<?xml-stylesheet type="text/xsl" href="https://devzone.nordicsemi.com/cfs-file/__key/system/syndication/rss.xsl" media="screen"?><rss version="2.0" xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:slash="http://purl.org/rss/1.0/modules/slash/" xmlns:wfw="http://wellformedweb.org/CommentAPI/" xmlns:atom="http://www.w3.org/2005/Atom"><channel><title>nRF connect VC Code, enable command line use</title><link>https://devzone.nordicsemi.com/f/nordic-q-a/98028/nrf-connect-vc-code-enable-command-line-use</link><description>Hi, with the new versions of ncs the vs code extension gets configured to be used with the gui interface nicely, but i have come accustomed to using the command line to build/flash, and getting the partition manager report, which I cannot seem to find</description><dc:language>en-US</dc:language><generator>Telligent Community 13</generator><lastBuildDate>Tue, 28 Mar 2023 11:13:58 GMT</lastBuildDate><atom:link rel="self" type="application/rss+xml" href="https://devzone.nordicsemi.com/f/nordic-q-a/98028/nrf-connect-vc-code-enable-command-line-use" /><item><title>RE: nRF connect VC Code, enable command line use</title><link>https://devzone.nordicsemi.com/thread/417857?ContentTypeID=1</link><pubDate>Tue, 28 Mar 2023 11:13:58 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:b6c6bb02-7fa1-408b-8ff5-7435d6d8250b</guid><dc:creator>y009</dc:creator><description>&lt;p&gt;Duh, when you said open from nrf connect, i just used the open vs code button.&lt;br /&gt;Opening a terminal then using that to open vscode, does indeed work.&amp;nbsp;&lt;br /&gt;&lt;br /&gt;Thanks&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: nRF connect VC Code, enable command line use</title><link>https://devzone.nordicsemi.com/thread/417847?ContentTypeID=1</link><pubDate>Tue, 28 Mar 2023 10:31:09 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:13d82aa0-f37a-46dd-a098-570ecd072257</guid><dc:creator>Vidar Berg</dc:creator><description>&lt;p&gt;I do not see how this would not work for you.&amp;nbsp; Did you do the same as outlined in the steps below?&lt;/p&gt;
&lt;p&gt;1. Open command prompt from the Toolchain manager app&lt;/p&gt;
&lt;p&gt;&lt;img style="max-height:240px;max-width:320px;" src="https://devzone.nordicsemi.com/resized-image/__size/640x480/__key/communityserver-discussions-components-files/4/pastedimage1679998788401v1.png" alt=" " /&gt;&lt;/p&gt;
&lt;p&gt;2. From the command prompt, open VS code by running &amp;#39;code .&amp;#39; (Note: &amp;#39;code.exe&amp;#39; must be in PATH for this to work)&lt;/p&gt;
&lt;p&gt;&lt;img style="max-height:240px;max-width:320px;" src="https://devzone.nordicsemi.com/resized-image/__size/640x480/__key/communityserver-discussions-components-files/4/pastedimage1679998848193v2.png" alt=" " /&gt;&lt;/p&gt;
&lt;p&gt;3. Verify that the env. variables have been inherited in the VS code terminal by echoing the ZEPHYR BASE variable&lt;/p&gt;
&lt;p&gt;&lt;img style="max-height:240px;max-width:320px;" src="https://devzone.nordicsemi.com/resized-image/__size/640x480/__key/communityserver-discussions-components-files/4/pastedimage1679999097256v3.png" alt=" " /&gt;&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: nRF connect VC Code, enable command line use</title><link>https://devzone.nordicsemi.com/thread/417827?ContentTypeID=1</link><pubDate>Tue, 28 Mar 2023 08:26:11 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:15fc00e1-3a28-47df-aeff-3576ee5d076f</guid><dc:creator>y009</dc:creator><description>&lt;p&gt;Doesn&amp;#39;t seem to change anything.&lt;br /&gt;&lt;br /&gt;Though it did give me a hint - the settings page in vscode.&lt;br /&gt;The&amp;nbsp;&lt;span&gt;&amp;nbsp;&lt;/span&gt;&lt;span&gt;&amp;quot;nrf-connect.....&amp;quot; variables as far as i understand control these, and I&amp;#39;d need to get them working outside of the nrf-connect extensions scope.&amp;nbsp;&lt;/span&gt;&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: nRF connect VC Code, enable command line use</title><link>https://devzone.nordicsemi.com/thread/417798?ContentTypeID=1</link><pubDate>Tue, 28 Mar 2023 06:50:37 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:9cae75ea-920d-4e25-820d-9c8d8aa21d60</guid><dc:creator>Vidar Berg</dc:creator><description>&lt;p&gt;The env. variables are exported if you open the terminal via the toolchain manager app. Have you tried that?&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: nRF connect VC Code, enable command line use</title><link>https://devzone.nordicsemi.com/thread/417795?ContentTypeID=1</link><pubDate>Tue, 28 Mar 2023 06:37:07 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:478249e6-f37a-42d8-af95-1ce1523c580d</guid><dc:creator>y009</dc:creator><description>&lt;p&gt;Thanks but, sadly doesnt work for me, since&amp;nbsp;the commands arent added to path by by default, at least with the latest nrf connect version on windows. &lt;br /&gt;&lt;br /&gt;Hoping there are some commands from previous version i could utilize to get the same functionality&lt;br /&gt;&lt;br /&gt;&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: nRF connect VC Code, enable command line use</title><link>https://devzone.nordicsemi.com/thread/416985?ContentTypeID=1</link><pubDate>Thu, 23 Mar 2023 08:53:14 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:7e21b0e4-a8ef-4620-b4b7-a7ba35b3383b</guid><dc:creator>Vidar Berg</dc:creator><description>&lt;p&gt;Hi,&lt;/p&gt;
&lt;p&gt;There are probably other ways to do this, but my workflow involves opening VS code from the terminal with &amp;#39;code .&amp;#39;. This makes terminal in VS code inherit the env. variables (ZEPHYR_BASE, etc) from the terminal it was opened from.&amp;nbsp;&lt;/p&gt;
&lt;p&gt;Best regards,&lt;/p&gt;
&lt;p&gt;Vidar&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item></channel></rss>
