Story Short: When trying to run the ble_app_uart example on a custom board with a nRF51822QFAAH0 chip, the code faults and resets at the point in tries to call sd_softdevice_enable.
What are the prerequisites for running the examples of the new SDK on nRF51822QFAAH0?
Long Explanation:
I am on a MBP, OSX 10.11.6
I have downloaded the most recent (as of April 25th, 2017) SDK in
~/Downloads/nrfdev/nRF5_SDK_12
My current version of arm-none-eabi-gcc
is installed via homebrew.
Install directory is in:
/usr/local/Cellar/arm-none-eabi-gcc/20150921/bin
and with a symbolic link to:
/usr/local/bin
In order to compile I have changed the Makefile.posix
in
~/Downloads/nrfdev/nRF5_SDK_12/components/toolchain/gcc
so that the first line
GNU_INSTALL_ROOT := /usr/local/gcc-arm-none-eabi-4_9-2015q3
now reads
If I go to
~/Downloads/nrfdev/nRF5_SDK_12/examples/ble_peripheral/ble_app_uart/pca10028/s130/armgcc
and run “make” it compiles.
I have a Bluz board (Raytac MDBT40-236R based on nRF51822QFAC-A1) to which I connect my MBP via the ST-LINK on a STM32F4DISCOVERY board (version MB997C).
I then use openocd to flash the softdevice and code with a shell script which contains one line:
openocd -f interface/stlink-v2.cfg -f target/nrf51.cfg -c "init; reset halt;nrf51 mass_erase; program ../../../../../../components/softdevice/s130/hex/s130_nrf51_2.0.1_softdevice.hex verify;program ./_build/nrf51422_xxac.hex verify;reset
This works, and I can see the Nordic_UART in the nRF Toolbox app on my iPhone. If I change RX_PIN_NUMBER to 12 and TX_PIN_NUMBER to 12, then, when connecting the Bluz chip with a FTDI TTL-232R cable, I can also send and see messages between a serial console on my MBP and the nRF Toolbox app on my phone. So this works.
Now, I have a custom board with a nRF51822QFAA-H0.
As far as I can tell from the infocenter compatibility matrix, this particular chip (16kB RAM, IC rev 3) should work with SDK12 and s130.
But when I upload to this chip the Nordic_UART never shows up on my phone. This is somewhat expected, as the code uploaded is based on the pca10028 SD board with 32kB RAM.
So I change this line in the linker file ble_app_uart_gcc_nrf51.ld
RAM (rwx) : ORIGIN = 0x20001fe8, LENGTH = 0x6018
to
RAM (rwx) : ORIGIN = 0x20001fe8, LENGTH = 0x2018
so that we use a total of 0x4000 (16kB) instead of 0x8000 (32kB) of RAM.
I also insert a breakpoint in the main function in the main.c file, just before entering the function ble_stack_init()
Using gdb to step through from here I get this output:
$ arm-none-eabi-gdb _build/nrf51422_xxac.out --silent -ex "target remote localhost:3333"
Reading symbols from _build/nrf51422_xxac.out...done.
Remote debugging using localhost:3333
main () at ../../../main.c:601
601 __BKPT(1);
(gdb) s
0x0001d89e in ble_stack_init () at ../../../main.c:391
391 nrf_clock_lf_cfg_t clock_lf_cfg = NRF_CLOCK_LFCLKSRC;
(gdb)
Note: automatically using hardware breakpoints for read-only addresses.
394 SOFTDEVICE_HANDLER_INIT(&clock_lf_cfg, NULL);
(gdb)
softdevice_handler_init (p_clock_lf_cfg=p_clock_lf_cfg@entry=0x20003f70,
p_ble_evt_buffer=p_ble_evt_buffer@entry=0x20002420 <BLE_EVT_BUFFER.8118>,
ble_evt_buffer_size=ble_evt_buffer_size@entry=72,
evt_schedule_func=evt_schedule_func@entry=0x0)
at ../../../../../../components/softdevice/common/softdevice_handler/softdevice_handler.c:261
261 return NRF_ERROR_INVALID_PARAM;
(gdb)
259 if (p_ble_evt_buffer == NULL)
(gdb)
265 if (!is_word_aligned(p_ble_evt_buffer))
(gdb)
283 bool power_clock_isr_enabled = nrf_drv_common_irq_enable_check(POWER_CLOCK_IRQn);
(gdb)
nrf_drv_common_irq_enable_check (IRQn=POWER_CLOCK_IRQn)
at ../../../../../../components/drivers_nrf/common/nrf_drv_common.h:269
269 return 0 != (NVIC->ISER[(((uint32_t)(int32_t)IRQn) >> 5UL)] &
(gdb)
at ../../../../../../components/softdevice/common/softdevice_handler/softdevice_handler.c:270
270 mp_ble_evt_buffer = (uint8_t *)p_ble_evt_buffer;
(gdb)
271 m_ble_evt_buffer_size = ble_evt_buffer_size;
(gdb)
(gdb)
(gdb)
at ../../../../../../components/softdevice/common/softdevice_handler/softdevice_handler.c:271
(gdb)
279 m_evt_schedule_func = evt_schedule_func;
(gdb)
(gdb)
(gdb)
at ../../../../../../components/softdevice/common/softdevice_handler/softdevice_handler.c:284
284 if (power_clock_isr_enabled)
(gdb)
300 err_code = sd_softdevice_enable(p_clock_lf_cfg, softdevice_fault_handler);
(gdb)
sd_softdevice_enable (p_clock_lf_cfg=0x20003f70,
fault_handler=fault_handler@entry=0x1efd1 <softdevice_fault_handler>)
at ../../../../../../components/softdevice/s130/headers/nrf_sdm.h:229
229 SVCALL(SD_SOFTDEVICE_ENABLE, uint32_t, sd_softdevice_enable(nrf_clock_lf_cfg_t const * p_clock_lf_cfg, nrf_fault_handler_t fault_handler));
(gdb) next
0x00000750 in ?? ()
(gdb)
calling backtrace this shows in a more condensed version.
(gdb) bt
#0 0x00000750 in ?? ()
#1 <signal handler called>
#2 0x0001efc6 in sd_softdevice_enable (p_clock_lf_cfg=0x20003f70,
#3 0x0001f0f0 in softdevice_handler_init (
at ../../../../../../components/softdevice/common/softdevice_handler/softdevice_handler.c:300
#4 0x0001d8b4 in ble_stack_init () at ../../../main.c:394
#5 main () at ../../../main.c:602
(gdb)
I have tried setting a breakpoint the softdevice_fault_handler
in softdevice_handler.c, but it does not reach it.
I am quite aware that it is probably because I have not configured memory regions correctly, but having a hard time figuring out what to do.
Does anyone have any suggestions?
