Hi all,
I have understood that sys_evt_dispatch is used for all events that aren't BLE but concern the softdevice.
I start to develop my code on gls_example, here in sys_evt_dispatch there are two function
static void sys_evt_dispatch(uint32_t sys_evt)
fs_sys_event_handler(sys_evt);
ble_advertising_on_sys_evt(sys_evt);
Someone can explain me what does this function do? Can i don't use it? ( I need on my application have a pairing and bonding).
void fs_sys_event_handler(uint32_t sys_evt)
fs_op_t * const p_op = &m_queue.op[m_queue.rp];
if (m_flags & FS_FLAG_PROCESSING)
// A flash operation was initiated by this module. Handle the result.
switch (sys_evt)
case NRF_EVT_FLASH_OPERATION_SUCCESS:
on_operation_success(p_op);
case NRF_EVT_FLASH_OPERATION_ERROR:
on_operation_failure(p_op);
else if ((m_flags & FS_FLAG_FLASH_REQ_PENDING))
// A flash operation was initiated outside this module.
// A callback which indicates that it has finished was received.
m_flags &= ~FS_FLAG_FLASH_REQ_PENDING;
// If there are any elements left in the queue, set FS_FLAG_PROCESSING.
if (m_queue.count > 0)
m_flags |= FS_FLAG_PROCESSING;
// Resume processing the queue, if necessary.
queue_process();
void ble_advertising_on_sys_evt(uint32_t sys_evt)
uint32_t err_code = NRF_SUCCESS;
switch (sys_evt)
// Fall through.
//When a flash operation finishes, advertising no longer needs to be pending.
if (m_advertising_start_pending)
m_advertising_start_pending = false;
err_code = ble_advertising_start(m_adv_mode_current);
if ((err_code != NRF_SUCCESS) && (m_error_handler != NULL))
m_error_handler(err_code);
// No implementation needed.
I have seen that if i comment them have some problems, so i would understand better what this function do.
Thanks, Anna
