<?xml-stylesheet type="text/xsl" href="https://devzone.nordicsemi.com/cfs-file/__key/system/syndication/rss.xsl" media="screen"?><rss version="2.0" xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:slash="http://purl.org/rss/1.0/modules/slash/" xmlns:wfw="http://wellformedweb.org/CommentAPI/" xmlns:atom="http://www.w3.org/2005/Atom"><channel><title>How to make PinTime board a connected device in VSCode using nRF Connect add-in</title><link>https://devzone.nordicsemi.com/f/nordic-q-a/98525/how-to-make-pintime-board-a-connected-device-in-vscode-using-nrf-connect-add-in</link><description>I got the pinetime board setup in VSCode, thanks to Don J. but I do not see the device connected:
 I have a pinetime dev kit connected through a ST-Link v2 and have used openocd to flash it in the past. Is there a way to make it appear as a connected</description><dc:language>en-US</dc:language><generator>Telligent Community 13</generator><lastBuildDate>Mon, 17 Apr 2023 11:55:50 GMT</lastBuildDate><atom:link rel="self" type="application/rss+xml" href="https://devzone.nordicsemi.com/f/nordic-q-a/98525/how-to-make-pintime-board-a-connected-device-in-vscode-using-nrf-connect-add-in" /><item><title>RE: How to make PinTime board a connected device in VSCode using nRF Connect add-in</title><link>https://devzone.nordicsemi.com/thread/420756?ContentTypeID=1</link><pubDate>Mon, 17 Apr 2023 11:55:50 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:b9f16a67-d0b5-404c-9dff-8eeb73e5376f</guid><dc:creator>Elfving</dc:creator><description>&lt;p&gt;Great! Let me know when you&amp;#39;ve tried it out, and if it works for you :)&lt;/p&gt;
&lt;p&gt;Regards,&lt;/p&gt;
&lt;p&gt;Elfving&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: How to make PinTime board a connected device in VSCode using nRF Connect add-in</title><link>https://devzone.nordicsemi.com/thread/420720?ContentTypeID=1</link><pubDate>Mon, 17 Apr 2023 10:25:58 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:45ba294d-9a62-49e7-a373-e130ca6c2804</guid><dc:creator>lcj</dc:creator><description>&lt;p&gt;That is very helpful. Thank you. Here is what I was looking at and clearly doing it wrong:&lt;br /&gt;&lt;img style="max-height:240px;max-width:320px;" src="https://devzone.nordicsemi.com/resized-image/__size/640x480/__key/communityserver-discussions-components-files/4/pastedimage1681727116664v2.png" alt=" " /&gt;&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: How to make PinTime board a connected device in VSCode using nRF Connect add-in</title><link>https://devzone.nordicsemi.com/thread/420669?ContentTypeID=1</link><pubDate>Mon, 17 Apr 2023 07:52:29 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:6c837d69-8b1d-4205-b6f1-3ed1e9bd545e</guid><dc:creator>Elfving</dc:creator><description>[quote user="lcj"]I guess at some point a SEGGER J-link Programmer may be a necessity.[/quote]
&lt;p&gt;I am not really seeing why you wouldn&amp;#39;t be able to continue with the Onboard Programmer for now at least.&lt;/p&gt;
[quote user="lcj"]Also, I was reading &lt;a href="https://infocenter.nordicsemi.com/topic/ug_nrf52832_dk/UG/dk/ext_programming_support_P20.html"&gt;the documentation&lt;/a&gt; and think it&amp;#39;s might be wrong. Look at line 5 in the table:[/quote]
&lt;p&gt;Ah yes I guess it should say SWCLK there, I&amp;#39;ll report that internally. Thanks for the heads-up! :)&lt;/p&gt;
[quote user="lcj"]I&amp;#39;m trying to find the GND pin here and can&amp;#39;t. [/quote]
&lt;p&gt;Any GND would do. You can use the GND pin here, or &lt;a href="https://infocenter.nordicsemi.com/topic/ug_nrf52832_dk/UG/dk/ext_programming_support_P20.html"&gt;using the illustration from the documentation you&amp;#39;ve linked me&lt;/a&gt; to.&lt;/p&gt;
&lt;p&gt;&lt;img style="max-height:123px;max-width:283px;" height="123" src="https://devzone.nordicsemi.com/cfs-file/__key/communityserver-discussions-components-files/4/3750.pastedimage1646400005206v1.png" width="283" alt=" " /&gt;&lt;/p&gt;
[quote user="lcj"]Ok. I connected the GND/3.3v to the ST-LinkV2 and the CLK/IO to the DK, which powers up the PineTime. I tried to flash it and got this in the terminal:[/quote]
&lt;p&gt;If you want to use the ST-link for this you&amp;#39;re on your own. It might be possible to get it to work but it is not an nRF Tool and not supported by us. This might not make a difference, could you try doing this again without the ST Link and see if that works?&lt;/p&gt;
&lt;p&gt;Elfving&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: How to make PinTime board a connected device in VSCode using nRF Connect add-in</title><link>https://devzone.nordicsemi.com/thread/420609?ContentTypeID=1</link><pubDate>Sat, 15 Apr 2023 12:56:55 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:59b63b78-0c4a-4ede-a1db-202137deb414</guid><dc:creator>lcj</dc:creator><description>&lt;p&gt;Ok. I connected the GND/3.3v to the ST-LinkV2 and the CLK/IO to the DK, which powers up the PineTime. I tried to flash it and got this in the terminal:&lt;br /&gt;&lt;br /&gt;&lt;/p&gt;
&lt;p&gt;&lt;pre class="ui-code" data-mode="text"&gt;FATAL ERROR: board pinetime_devkit0 does not support runner nrfjprog&lt;/pre&gt;&lt;/p&gt;
&lt;p&gt;I&amp;#39;m just trying to use the simple ble peripheral example:&lt;br /&gt;&lt;img style="max-height:240px;max-width:320px;" alt=" " src="https://devzone.nordicsemi.com/resized-image/__size/640x480/__key/communityserver-discussions-components-files/4/pastedimage1681563402671v1.png" /&gt;&lt;/p&gt;
&lt;p&gt;&lt;/p&gt;
&lt;p&gt;Here are the lines from the Terminal in VS Code:&lt;br /&gt;&lt;pre class="ui-code" data-mode="text"&gt;-- west flash: using runner nrfjprog
To fix, configure this runner in /opt/nordic/ncs/v2.3.0/zephyr/boards/arm/pinetime_devkit0/board.cmake and rebuild.
&lt;p&gt;&lt;/p&gt;
&lt;p&gt;I&amp;#39;m not sure how I need to configure. I did order the Seggar J-Link Plus (compact), but am not sure if that changes anything.&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: How to make PinTime board a connected device in VSCode using nRF Connect add-in</title><link>https://devzone.nordicsemi.com/thread/420608?ContentTypeID=1</link><pubDate>Sat, 15 Apr 2023 12:28:13 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:a9cc0806-c91e-4555-be89-7696039ae2af</guid><dc:creator>lcj</dc:creator><description>&lt;p&gt;I&amp;#39;m trying to find the GND pin here and can&amp;#39;t. Also, I was reading &lt;a href="https://infocenter.nordicsemi.com/topic/ug_nrf52832_dk/UG/dk/ext_programming_support_P20.html"&gt;the documentation&lt;/a&gt; and think it&amp;#39;s might be wrong. Look at line 5 in the table:&lt;br /&gt;&lt;img style="max-height:240px;max-width:320px;" alt=" " src="https://devzone.nordicsemi.com/resized-image/__size/640x480/__key/communityserver-discussions-components-files/4/pastedimage1681561581232v1.png" /&gt;&lt;/p&gt;
&lt;p&gt;And the drawing looks like this:&lt;br /&gt;&lt;img style="max-height:240px;max-width:320px;" alt=" " src="https://devzone.nordicsemi.com/resized-image/__size/640x480/__key/communityserver-discussions-components-files/4/pastedimage1681561640957v2.png" /&gt;&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: How to make PinTime board a connected device in VSCode using nRF Connect add-in</title><link>https://devzone.nordicsemi.com/thread/420496?ContentTypeID=1</link><pubDate>Fri, 14 Apr 2023 12:14:39 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:d507cbf8-e558-46df-88fd-5a666112f79d</guid><dc:creator>lcj</dc:creator><description>&lt;p&gt;I do have a DK and Don J. pointed me to the fact you can connect using &lt;a href="https://www.nordicsemi.com/Products/Development-hardware/nRF52-DK/GetStarted"&gt;On-board SEGGER J-Link debugger/programmer&lt;/a&gt;, which I am trying to do now. I guess at some point a SEGGER J-link Programmer may be a necessity. The configuration challenges of the environment are significant for me. I am reading&amp;nbsp;the &lt;a href="https://infocenter.nordicsemi.com/topic/ug_nrf52832_dk/UG/dk/hw_debug_out_segger53.html"&gt;Debug out for programming external boards&lt;/a&gt;&amp;nbsp;now to see how I can connect it to the &lt;a href="https://docs.zephyrproject.org/latest/boards/arm/pinetime_devkit0/doc/index.html"&gt;4 PineTime connections&lt;/a&gt;.&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: How to make PinTime board a connected device in VSCode using nRF Connect add-in</title><link>https://devzone.nordicsemi.com/thread/419777?ContentTypeID=1</link><pubDate>Tue, 11 Apr 2023 14:26:11 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:4c0d5807-4df2-4e7b-9db0-7d870f62f26a</guid><dc:creator>Elfving</dc:creator><description>&lt;p&gt;Hello,&lt;/p&gt;
&lt;p&gt;I believe the ST Link v2 is mainly for ST devices, &lt;a href="https://devzone.nordicsemi.com/f/nordic-q-a/21415/flashing-nrf52832-chip-with-st-link-v2/83987"&gt;though there might be a way for you to get it working with our devices&lt;/a&gt;.&lt;/p&gt;
&lt;p&gt;What would probably be optimal would be to get a proper SEGGER J-link Programmer, though if those are too expensive you can also simply use the debug out of an nRF DK. I do not know a lot about pinetime &lt;a href="https://wiki.pine64.org/wiki/PineTime_Devkit_Wiring"&gt;though it seems you can program it using SWD&lt;/a&gt;. Do you have a DK?&lt;/p&gt;
&lt;p&gt;Elfving&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: How to make PinTime board a connected device in VSCode using nRF Connect add-in</title><link>https://devzone.nordicsemi.com/thread/419435?ContentTypeID=1</link><pubDate>Fri, 07 Apr 2023 14:14:56 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:56695556-7e27-4bdc-b5db-fc587cb2940f</guid><dc:creator>wbober</dc:creator><description>&lt;p&gt;As per documentation J-Link is required.&amp;nbsp;&lt;a href="https://nrfconnect.github.io/vscode-nrf-connect/reference/ui_sidebar_connected_devices.html"&gt;Connected Devices View - nRF Connect for VS Code&lt;/a&gt;&lt;/p&gt;
&lt;p&gt;&lt;img style="max-height:240px;max-width:320px;" alt=" " src="https://devzone.nordicsemi.com/resized-image/__size/640x480/__key/communityserver-discussions-components-files/4/pastedimage1680876886001v1.png" /&gt;&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item></channel></rss>
