My DFU is staying in the bootloader, even after successful download of the application package.
I have modified the secure bootloader for my custom PCB (removed the GPIO for the button check), so that is not an issue.
I can make the DFU "work" if I just initially install the bootloader and softdevice only. The app will start nicely with my app only package.
However, if I generate the combined bootloader, SD and app hex file by manually creating the bootloader settings and adding it to the combined hex file according with the method in Hung Bui's blog ("Getting started with Nordic's Secure DFU bootloader, a step by step guide"), the OTA app will not start and the device stays in the bootloader mode.
When I generate the app package, I have increased the version by "1" over the value I put in the manually generated settings file (from 3 to 4) so it should be setting the app valid flag. I can't debug the bootloader, because I'm using the IAR platform and there seems to be a bug with debugging the bootloader.
Any suggestions to help figure out why the bootloader is not accepting the app would be appreciated.
