GDB error when trying to launch debugger
I'm developing using vscode and Nordic pluggin, Windows 10 OS. When I try to launch debugger, I get the following message:
"Unable to start debugging. Unexpected GDB output from command "-target-select-extended-remote 127.0.0.1:63241". Remote communication error. Target disconnected.: No such file or directory."
The launch configuration is the default:
	"launch": {
		"version": "0.2.0",
		"configurations": [
				"type": "nrf-connect",
				"request": "launch",
				"name": "Launch build",
				"config": "${workspaceFolder}/build",
				"runToEntryPoint": "main"
How can I make it run?
Thanks in advance,
Pedro.
    Please create a new ticket and upload support information from the VS Code extension.
    1. Open the command palette (Ctrl + Shift + P or View > Command Palette).
    2. Write "nRF Connect: Generate support information" and press enter.
    3. Copy the entire support information output.
    4. Upload it using Insert > Code or upload a .txt file with Insert > Image/video/file.
    Make sure to remove confidential information you do not want to be shared in a public case.
    Marte
