Hello, I would like to use a custom flash memory layout for the flash memory of nrf52:
I thought that I should be able to use the UICR.NRFFW[0] - if I set to the start address of my application, SD should jump there (instead of bootloader, for which this register is usually used). However when I set the start address of my application to UICR.NRFFW[0] I end up in a hard-fault handler. Is there some other consideration that I should take into account when realizing this scenario? Is it supposed to work the way I imagine?
