Bluetooth Channel Sounding Comes to iPhone: Distance Measurement for Both Ecosystems
Summary
As of October 2026, Bluetooth Channel Sounding works with both Android and iOS. iOS 27 supports it on iPhone 17 and later, with the exception of the iPhone 17e, and Android has supported it on select phones since Android 16 QPR2 in December 2025. One extra requirement applies to accessories that want to work with iPhone: Inline PCT Transfer (IPT). Nordic’s nRF54L Series supports both Channel Sounding and IPT, so a single accessory design can reach both ecosystems.
Why distance matter (and why it’s been hard)
Imagine a smart-home device that automatically opens the correct menu in the accompanying mobile app if you’re moving towards a specific device with the app open. For some devices, the ability to know the distance between the device and your phone is a valuable feature. For example, beacons and asset-tracking tags could use distance to aid in the locating of a lost device or checkpoint by displaying the distance on the phone screen.
For both phone and accessory device manufacturers, the way to implement this has been through use of dedicated ultra-wideband (UWB) chipsets. This hardware needs to be added to both the phone and the accessory, which plants it firmly into a category of premium feature, with limited ecosystem support and low standardization across manufacturers. Measuring distance using the Bluetooth signal-strength (RSSI) is technically possible, but highly unreliable and inaccurate. It is also vulnerable to spoofing for security-related and sensitive use cases like smart locks.
What is Channel Sounding?
Enter Bluetooth Channel Sounding. Adopted by the Bluetooth SIG as an optional feature of the Bluetooth Core specification 6.0, it introduces a method for using the Bluetooth radio, which is already ubiquitous in both phones and accessories, to accurately gauge the range between two devices. This differs greatly from the legacy way of doing this using the Bluetooth RSSI only.
Channel Sounding measures distance by exchanging tones between the two devices and looking at how their phase shifts across many frequencies. This is much more accurate and reliable than RSSI, which is extremely susceptible to line-of-sight interference (objects between the two devices), with a claimed accuracy of down to the half-a-meter level. It also cross-checks the measured distance by looking at the tones' round-trip timing for an added sanity check, which makes it much harder to spoof in a security attack.
Why the phone support was the missing piece
After being adopted by the Bluetooth SIG in September 2024, devices using Bluetooth Channel Sounding between two Bluetooth LE devices started appearing, mostly as a curiosity within specialized markets. This started to change with the release of the first non-beta mobile OS in Android 16 QPR2 in December 2025, and the first consumer products with Bluetooth ranging features started hitting the market. But for the majority of smartphone owners, Channel Sounding features were still unreachable. It required specific models of supported Android phones, not even being supported by new flagship phones from many vendors, and with no word on support from Apple in their iPhones.
iOS 27 joins brings Channel Sounding to iPhone
With the public release of iOS 27, distance measurement with Bluetooth Channel Sounding is now officially supported on all new Apple iPhones from the iPhone 17 onwards, with a notable exception of the iPhone 17e as Apple’s official spec sheet lists it as Bluetooth 5.3. Previously, Bluetooth Channel Sounding has only been available to Android users on certain smartphone models. For device manufacturers with Channel Sounding-enabled hardware products and accompanying smartphone apps, this means Bluetooth Channel Sounding features can now be implemented to reach customers on both ecosystems.
In North America, an important market for phone-connected devices, the iOS ecosystem has over 50 % market share of the smartphone market. With an average replacement cycle of iPhones just around 4 years, a conservative estimate is that Channel Sounding-compatible iPhones will cover more than 30 % of the North American smartphone market by the start of 2030.
It will take a while before all iPhone users can take advantage of these features. However, being available on new iPhones from the two latest generations vastly increases the number of devices, as not all Android devices, even recently released ones support Bluetooth 6.0’s optional Channel Sounding feature on the hardware level. Support in the iOS ecosystem is therefore the real starting signal for mass-market adoption of Bluetooth ranging.
However, iOS puts one extra requirement on device manufacturers to use Channel Sounding features: Inline PCT Transfer (IPT). IPT allows the phase correction term (PCT) to be transmitted in the same exchange as the Channel Sounding event itself. This saves energy and reduces the latency of the procedure. Not all Bluetooth SoC vendors can support IPT with their existing hardware.
See it in action: Nordic demonstrates using the nRF54L15 tag as a Channel Sounding reflector using Apple’s iOS ranging APIs.
Android and iOS support at a glance
Android
iOS
Channel Sounding support since
Android 16 QPR2 (puiblic release, December 2nd, 2025)
iOS 27 (public release, September 14th, 2026)
Supported phones
Select models with Channel Sounding hardware support
iPhone 17 series and later (not iPhone 17e)
Bluetooth requirement
Bluetooth 6.0 or later with Channel Sounding
Bluetooth 6.3 or later with Channel Sounding
Accessory requirement
Channel Sounding
Channel Sounding plus Inline PCT Transfer (IPT)
Nordic SoCs supported
nRF54L Series (except nRF54LS05A and nRF54LS05B)
nRF54L Series: ready for both platforms
From the inception of the nRF54L Series of Bluetooth and multiprotocol wireless SoCs, Channel Sounding has been a key feature supported across every device in the series, except the nRF54LS05A and nRF54LS05B SoCs. Nordic works closely with the Bluetooth SIG, and the nRF54L Series has been designed with future advancements of the Bluetooth Core spec in mind. This gives Nordic the ability to support new features almost from the very day they’re adopted by the Bluetooth spec. As an example, when Bluetooth Channel Sounding was adopted by the spec, the first Channel Sounding sample was ready for merging into the nRF Connect SDK. And when IPT was later adopted, Nordic had already put in place the necessary features in their hardware, so that it could be supported by a simple update in the SDK. In fact, IPT is now supported on every nRF54L Series SoC that supports Bluetooth Channel Sounding. This means that Nordic is the first chip vendor to publicly support Channel Sounding across both Android and iOS, furthering Nordic’s reputation of having the industry’s best interoperability across all ecosystems.
What you can build
Secure, accurate distance measurement from a standard Bluetooth radio opens up products that used to need dedicated UWB hardware, or that were never reliable enough with signal strength alone. With both major phone platforms now covered, a few use cases stand out:
  • Digital car keys and vehicle access. Unlock or start the car when the key is actually close, not just when a signal happens to be strong enough, and make relay-style attacks much harder to pull off.
  • Smart locks and door access. Open the door as you walk up to it, with the round-trip timing cross-check adding protection against spoofing.
  • Finding lost items. Trackers and tags can show a real distance on the phone screen as you get closer, instead of a vague "nearby".
  • Asset and tool tracking. Confirm that equipment is at the right checkpoint, workstation or room, without dedicated infrastructure.
  • Context-aware smart-home and interactive interfaces. An app that opens the right controls for the specific device you are walking towards.
Until now, building any of these meant choosing which part of your customers you could serve. That choice is going away.
Get started, and what's next
Whether you are building a product from scratch or adding ranging to an existing one, the fastest way to see how it works on both platforms is to try it:
  • Watch the demo video above to see an nRF54L15 working with iOS ranging.
  • Access the iOS sample project to build your own Channel Sounding iOS app: Apple Developer Documentation
  • Build the Channel Sounding sample in the nRF Connect SDK: nRF Connect SDK documentation
  • Ask questions and share what you are building on DevZone: Nordic DevZone
iOS adds one extra requirement for accessories: Inline PCT Transfer. In our next blog post, we will take a closer look at IPT, what it changes in the Channel Sounding procedure, and what it takes to enable it on the nRF54L Series. Stay tuned.
