Hi all, I'm using sdk11.0.0 signed bootloader and I have custom board with dfu support. The custom board have device type ex:0x01 now I need to change device type to ex:0x02
I created a sd+bootloader+application.zip with device type 0x01 but the bootloader firmware in that zip have device type 0x02. when I try to update that zip file first it updating sd+bootloader firmware successfully then it disconnect and connect again and start dfu to update application firmware but at these time it fails and giving error as device type failed
when I see manifest.json for both sd+bootloader and application have same device type
And I'm using command to create zip file is
Is their any option to create zip file with different device types for sd+bootloader and application
Thanks in advance
