i am using a blend micro with nRF8001. and i am using it as a hub in my project.Now i am getting a range of 13 meters.but that is not enough for my project.so can i increase the transmission power to increase the range...?
What power have you set the nRF8001 and blend micro to?
Are either a custom board, if so did you tune the RF parts properly?
Finally, what kind of environment are you getting the 13 m range in? Solid surfaces nearby can affect the range of the system.
Øyvind
i am using a blend micro from redBear lab. an it work in the default 0dbm power. I am getting a range of 13M in line of sight
Then you can try increasing to +4 dBm output power and see if your range improves. Be aware that this will increase current consumption.
