nRF Connect for Desktop Bluetooth Low Energy Standalone v4.0.4 - freezing on "Found device type: unknown. J-Link firmware: J-Link OB-nRF5340-NordicSemi compiled Dec 3 2012 15:46:49
When using the software, the app freezes on - Found device type: unknown. J-Link firmware: J-Link OB-nRF5340-NordicSemi compiled Dec 3 2012 15:46:49.
If I first flash any program using vs code, then try the Bluetooth app again it no longer freezes and finishes the setup of the device. Has anyone experienced this or what other information do you need to help me resolve this issue.
  • 15:12:42.868
    Using nrf-device-lib-js version: 0.4.4
    15:12:42.869
    Using nrf-device-lib version: 0.10.3
    15:12:42.869
    Using nrfjprog DLL version: 10.15.1
    15:12:42.869
    Using JLink version: JLink_V7.80c
    15:12:42.953
    Installed JLink version does not match the provided version (V7.66a)
    15:12:42.964
    15:12:42.983
    [nrfdl][warning](15:12:42.944) JlinkArm version non expected one found: JLink_V7.80c, expected: JLink_V7.58b
    15:12:59.730
    Selected device with s/n 001050346905
    15:13:00.742
    [nrfdl][error](15:13:00.739) NRFDLException(9): async task failure for id: 715991010640 msg: NOT_AVAILABLE_BECAUSE_PROTECTION
    15:13:02.978
    Uploading image through JLink: 0%
    15:13:03.054
    [nrfdl][error](15:13:03.051) NRFDLException(9): async task failure for id: 715993309900 msg: NOT_AVAILABLE_BECAUSE_PROTECTION
    15:13:03.055
    Device programming completed.
    15:13:03.061
    Device setup completed
    15:13:03.061
    Getting information from J-Link debugger...
    15:13:03.061
    Found device type: unknown. J-Link firmware: J-Link OB-nRF5340-NordicSemi compiled Dec 3 2021 15:46:49.
    15:13:04.004
    [nrfdl][error](15:13:04.001) NRFDLException(9): async task failure for id: 715994328436 msg: NOT_AVAILABLE_BECAUSE_PROTECTION
  • After flashing with blinky program:
    15:14:19.569
    Device closed. --Flashed blinky onto board then retried--
    15:15:48.249
    15:15:55.062
    15:15:57.243
    Uploading image through JLink: 100%
    15:15:57.449
    15:15:58.764
    15:15:58.764
    15:15:58.764
    15:16:00.172
    Connectivity firmware version: 4.1.4. SoftDevice API version: 5.
    15:16:00.172
    Opening adapter connected to COM5
    15:16:01.000
    Successfully opened COM5. Baud rate: 1000000. Flow control: none. Parity: none.
    15:16:01.003
    Reset performed on adapter COM5
    15:16:02.119
    Adapter connected to COM5 opened
    Does this mean that you fixed the issue?
    From the log in your other comment
    This looks like your device was locked (APPROTECT). Running a nrfjprog --recover should fix this, it erases all user flash memory and disables the readback protection mechanism if enabled.
  • running nrfjprog --recover fixed the issue!! Thank you very much!
  • Was there any way to disable the read back protection? Every time I power off the unit it re-enables the read back protection.
