>https://devzone.nordicsemi.com/thread/415285?ContentTypeID=1</link><pubDate>Tue, 14 Mar 2023 15:23:53 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:76ca14fd-445a-4e7d-a188-aa16fa999bdb</guid><dc:creator>haakonsh</dc:creator><description>[quote user="Thurow"]I assume you mean the NRFX QSPI driver. That means the gerneric Zephyr SPI driver in EXTENDED MODES is not implemented &amp;quot;down&amp;quot; to the NRFX driver level at all? Because this is supposed to support multiple channels (SPI_LINES_SINGLE, SPI_LINES_DUAL, SPI_LINES_QUAD, SPI_LINES_OCTAL) according to my understanding from the Zephyr documentation ?[/quote]
&lt;p&gt;Only&amp;nbsp;SPI_LINES_SINGLE is implemented as of now. See&amp;nbsp;zephyr\drivers\spi\spi_nrfx_spim.c:153&lt;br /&gt;&lt;pre class="ui-code" data-mode="c_cpp"&gt;if (IS_ENABLED(CONFIG_SPI_EXTENDED_MODES) &amp;amp;&amp;amp;
    (spi_cfg-&amp;gt;operation &amp;amp; SPI_LINES_MASK) != SPI_LINES_SINGLE) {
	LOG_ERR(&amp;quot;Only single line mode is supported&amp;quot;);
	return -EINVAL;
}&lt;/pre&gt;&lt;/p&gt;
&lt;p&gt;&lt;/p&gt;
[quote user="Thurow"]Different, I just use the buffers of the SPI interface and then extract the BISS protocol step by step, at the beginning on bit level, so I save an extra FPGA. But this is very easy and fast via software.[/quote]
&lt;p&gt;Aah,&amp;nbsp;then that makes this application a lot easier.&amp;nbsp;&lt;/p&gt;
[quote user="Thurow"]Not on the receiver side, where throughput is more important. I am already working on an extra ring buffer, which I fill very efficiently with measured values and then send enlarged BLE packets. The jitter on the receiver side is not so relevant, the important thing is that the measured values must arrive in the throughput.[/quote]
&lt;p&gt;What is the required throughput for the BLE link?&lt;/p&gt;
&lt;p&gt;How long are each SPI transfer in bytes?&amp;nbsp;&lt;/p&gt;
&lt;p&gt;fyi: In case you need to timestamp the samples the TIMER peripheral can capture the current time based on HW events like when an SPIM peripheral has finished a transfer.&amp;nbsp;&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: DSPI example on Zephyr / nRF Connect SDK</title><link>https://devzone.nordicsemi.com/thread/415260?ContentTypeID=1</link><pubDate>Tue, 14 Mar 2023 14:39:22 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:b28b16e8-d974-4fe6-b725-9c867c710778</guid><dc:creator>Thurow</dc:creator><description>[quote userid="13562" url="~/f/nordic-q-a/97642/dspi-example-on-zephyr-nrf-connect-sdk/415154"]There&amp;#39;s no BISS driver in Zephyr, so you will have to write or port one.&amp;nbsp;[/quote]
&lt;p&gt;This has already been done, not as a real driver but &amp;quot;in application&amp;quot; for certain reasons.&lt;/p&gt;
&lt;p&gt;&lt;/p&gt;
[quote userid="13562" url="~/f/nordic-q-a/97642/dspi-example-on-zephyr-nrf-connect-sdk/415154"]As for the DSPI interface I&amp;#39;ll have to do a bit of digging, we might be able to coax the &lt;a href="https://infocenter.nordicsemi.com/topic/ps_nrf52840/qspi.html?cp=5_0_0_5_18"&gt;QSPI peripheral&lt;/a&gt;&amp;nbsp;into a DSPI interface. Two &lt;a href="https://infocenter.nordicsemi.com/topic/ps_nrf52840/spim.html?cp=5_0_0_5_24"&gt;SPIM peripherals&lt;/a&gt;&amp;nbsp;will also work if they are controlled PPI events.[/quote]
&lt;p&gt;I assume you mean the NRFX QSPI driver. That means the gerneric Zephyr SPI driver in EXTENDED MODES is not implemented &amp;quot;down&amp;quot; to the NRFX driver level at all? Because this is supposed to support multiple channels (SPI_LINES_SINGLE, SPI_LINES_DUAL, SPI_LINES_QUAD, SPI_LINES_OCTAL) according to my understanding from the Zephyr documentation ?&lt;/p&gt;
[quote userid="13562" url="~/f/nordic-q-a/97642/dspi-example-on-zephyr-nrf-connect-sdk/415154"]I believe we will manage the real-time requirements just fine, but it will require a bit of work as the generic zephyr drivers are not designed for very tight real-time requirements.&amp;nbsp;&lt;br /&gt;[/quote]
&lt;p&gt;Thanks for this tip, it saves me a lot of work! I will switch directly to NRFX SPI driver. Does this also affect the direct GPIO control?&lt;/p&gt;
[quote userid="13562" url="~/f/nordic-q-a/97642/dspi-example-on-zephyr-nrf-connect-sdk/415154"]Can you share the DSPI transfer specs?&amp;nbsp;like Opcodes, CLK freqency, etc. Also part number for the encoders would be great as I might spot some helpful features.&amp;nbsp;[/quote]
&lt;p&gt;Different, I just use the buffers of the SPI interface and then extract the BISS protocol step by step, at the beginning on bit level, so I save an extra FPGA. But this is very easy and fast via software. At the moment I work with 7 byte buffers, which are sufficient to receive the BISS messages with 48 bits plus enough space for start bit detection etc. Clock rate is 250000, maybe I will double it.&lt;/p&gt;
[quote userid="13562" url="~/f/nordic-q-a/97642/dspi-example-on-zephyr-nrf-connect-sdk/415154"]What&amp;nbsp;are your hard timing limits with regard to data acquisition jitter and processing latency?&amp;nbsp;[/quote]
&lt;p&gt;Not on the receiver side, where throughput is more important. I am already working on an extra ring buffer, which I fill very efficiently with measured values and then send enlarged BLE packets. The jitter on the receiver side is not so relevant, the important thing is that the measured values must arrive in the throughput.&lt;/p&gt;
[quote userid="13562" url="~/f/nordic-q-a/97642/dspi-example-on-zephyr-nrf-connect-sdk/415154"]Do you have any hard memory limits with regard to buffers, stacks, and heaps?[/quote]
&lt;p&gt;No, and so far I don&amp;#39;t see any problems coming. The evaluation of the data takes place at the host. I just have to send them quickly.&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: DSPI example on Zephyr / nRF Connect SDK</title><link>https://devzone.nordicsemi.com/thread/415154?ContentTypeID=1</link><pubDate>Tue, 14 Mar 2023 11:44:11 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:e9d03094-9952-4a8e-907d-975729bdd4fa</guid><dc:creator>haakonsh</dc:creator><description>&lt;ol&gt;
&lt;li&gt;There&amp;#39;s no BISS driver in Zephyr, so you will have to write or port one.&amp;nbsp;&lt;br /&gt;&lt;br /&gt;&lt;/li&gt;
&lt;li&gt;As for the DSPI interface I&amp;#39;ll have to do a bit of digging, we might be able to coax the &lt;a href="https://infocenter.nordicsemi.com/topic/ps_nrf52840/qspi.html?cp=5_0_0_5_18"&gt;QSPI peripheral&lt;/a&gt;&amp;nbsp;into a DSPI interface. Two &lt;a href="https://infocenter.nordicsemi.com/topic/ps_nrf52840/spim.html?cp=5_0_0_5_24"&gt;SPIM peripherals&lt;/a&gt;&amp;nbsp;will also work if they are controlled PPI events.&lt;br /&gt;&lt;br /&gt;I suggest you use the nrfx drivers and HAL directly for this BISS interface, they can be found in ncs\modules\hal\nordic\nrfx\. There&amp;#39;s also samples that work with zephyr in&amp;nbsp;modules\hal\nordic\nrfx\samples\src\.&amp;nbsp;&lt;br /&gt;&lt;br /&gt;I believe we will manage the real-time requirements just fine, but it will require a bit of work as the generic zephyr drivers are not designed for very tight real-time requirements.&amp;nbsp;&lt;br /&gt;&lt;br /&gt;&lt;/li&gt;
&lt;li&gt;If you do end up writing or porting an open source BISS driver (with a permissive license) it would be great if you&amp;nbsp;would consider adding it to the Zephyr Project ^^.&lt;br /&gt;&lt;br /&gt;&lt;/li&gt;
&lt;li&gt;[quote user="Thurow"]The whole thing is also still somewhat time-critical, 2x2000 measured values are acquired per second with an angular accuracy &amp;gt;=19 bits in order to determine very precise positions in space.[/quote]
&lt;p&gt;Can you share the DSPI transfer specs?&amp;nbsp;like Opcodes, CLK freqency, etc. Also part number for the encoders would be great as I might spot some helpful features.&amp;nbsp;&lt;/p&gt;
&lt;/li&gt;
&lt;li&gt;What&amp;nbsp;are your hard timing limits with regard to data acquisition jitter and processing latency?&amp;nbsp;&lt;br /&gt;&lt;br /&gt;&lt;/li&gt;
&lt;li&gt;Do you have any hard memory limits with regard to buffers, stacks, and heaps?&lt;/li&gt;
&lt;/ol&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: DSPI example on Zephyr / nRF Connect SDK</title><link>https://devzone.nordicsemi.com/thread/415016?ContentTypeID=1</link><pubDate>Mon, 13 Mar 2023 20:11:26 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:c7fd03b2-5de7-428e-9f65-381542960f32</guid><dc:creator>Thurow</dc:creator><description>&lt;p&gt;This is a bit complicated. Finally I use SPI with a driver interface ala RS485 to read two encoders according to the BISS standard. Therefore also the question about the DSPI, because I need the angle values exactly at the same time and therefore control both encoders with one clock line. So in reality I only use MISO of the two channels. The whole thing is also still somewhat time-critical, 2x2000 measured values are acquired per second with an angular accuracy &amp;gt;=19 bits in order to determine very precise positions in space.&lt;br /&gt;Only important for me is the configuration of the pins for DSPI in the devicetree and the inclusion in the source file. For SPI with one channel I managed all that, but for the conversion to DSPI I just lack a template. Zephyr I have also already configured to the extended SPI mode.&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: DSPI example on Zephyr / nRF Connect SDK</title><link>https://devzone.nordicsemi.com/thread/415014?ContentTypeID=1</link><pubDate>Mon, 13 Mar 2023 20:02:36 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:46d95306-ab10-4350-b4fc-388e5c55cdac</guid><dc:creator>haakonsh</dc:creator><description>&lt;p&gt;What device are you interfacing with? Can you share its datasheet?&amp;nbsp;&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item></channel></rss>
