I cannot start Power Profiler Kit software. I followed the installing instructions, but ended up with the following:
>python.exe ppk.py
File "ppk.py", line 19, in <module>
missing = str(ie).split("named ")[1]
IndexError: list index out of range
By modifying the ppk.py I found out that the problem is probably with the lines:
import pyqtgraph as pg
from pyqtgraph.Qt import QtCore, QtGui
The error message seems to be:
DLL load failed: %1 is not a valid Win32 application
Sounds strange, a missing DLL, or what could be the solution for this problem?
This problem happened with a Windows 7 and a Windows 8.1 machine.
