My android app give me this "register with gatt stack failed" error on Samsung S7 marshmallow. The scenario is that I am working with 21 BLE peripherals (nrf52). I scan available devices and then connect => write data => disconnect device one by one. After trying a few times, it give me this error. If i exist the application , it is recover back. Please help!
Already Try : Write on main UI thread for all connectGatt, disconnectGatt method.
The following is my logcat :
05-14 17:45:05.254 5018-5200/? E/BtGatt.GattService: [GSIM LOG]: gsimLogHandler: com.example.jinghu.smartmagazine, msg: MESSAGE_STOP_SCAN
05-14 17:45:05.254 5018-5182/? E/BtGatt.ScanManager: default value of curScanSetting 0 is choosen
05-14 17:45:08.064 5018-5115/? E/BluetoothRemoteDevices: aclStateChangeCallback: State:Connected to Device:F5:E8:84:5E:09:XX, linktype is 2
05-14 17:45:08.094 5018-5352/? E/bt_btif: already has a pending command!!
05-14 17:45:08.804 5018-5115/? E/bt_btif_gatt: bta_to_btif_uuid: Unknown UUID length 63201!
05-14 17:45:09.434 24160-24160/com.example.jinghu.smartmagazine E/UartService: mBluetoothGatt nullandroid.bluetooth.BluetoothGatt@4ed0d4f
05-14 17:45:09.604 5018-5352/? E/bt_btif: Connection doesnt exist. Drop indication!
05-14 17:45:10.254 5018-5352/? E/bt_btm: btm_ble_get_search_if search_if=4
05-14 17:45:10.254 5018-5352/? E/bt_btif: bta_gattc_mark_bg_conn unable to find the bg connection mask for: f5:e8:84:5e:09:a6
05-14 17:45:10.294 5018-5352/? E/bt_btm: btm_sec_disconnected :: clear unused flags. p_dev_rec->sm4 : 0
05-14 17:45:10.304 5018-5115/? E/BluetoothRemoteDevices: aclStateChangeCallback: State:DisConnected to Device:F5:E8:84:5E:09:XX
05-14 17:45:10.304 3981-4166/? E/BluetoothEventManager: ACTION_ACL_DISCONNECTED
05-14 17:45:10.324 5018-5352/? E/bt_btif: Register with GATT stack failed.
05-14 17:45:10.344 5018-5018/? E/BluetoothPbapService: Device F5:E8:84:5E:09:A6 not waiting for authorization..Skipping cancel dialog...
05-14 17:45:10.424 5018-5352/? E/bt_btif: Register with GATT stack failed.
05-14 17:45:10.494 5018-5352/? E/bt_btif: Register with GATT stack failed.
05-14 17:45:10.584 5018-5352/? E/bt_btif: Register with GATT stack failed.
05-14 17:45:10.694 5018-5352/? E/bt_btif: Register with GATT stack failed.
05-14 17:45:10.754 24160-24160/com.example.jinghu.smartmagazine E/ViewRootImpl: sendUserActionEvent() mView == null
05-14 17:45:12.054 5018-5352/? E/bt_btif: Register with GATT stack failed.
05-14 17:45:12.064 5018-5352/? E/bt_btif: bta_gattc_deregister Deregister Failedm unknown client cif
05-14 17:45:33.104 3528-4160/? E/Watchdog: !@Sync 1813 [05-14 17:45:33.111]
05-14 17:46:03.104 3528-4160/? E/Watchdog: !@Sync 1814 [05-14 17:46:03.113]
05-14 17:46:33.104 3528-4160/? E/Watchdog: !@Sync 1815 [05-14 17:46:33.115]
