I see on your website that Bluetooth 5 throughput numbers are given in the graph below. And the following disclaimer is given.
"Net data throughput not including overhead such as addressing can be as high as 1.4Mbs"
I see where this number comes from, but I believe the overhead such as addressing and limits placed on the number of packets per connection. How realistic are these numbers for a connection involving an iOS device?
iOS has a relatively long minimum connection interval of 20ms and only accepts 4 packets per connection. I assume for the graph these values were optimised, with very short connection intervals, and more packets per connection.
I am under the impression that iOS also currently does not support Data Length Extension, so the packet size would be limited to 27 bytes.
