Im using sdk 11.0 and s130 When i add pstorag codes to my project which has bluetooth communication ,it does not work I wanna send data to flash and i wanna read it What is the shortest and simplest way to do this
Thank you
Thank you
You can find a pstorage example for SDK 11 here, and you can read more about pstorage here.
You should also check out fstorage too.The pstorage module was removed in SDK12, and its usage has been replaced by fstorage. fstorage is a much more modern and flexible solution. The usage of fstorage is described in the infocenter: Experimental: Flash Storage. The full API is described here.
I would also recommend that you check out the Flash Data Storage module, which is built on fstorage. This module abstracts away the lower levels of fstorage and provides a simple flash file-system.
Thank you for fastly answer.
