Keil + nrfjprog = true
  • nrfjprog --help
  • Pressing: Win+Break or
  • Opening Control Panel >> System >> Advanced >> Environment Variables or
  • Right-clicking My Computer and click on properties
  1. Then click on Advanced system setting
  2. Click on Environment Variables...
  • Pressing Tools >> Customize Tools Menu...
If you are using nRF52 you will have to specify --family nrf52 as an additional argument, like this:
Programming SoftDevices
The parameters are:
  • Command: nrfjprog
  • Initial Folder: [YOUR_SDK_LOCATION]\SDK11\components\softdevice\s130\hex
  • Arguments: --program s130_nrf51_2.0.0-7.alpha_softdevice.hex
I chose to call my tool program_sd130, however you can call this anything you like.
Final words
