hi,all i use use dongle as packet sniffer.when the phone can not connect my device,the dongle can not receive CONNECT_REQ PDU.if the phone can connect with my device,the dongle can receive CONNECT_REQ PDU; QS1:why can not receive CONNECT_REQ PDU when phone can not connect with device? QS2:the CONNECT_REQ PDU is from phone? QS3:when the phone connect with device,how long send CONNNECT_REQ PDU?
QS4:the 37 channel(2402MHZ) data is still not correct,and the rssi is weak(connect device is ok,and the device use DTM example,the 2402MHZ is 2402.168MHz by using the spectrometer
),but the 38 39 channel is correct,and rssi is normal.
so i change the Crystals matching capacitance,from 30pf to 12pf,the 37 channel is correct.
Why appear this kind of phenomenon?
QS5:i use the time_init create a timer(1s),and the lfclk is from NRF_CLOCK_LFCLKSRC_RC_250_PPM_TEMP_16000MS_CALIBRATION or NRF_CLOCK_LFCLKSRC_RC_250_PPM_250MS_CALIBRATION,the accuracy is very bad.Run 24 hours later, the timer error between 1-20 seconds(fast or low),Whether the internal crystals have a problem or firmware has a problem?
