I have a device in the central role that connects to a device with a specific name. I then do a db_discovery_start
to get the handles of two of the characteristics. However, it takes a while for the BLE_DB_DISCOVERY_COMPLETE
to be triggered (approx 750 - 1000ms). Is there anyway I can speed this up, or get rid of db_discovery altogether? Some additional points:
- I know the UUID of the characteristics
- I know the properties of the characteristic
- I will only ever connect to a device with these characteristics (if I do connect to a device without these characteristics I am happy for an error to be thrown and a reset triggered)
I am using:
- nRF52832
- S132 v4.0.2
- SDK13
My current ble_db_discovery_evt_handler()
code is below:
static void ble_db_discovery_evt_handler(ble_db_discovery_evt_t *p_evt)
ble_gatt_db_char_t * p_chars = p_evt->params.discovered_db.charateristics;
uint8_t second_handle;
if(p_evt->evt_type == BLE_DB_DISCOVERY_COMPLETE)
if(p_evt->params.discovered_db.srv_uuid.uuid == BLE_UNIQUE_SERVICE_UUID)
NRF_LOG_INFO("Found Service \r\n");
for (uint32_t i = 0; i < p_evt->params.discovered_db.char_count; i++)
switch(p_chars[i].characteristic.uuid.uuid)
case FIRST_CHARACTERISTC_UUID:
first_handle = p_chars[i].characteristic.handle_value;
case SECOND_CHARACTERISTC_UUID:
second_handle = p_chars[i].characteristic.handle_value;
sd_ble_gattc_read(p_evt->conn_handle, second_handle, 0);
ble_db_discovery_start(&m_ble_db_discovery[p_evt->conn_handle], p_evt->conn_handle);
NRF_LOG_WARNING("No DB Discovered: %d \r\n", p_evt->evt_type);
Thanks in advance,
