i m new in nrf51822 controller so help me for coding of my question. any help will be appriciate. thank you.
Take a look at the PWM library example in the SDK. It's located in the folder <SDK_InstallFolder>\examples\peripheral\pwm_library
. You can get a 1kHz square wave by setting the period to 1000 us:
// 2-channel PWM as used in the example
app_pwm_config_t pwm1_cfg = APP_PWM_DEFAULT_CONFIG_2CH(1000L, BSP_LED_0, BSP_LED_1);
// 1-channel PWM
app_pwm_config_t pwm1_cfg = APP_PWM_DEFAULT_CONFIG_1CH(1000L, PIN_NUMBER);
Use the function app_pwm_channel_duty_set() to set the desired duty cycle:
while (app_pwm_channel_duty_set(&PWM1, 0, 50) == NRF_ERROR_BUSY); // 50%
