After finding that Windows doesn't like HID devices if they can't be bonded to, I've been attempting to add peer_manager and bonding into my application.
However, having added it I'm getting loads of problems. I can connect normally, but:
Bonding (using nRF Connect) appears to work, but immediately after disconnecting, I get NRF_ERROR_NOT_FOUND
from pm_whitelist_set
in the BLE_GAP_EVT_DISCONNECTED
handler (and the device resets).
Even after removing all the whitelist code (which I'm not too worried about), when attempting to bond I get NRF_ERROR_INTERNAL
which comes via the PM_EVT_ERROR_UNEXPECTED
handler (and the device also resets)
Any thoughts what could be the issue here? The internal error sounds a bit worrying.
The code that changed in order to add the peer manager without whitelist :
github.com/.../c969f3c52cb39cd0a66df6da4e22d61241486071...BLE_peer_manager_no_whitelist
Same code, but with the whitelist:
Is there anything obvious I've missed here? It kind of seemed like I'd got everything, but it's hard to tell from just looking through the HID example.
