<?xml-stylesheet type="text/xsl" href="https://devzone.nordicsemi.com/cfs-file/__key/system/syndication/rss.xsl" media="screen"?><rss version="2.0" xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:slash="http://purl.org/rss/1.0/modules/slash/" xmlns:wfw="http://wellformedweb.org/CommentAPI/" xmlns:atom="http://www.w3.org/2005/Atom"><channel><title>Intermitting problem with the nRF5340</title><link>https://devzone.nordicsemi.com/f/nordic-q-a/99272/intermitting-problem-with-the-nrf5340</link><description>Dear Devzone,
 We have developed a medical product that consist of the Fanstel BC40C/nRF5340 module and includes custom nRF5340 firmware and a BLE monitoring app for both Apple and Android OS. The unit runs from a 3.7v lithium cell that provides power</description><dc:language>en-US</dc:language><generator>Telligent Community 13</generator><lastBuildDate>Wed, 03 May 2023 14:56:21 GMT</lastBuildDate><atom:link rel="self" type="application/rss+xml" href="https://devzone.nordicsemi.com/f/nordic-q-a/99272/intermitting-problem-with-the-nrf5340" /><item><title>RE: Intermitting problem with the nRF5340</title><link>https://devzone.nordicsemi.com/thread/423605?ContentTypeID=1</link><pubDate>Wed, 03 May 2023 14:56:21 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:69cc519d-118c-4556-9270-16324f59f799</guid><dc:creator>JONATHAN LL</dc:creator><description>&lt;p&gt;Want to add one additional comment:&lt;br /&gt;&lt;br /&gt;Errata 160 is less likely at room temps, are the devices used somewhere cold?&amp;nbsp;&lt;br /&gt;&lt;br /&gt;I would say that the number one suspect from the info you have shared so gar is the errata 161.&amp;nbsp;&lt;br /&gt;&lt;br /&gt;&lt;br /&gt;Are you using approtect? If so then you cant watch&amp;nbsp;what&amp;#39;s happening when the device gets stuck.&amp;nbsp;&lt;br /&gt;If you set&amp;nbsp;&lt;strong&gt;CONFIG_NRF_APPROTECT_LOCK=n&lt;/strong&gt; then you should be able to connect a debugger and see what is happening when it gets stuck.&amp;nbsp;&lt;br /&gt;&lt;br /&gt;And are you using watchdog timers to reset the device ? could maybe be a workaround.&amp;nbsp;&lt;br /&gt;&lt;br /&gt;Regards,&lt;br /&gt;Jonathan&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: Intermitting problem with the nRF5340</title><link>https://devzone.nordicsemi.com/thread/423395?ContentTypeID=1</link><pubDate>Tue, 02 May 2023 20:35:25 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:42aa5a53-f424-423b-9811-0389dd64911f</guid><dc:creator>JONATHAN LL</dc:creator><description>&lt;p&gt;Hi Jeff and thanks for posting!&lt;br /&gt;&lt;br /&gt;Will gladly do my best to help here so thanks for all the details.&amp;nbsp;&lt;br /&gt;&lt;br /&gt;&lt;br /&gt;&lt;/p&gt;
[quote user=""]Our FW has also been tested and verified to work on the nRF5340-DK board but not over extended periods of time.[/quote]
&lt;p&gt;Would be good to know if the issue is reproducible on the nRF5340DK then I would be very confident to exclude firmware if it does not happen.&amp;nbsp;&lt;br /&gt;&lt;br /&gt;&lt;br /&gt;&lt;br /&gt;&lt;/p&gt;
[quote user=""]It seems all units will eventually stop working if allowed to operate long enough.[/quote]
&lt;p&gt;Do you have any data on witch devices has experienced&amp;nbsp;the issue and how often it. Could be good to know if some units are more prone to the issue.&amp;nbsp;&lt;br /&gt;&lt;br /&gt;Have you been in contact with&amp;nbsp;Fanstel regarding the issue to see if they have any info on this. &lt;br /&gt;&lt;br /&gt;If this is a due to the chip having a bug or faulty from production in some way then we would like to have the SoC build code. Could you provide this to us. (We can make a private ticket and do any info exchange there that you don&amp;#39;t want public)&lt;br /&gt;&lt;br /&gt;&lt;br /&gt;I can do a HW review of device and see if there is anything to comment on.&lt;br /&gt;&lt;br /&gt;You could also share you application and we could have a look but its often more difficult to find any issues this way if we don&amp;#39;t have the device to test on. But if the issue is reproducible on the nRF5340DK then this is one way forward.&amp;nbsp;&lt;br /&gt;&lt;br /&gt;&lt;br /&gt;Edit:&lt;br /&gt;Are you using DCDC? if so then&amp;nbsp;&lt;a href="https://devzone.nordicsemi.com/members/qwertynoon"&gt;qwertynoon&lt;/a&gt;&amp;nbsp;comment could be something to test on a couple of units. Currently not aware of a anything DCDC related that could fit the issue you describe.&amp;nbsp;&lt;br /&gt;Do you have&amp;nbsp;&lt;span&gt;CONFIG_RESET_ON_FATAL_ERROR=y ?&lt;/span&gt;&lt;br /&gt;&lt;br /&gt;And are you following the workaround for &lt;a href="https://infocenter.nordicsemi.com/topic/errata_nRF5340_Rev1/ERR/nRF5340/Rev1/latest/anomaly_340_161.html?cp=4_0_1_0_1_30"&gt;Errata 161&lt;/a&gt;? If not then if you have an assert that is triggered or after a system off it can put the device in a stuck state. The workaround was added to main a month ago,&amp;nbsp;&lt;a href="https://github.com/NordicSemiconductor/nrfx/blame/master/hal/nrf_reset.h#L177"&gt;https://github.com/NordicSemiconductor/nrfx/blame/master/hal/nrf_reset.h#L177&lt;/a&gt;&amp;nbsp;, make sure to incorporate this.&lt;br /&gt;&lt;br /&gt;&lt;br /&gt;Regards,&lt;br /&gt;Jonathan&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: Intermitting problem with the nRF5340</title><link>https://devzone.nordicsemi.com/thread/423172?ContentTypeID=1</link><pubDate>Tue, 02 May 2023 06:42:23 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:7bc115d3-ee45-47fd-9724-240fe2b6edfd</guid><dc:creator>qwertynoon</dc:creator><description>&lt;p&gt;I would advise you to run your test with DCDC turned off (CONFIG_BOARD_ENABLE_DCDC=n) and whether this bug will happen. I have a bitter experience with this functionality.&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item></channel></rss>
