dfu bootloader eclipse managed project issue
I tryed to port the dfu secure bootloader sample of sdk 13 to eclipse managed project. after a few hours, i finished it. compiling and linking went fine but the filesize is a little bit bigger then the ordinary gnu make in the sample folder. if i flash the .hex, bootloader is starting. but after a ble flash with the app from an iphone, there is no response from the chip. no application is starting. no dfu bootloader anymore. if i use the .hex from the sample folder, all works fine. i attached the eclipse project for u guys to try it by yourself. maybe there is someone who can fix the issue and figure out what the problem is?
The sdk should be in folder "sdk" in folder before project.
Bootloader.zip
You can download folder with sdk here: www66.zippyshare.com/.../file.html
MBR Page of eclipse compiled bootloader. read after dfu update: eigen_mbrset.txt
